Bicycle Mobile Charger
6,813
110
12
Posted
Introduction: Bicycle Mobile Charger
Epilog Challenge 9
This is an entry in the
Epilog Challenge 9
First Time Author Contest 2018
Hello Friend , Due to maximum use of Smartphone battery will discharge very fast. so we need Mobile charger and Electricity. But When we are at Street It very difficult to find. In this Instructable show you that how to charge your Smartphone using Bicycle(Free Energy).
See above Video First so you Can Easily understand. We Make Different Creative Video on our youtube Channel. Follows us on ...https://goo.gl/xx3FD8
Tools To Be Used:
  1. Drill Machine
  2. Glue Gun
  3. Zip Tie
  4. Spanner Set
Material To Be Used:
  1. Step up Booster: DC 0.9V - 5V to 5V 600MA
  2. DC Motor
  3. Small Wheel
Step 1: Making of Wooden Stand
In this Step we need two piece of wooden. Make the 2 through hole in wooden by drilling machine. This 2 hole is for Zip Tie to fix this Stand with the Bicycle. Put one Small piece on the other piece and stick with use of Glue Gun.
Step 2: DC Motor
To Produce electricity We Need Mechanical System. Here We Rotate the dc motor by bicycle Tyre. So we can Convert mechanical Energy into Electrical Energy.
Step 3: STEP UP BOOSTER
Step up booster is increase the voltage so we can easily charge our phone. Follow below step.
  1. Soldering of booster wire with DC Motor.
  2. Put Glue on Wooden.
  3. Stick Motor on Wooden.
  4. Put Booster on the Small Wooden Piece.
Step 4: ZIP TIE FITTING
To Connect this Assembly very tight we need Zip Tie. Tie the motor use of Zip tie inserting in drilled hole.
Step 5: ROTATING WHEEL
To rotate DC Motor we need a Small Wheel. This Wheel is Mount on the Motor Shaft. See the full Assembly on Picture.
Step 6: CHARGE YOUR PHONE
Attach this Assembly to bicycle by zip tie. Small wheel is touching the bicycle tyre,If we rotate bicycle tyre small wheel also rotate and voltage is up by booster. Now you can Charge your phone using Mobile data Cable..
If you Like Our Insrtuctable than Subscribe our YouTube Channel : CREATIVITY BUZZ.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
2 Tips
I have a few improvement:
- maybe it's easier if you're using an old bicycle dynamo (it became a generator with the regulator)
- if you're charging a battery (or maybe a bigger capacitor also could be a good solution) instead of the phone directly, the charge is continously when you stop the bike.
But I like the basic idea, thanks for sharing!
I would suggest a wider wheel, about 1/4". Eventually, that skinny wheel is going to saw through the sidewall of the tire.
8 Comments
I like the idea. If I was going to do this tho, I would put some permanant magnets on the spokes, and have them pass by a coil. Then there is no moving parts to wear against the tire etc.
Many years ago I had a bike with a purpose-built dynamo (6V @ 3A, AC). I rigged it with rectifiers and a three-way switch so I could charge up my lights during the day and have them good and bright, even when I stopped at junctions. This was a long time ago - before LED lights - so batteries for normal bike lights never lasted long.
But after running fine for about three months I suddenly had a blow-out. The dynamo had worn through the tire sidewall.
Nice, you basically made a dynamo.
The booster is an interesting part. If there are step-up/step-down converters that can work with a wide range of AC voltages (say up to 32V), it may be handy to connect one with an existing bike lighting circuit, if it's powered with a hub dynamo.
I don’t say this often, but I am now legitimately going to look at making this. Can’t believe I didn’t think of it before.
One day i put a motor ,scrapped from a printer. when i reach a certain speed, the led burn lol (i just attach the led directly). When speed up in a bike, will not burn the DC-DC?
