Bamboo Spaghetti Measure
2,383
27
10
Posted
Introduction: Bamboo Spaghetti Measure
Okay. I'll preface this by saying this is quite possibly the silliest thing I have ever made. It's silly. Right, so that is out the way.
In this Instructables I show how I made this Bamboo Spaghetti Measurer. My wife and I are pretty terrible at working out how much spaghetti is needed for each person.
DOWNLOAD FREE TEMPLATE HERE.
Step 1: Bamboo
I started with a piece of bamboo. This was a left over off cut from when we re-floored a room in our house. This worked out great as it was free, but you can use any wood you have. There are lots of different types of bamboo flooring and not all would be suitable for this, so do some research. This was pure bamboo which was resin bonded.
Step 2: Groove
As this was left over flooring it had a tongue and groove on 3 sides. First job was to take this over to the bandsaw and trim these bits. I set up the fence to make sure this stayed nice and straight.
I designed a template in Illustration and printed it off onto some sticker paper. You can just print onto regular paper, and use spray glue which is what I usually do. But doing this way is a lot quicker! If you guys want me to make this template available to download let me know in the comments below.
Next I took it back over to the bandsaw and cut close up to the line, but stayed just outside line so I could sand it closer to the edge. Not all bandsaw blades work well for cutting curves, I can't remember which blade I had on, but make sure you have one that works for this.
I tidied up the edges on the bench sander, and sanded right up to the line.
Step 3: Punch
I knew going in that keeping the lines central on this would be important in it looking great. Unfortunately I was slightly off on one of the holes, but it looks good enough for me!
To help keep these lined up neatly it was crucial I start the drilling off in the right spot, so I used a punch to start the hole off.
It was at this point that I realised that it was far too thick. There was no main reason, it just didn't look or feel quite right. I had planned to sand it down to size, but thought it was take too long. So instead I took another off cut, and started again, but this time trimmed it down on the bandsaw so it was around 3mm thick.
Step 4: Step Up
The main tool that makes this measurer work is the stepped drill bit. I got a pack that came with multiple sizes. I used the biggest one that goes up to 32mm big. To help me make sure I don't go over sized I added some masking tape around the right size.I slowly worked my way up through the sizes and up through the wholes.
You will get much neater holes if you can use a drill press here, but if you're careful you should be able to do it with a hand drill. I had to add a scrap bit of wood underneath to as not to mark my drill press plate.
For the final 32mm wide hole though I had to switch out and use a hand drill.
Step 5: Sand + Wax
Hand sanded the sides, edges and inside from 60 grid up to 240 grit. I always use left over sandpaper discs, after a while they no longer grip to my Ryobi Orbital Sander, but the sandpaper still have plenty of life in them.
This bamboo was getting scratches on very quickly, so I made sure to sand with the grain.
Then I used my Beeswax Wood Polish to finish the spaghetti measure. I have a video on how to make your own (DIY Beeswax Wood Polish) or it's available to buy directly from my shop (Curious Creator Beeswax).
Step 6: Final Image
Here are the final images. If you make your own make sure to share a photo with me on here! And don't forget to head over to my YouTube Channel.
Step 7: Video
Don't forget to watch the video here.
'A Curious Creator' is a participant in the Amazon Services LLC Associates Program + eBay Partner Network, affiliate advertising programs designed to provide a means for sites to earn advertising fees by advertising and linking to 'amazon.com', 'amazon.co.uk, 'ebay.com', 'ebay.co.uk.
Any links I provide to you in will be affiliate links, these provide me with a small percentage of any of your purchases at absolutely no cost to yourself.
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    8 Comments
    Great idea and all, but what I really want to know is why do you require access to my Youtube account for a copy of your plans. Specifically it says ... "View and manage your videos and playlists. View and manage your YouTube activity, including posting public comments" What's really going on here ... it seems pretty simple to publish a pdf without providing you access to my Youtube account ... Pretty sleazy.
    Screen Shot 2018-04-10 at 1.03.01 PM.jpgScreen Shot 2018-04-10 at 1.03.53 PM.jpg
    Hi, all it's asking you to do is log in to your YouTube account and subscribe to me. It's fairly standard way to 'pay' for things, instead of charing hard currency I charge for my time, effort and work with a YouTube subscription. I do not get any access to your account.
    This is really good... but I keep losing these kinds of things all over the place and I just figure "Mehhh big handful" and I am not dead yet.. bit fat though. :(
    Aha Yes I went through a stage of having too many kitchen gadgets, but this one is super useful! It helps not make too little either! That's worse than too much!
    Very nice simple gift idea but I was having trouble finding just what size holes you determined for the servings. I am assuming these are for single then two and three person servings?
    Ingenious idea and a very well made Instructable!
    Thank you very much! Super useful little tool :)
