Questions about a soundboard.
Hello! I was recently thinkng about soundboard that would plug into minijack socket. After little research I dedcided to go with Arduino nano and DAC converter to get analog signal to jack. The sound files will be saved on the SD card and as you can see there are 8 buttons. I made the project in EasyEDA but I am not sure is it going to work. So I ask you. Thanks.
Picture of Questions about a soundboard.
What are you intending to do ? WIll the hardware process the samples quickly enough ? Do you have enough bit depth ?
ZawszeN (author)  steveastrouk1 month ago
I am intending to do mini jack soundboard, yes it will, and yes it does have enough bit depth.
Then write the code.
ZawszeN (author)  steveastrouk29 days ago
Ok
