Bluetooth Speaker
2,122
30
Published
Introduction: Bluetooth Speaker
About: How to Everything.
Hello Guys, In this instructable, I'm making an awesome Bluetooth speaker. which also has an inbuilt charging feature.
Specs & Features:
Dual 100W Full- Range Speaker
CC16 High- Efficiency Amplifier Module
Inbuilt 5600mAh Powerbank
Charging
Bluetooth 4.1
Long Lasting Battery Backup
Step 1: Get Two 100 Watt Speaker
First of all, you need two 100 watt JBL speaker.
Connect the negative and positive wire to both of speaker.
Then You need below products to make this...
1) Cement and water
2) CC
Step 2: Make Concrete Outer Box
Then make one 33 cm long and 11 cm hight mold with help of PVC pipe and hard sheet.
Then pour the concrete into this mold and take this for 24 hours.
Then disable outer box of PVC pipe and sheet.
Step 3: Stick Two Speaker.
Stick two speaker of JBL to the concrete box using the glue gun.
Step 4: Connect Speaker With Amplifier
Take 16cc power amplifier and connect both speakers with this.
Step 5: Stick Bottom Wood
Take bottom wood and stick it with concrete mold using the glue gun.
Also, stick amplifier module with this concrete box.
Step 6: Make Power Supply
Make power Supply with the charging point.
Take Power bank to get three 18650 lithium battery and make 11.1-volt power supply using 3S charging protection circuit.
Step 7: Pack This Speaker.
Pack this speaker using top wood.
Step 8:
Step 9:
Stick It! Contest
This is an entry in the
Stick It! Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    3 Discussions
    Concrete looks great in this project. Its main advantage here is weight. Big weight is good for loudspeaker! ) I think it will sound better, if you separate speakers from each other to get stereo effect . )
    The concrete looks amazing!
