Alexa Echo + ESP 8266 = Smart Power Plug
2,746
31
5
Published
Introduction: Alexa Echo + ESP 8266 = Smart Power Plug
This instructable use ALEXA ECHO direct control ESP8266.
My server just support authorization ESP8266 to Amazon server.
My server do not backup your data.
Vote for me :D Thank you!
Step 1: Requirements
HARDWARE
SOFTWARE
Step 2: Flash New Frimware
1. Unplug ESP8266 from module
2.Connect module to USB to Uart module:
GND -------- | GND TX | -------- RX
------- | IO2 EN | -------- 3V3
GND ------- | IO0 RST | -------- BUTTON -------- GND
TX ------- | RX 3V3 | -------- 3V3
BEFORE FLASH, PRESS BUTTON TO RESET
(IO0 alway connect to GND -> ESP8266 goto flash mode after reset)
3.Flash my firmware
  • Download my sketch:
    https://github.com/kim7tin/ESP8266-Smart-Power-Plu...
  • Open in Arduino IDE, and change:
    • wifi_ssid: your wifi name
    • wifi_password: your wifi password
    • control_password: your secret password
    • friendlyName: your device name
    • ip/gateway/subnet: ESP8266 IP static for NAT
  • In Arduino IDE. Select Tool:
    • Board: Node MCU 0.9 ()
    • Upload Speed: 230400
    • Port: Select your USB to Uart port
  • Hit Upload icon (before hit, press reset button in step 2)
4.Connect ESP to module again
5.Connect power plug
Step 3: Config NAT & DDNS
We need open port (default 666) to control from Amazon server to our ESP8266.
I just illustrated with my router. You can find out how to open your router port on the internet and open TCP port 666 to the configured ip in step 2
https://m.wikihow.com/Open-Ports
if you do not have a fixed ip. You must use a dynamic domain name. You can find many free DDNS service providers.
Step 4: Control by ALEXA ECHO
1.Enable my skill named "ESP8266 Smart Power Plug
  • Alexa app > Select menu > Skill
  • Search Skill named "ESP8266 Smart Power Plug"
  • Click to Skill
  • Click ENABLE
  • Login with your Static IP or DDNS domains (include your port - default 666)
2.Discover device
  • Alexa app > Select menu > SmartHome
  • Click Add device and wait 20 seconds
  • Now you can see ESP8266
3.Control:
"Alexa, turn on/off <your ESP named in step 2>"
Voice Activated Challenge
Runner Up in the
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    5 Comments
    Hi this looks really good but I cannot locate the Alexa skill you refer to
    It now live. You can search it now :)
    I just submitted my skill. It may take a few days for you to find it.
    You can edit my sketch a bit. My relay controller module via uart. With sonoff you can be direct controlled by gpio
