3d Printed Gearbox for Small Dc Motors
Introduction: 3d Printed Gearbox for Small Dc Motors
Design Now: In Motion Contest
Third Prize in the
I have many salvaged dc motors just laying around in my garage. They
often produce too high rpm/ low torque for many application. So I decided do something about this problem. I just bought my first 3d printer (prusa i3 clone) so this was quite easy problem to fix. I only got PLA plastic available so the heat was bit a problem but if you follow this guide you can make it work too. I also made a test wheels so your next robot can move around :)
Step 1: Assembly Video
All steps are included in this video. There's some test setups in 5.40 mark.
Step 2: Technical Details and Materials
This gearbox has ratio of 1/16. With this 12v motor it can lift around 3,5kg (straight from the shaft.) 2 washers should place between each gear (see details in video). It reduces heat between plastic parts when 2 washers is rubbing each other. Adding lots of bearing grease between everything is essential. Depending your printer tolerances you might need drill out some holes bigger. Motor mount should be standard size.
My print settings with slicer.
  • layer 0.2
  • infill 25%
  • perimeters 3
  • bottom layer 2, top 3
  • Layer 0.3
  • infill 20%
  • perimeters 2
Step 3: Files
If you want know more about gears and ratios check for google "compound gears".
All comments are welcome. Thank you !
2 People Made This Project!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Pocket-Sized Contest
  • Science of Cooking
    Science of Cooking
Happy to see a use for my salvaged DC motors! 2 questions though.
1. My Prusa clone (CTC) consistently prints PLA small, resulting in me having to up the scale 102%, does your printer do this and did you design it accordingly?
2. Would you ever consider sharing CAD files for some of us to tinker with it? Say to change gear ratios for different applications.
I don't have any problems with scaling when printing it. The Design should print fine with 100% scale option. Right now I don't have a time to convert sketch up files to CAD compatible format. Thnx for your interest.
Cool project ... thnx for sharing with us ... can u tell me the weight of this gear box To calculate it's cost for me ?!
This is beautiful !!!
really liked it looked really proffesional!
Thanks for your nice job. What chemical did you used in the surface finishing step of the gearbox?
Firts I clean all surfaces with oil and dirt cleaner. Then I add 1 layer of primer, 2 layers of surface paint and 2 layers of clear laquer. Im using acrylic spray paints.
good for a battery powered irrigation controller - thanks a lot !
The gearbox looks great and it's just what I need for a project I am working on. What is the electric motor you are using and where can I buy one?
My motor 12v version. If you have old printers, scanners.... you may find these motors inside it.
Here's couple links to ebay.
