Air Filter (with Activated Carbon/charcoal)
1,986
37
4
Posted
Introduction: Air Filter (with Activated Carbon/charcoal)
Spotless Contest
This is an entry in the
Spotless Contest
Most common problem faced by a designer or creator like me, is the pollution created by 3D printer !
So here is an air filter for all designers and creators.
Materials
- Super glue
- Scissors
- Cable tie
- Computer cooling fan
- Power supply for fan
- Activated carbon/charcoal
available here -
http://amzn.in/hyctZ99 for india
http://a.co/8AD0XHG for usa
* the shape or structure may change but works similarly.
Step 1: Print All 3D Files on Thingiverse !
Download it for free on https://www.thingiverse.com/thing:2831858
Step 2: Covering
Covering both the parts with stockings, and stick it !
The inner cylinder is not stable inside the outer cylinder, so a base ring should be placed in the outer cylinder.
Step 3: Assembly 1
Fix the base ring first in the outer cylinder, and then the inner cylinder in it.
Step 4: Filling Activated Carbon !
Fill the gap with activated carbon and make sure not to overload, as this may result in blockage of air flow.
Step 5: Assembly 2
- join the "fan looft" and the cap with cable tie.
- place it on the cylinders
- and fix an computer cooling fan on it.
( make sure the direction of the flow is up words/outside not the other way )
follow me on instagram @thecreatebaba
on Thingivers @adm1413
And the filter is ready to use !
Happy printing
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    1 Questions
    just wondering why having printed four holes that match up with the four holes on the fan you've not used those holes with four bolts but opted for cable ties instead, genuine question.
    They were actually designed for nut and bolt assembly, but I was not able to find nuts and bolts near my house. So I used cable tie instead.
    One can definitely use nut and bolt assembly to fix.
    The cable tie are just an improvised option for everyone who are not able to find the nut and bolt of perfect size.
    Thankyou for your concern! ✌☺
    Please let me know if you have more questions.
    Really looking forward to answer all of them !
    Will include similar designs in my new SLA 3D printer. Thanks!!!
