Need help to create a DIY USB monitor
Hi all,
I am working on a project to create my own portable usb monitor (eg. ltn101nt02) and a LCD controller board.
However, the controller board requires a 12v power input with more than 2A. I am thinking of using a boost converter but I'm not sure if it will work. Also, with the USB as power input, can it still work as a screen input for my monitor?
Can anyone advise if i can modify the board such that I can use a USB for both power input and screen input?
Thanks!
i just bought a reversing screen and converted it to a 5v usb portable screen powered with a poundland power bank.... screen 15 quid cable another quid so
17 pounds and 15 minutes
Downunder35m2 months ago
If you only need "normal" power levels for the microcontroller then a simple 5V voltage reulator like the 7805 will do, available for currents up to 1A and a bit more with a heatsink.
Yonatan242 months ago
12V li-ion battery from eBay, and a step down converter from 12V to 5V?
Did you see GreatScott's Youtube video about doing this? I think you should watch it. I watched it a long time ago but I remember something about those screens working at a lower voltage or soemthing like that.
