Captive Ring Puzzle
Introduction: Captive Ring Puzzle
I love puzzles. Not jigsaw puzzles where you assemble a box of oddly shaped pieces, but objects that make you think. Objects that make you look at everything from a different perspective, that make you understand the world isn't always as it seems. These are the puzzles I love.
I first saw this puzzle posted by pocket83 and knew I needed to make my own.
This simple puzzle is made of metal, brass, and wood. The ends are not removable, the ring doesn't come apart, there is no optical illusion present, nor is the image changed to deceive.
With a handful of tools and some scrap wood, you can make this simple puzzle to amaze your friends and family.
Step 1: Tools and Materials
There are a few things you will need to make this puzzle.
  • Saw
  • Drill Press - preferred (a hand held drill could also be used)
  • 1/4 inch drill bit
  • Compass
  • Awl
  • Disk Sander, Palm Sander, or Sanding Blocks
  • Hacksaw or Angle Grinder
Step 2: Cut Wooden Discs
Cut two wooden squares that measure 2 3/4 x 2 3/4 inches (and about a half inch thick). I used a crosscut sled on the table saw. Using an awl or nail, mark the center of each block and draw a circle with radius 1 5/16 inches using a compass. Using a band saw or similar saw, cut out the circle just bigger than the mark made by the compass. Make the discs perfectly round by removing the excess material with a disk or belt sander.
Step 3: Drill Three Support Holes
Using the compass, draw a new circle with radius 1 1/32 inches and divide that circle up evenly with the compass. This can be done by keeping the compass at the same radius as the circle, select a point on the circle and mark the radius away from that point. Transferring the "center" of the compass to these new marks and marking the radius again will result in the circle being divided into roughly six sections. Select and mark three of these divisions.
Drill out the holes as deep as possible without drilling completely through the wood.
I wanted the grain of the two discs to go in the same direction, so I took special care to mark the points of the second disk so this would happen.
Step 4: Polish the Rod
Take a 10 inch section of rod and insert it into a drill. Starting with 220 grit and ending with 600 grit sand paper, sand the rod till it's as shiny as you'd like. You can even use buffing compound if it's available to make the rod really shine.
Step 5: Cut Rod
Using a hacksaw or angle grinder, cut the rod so you have three pieces 2 inches long, and one 1 3/4 inches (this center rod will be too long and will need to be cut to final length later on). Using a bench grinder or disc sander, remove the burs caused by cutting the rod.
Step 6: Drill Center Holes
The center holes are the core of this puzzle. Drill one hole deep enough to recess the magnet about 1/16 of an inch. This will be what holds the center post in place making it appear solid. Drill the other center hole as deep as possible without drilling completely through the wood. Then take a 1/4 inch straight router bit to flatten out the bottom of this hole. This will allow the center rod to slide as far as possible, and give clearance for the brass ring.
Step 7: Test Fit
Test fit everything. Make sure everything fits together and that the center rod gives enough clearance for the brass ring to be replaced. If there isn't enough clearance, carefully trim the center rod shorter until there is enough space for the ring to slide in and out.
Step 8: Chamfer Edge
Using a router, add a small chamfer to the edges of each disc. You could place any edging you like on the disk to suit your personal taste.
Step 9: Sand
Using a palm sander or sanding blocks, remove all rough edges and markings from the design layout process.
Step 10: Apply Finish
Insert nails through some scrap cardboard to support the pieces to be finished. Using fine sandpaper to clean up irregularities in the finish between coats, apply four or five coats of lacquer.
Step 11: Cut Notches in Outside Posts
Using a hacksaw or thin disk angle grinder, cut notches for the epoxy to hold onto the rods in the next step.
Step 12: Final Assembly
Using quick set epoxy, embed the magnet into its corresponding hole. Allow this to dry for a few hours to ensure the movable center rod will not pull it out of place when finishing the assembly (speaking from experience, trying to reattach the magnet after it has fallen out is nearly impossible to do without ruining the rest of the puzzle). Apply epoxy to each of the posts and ensure everything is square. Let sit for 24 hours.
Step 13: How It Works
If you haven't figured out how it works by now, it's deceptively simple. The center post slides down when pulled from the magnet. This allows the ring to slip over the top of the post.
If you happen to make one or something similar, please leave a comment showing your favorite puzzles.
2 People Made This Project!
  • Pocket-Sized Contest
  • Pro Tips Challenge
    Pro Tips Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
Great instructable. Well done for the way you have stepped through each individual stage of construction. Will look forward to making this one for my neice.
I love it. One of the BEST and with pictures. Kudos.
Good idea and good instuctions! Great stocking stuffer idea!
Great Idea. I love little portable puzzles like that. Awesome job!
You provided the solution to "what can I make for the grandchildren this year?" THANKS! Neat puzzle. So I made a dozen. I did use a shortcut that may be of interest to those making multiple copies. I used a hole saw in my drill press. Once the saw had cut about an 1/8" and the pilot hole had not gone all the way through, I removed the pilot drill (i.e. the 1/4" twist drill). clamped the workpiece in place and completed the cut with the hole saw. Then I sanded the edges by mounting the blank discs in the lathe and sanding as the disk rotated fairly slowly.
You might also be interested in the note I attached to each gift puzzle:
year I decided to make a simple little curio for a few friends —something
totally useless, just a novelty with a brass ring secured by steel posts
between wood caps.
hardwood lumber is becoming very expensive and there is a growing market in
reclaimed woods. I went on line
and ordered several pieces of oak and maple. Responsible dealers always share the origin of the materials
they sell. Imagine my surprise
when the beautiful pieces I ordered came with a tag stating that the wood had
come from “shipping coffins” which had been stored in a New York City warehouse
for many years.
more detail than I wanted to know, I learned that the wood used in these curios
had been a coffin in which Eric Weisz’s body had been shipped from Detroit, where
he died to New York City on October 27, 1926. (He is now interred
in the Machpeiah, a Jewish Cemetery in Queens.)
wondered why, in making your gift I had such a hard time keeping the ring in
it be because the wood in your gift had once transported the body of Eric
Weisz, born in Budapest, Hungary on March 24, 1874. The same Eric Weisz the world came to know as Harry Houdini?
Nice! I gotta try this one! One thought about cutting the discs; I plan to select a hole saw with in ID of the proper disc size, cut a hole in a scrap piece of ply, then clamp the hardwood to the piece of plywood, remove the center drill bit from the hole saw, cut the hardwood to form one of the discs through the hole I just cut in the ply, reclamp and cut a second disc. That should save time in making the two pieces the same size and "perfectly" round.
Thanks for the link and the heads up; I have added this to my "TO DO" list, right now with X-mas around the corner I'm finishing a work desk for my grandchildren (Rustic-Modern) style, so right after the holidays I have a new "Trick/Puzzle" to work on.
Compaq1501, your comment is a puzzle.
tomatoxkins: I was studying the photos, thinking the straight rods were brass. Then it hit me. They had to be magnetic, therefore they could not be brass. Some stainless steel is magnetic and could be used. Not all is though, and it could not be used. Great instructable.
Thanks for all the detail, now I can build one for my daughter
