Cat Treat Push Feeder
379
5
Published
Introduction: Cat Treat Push Feeder
About: I enjoy making new Instructable
Hi , this is a cat treat push feeder , it means cat have to push the lever by one paw and then eat the treat which is fun and make them busy figuring out how on how to take out the treat.
Please vote for my instructable if you like it :)
Step 1: Tools and Supplies
Drill and Screwdriver
Cutter
Marker or pen
Screws
Brackets
Wood 3" , 5'' , 7''
Disposable Plastic Bowl
Plastic Bottle Cap
Step 2: Making a Lever
Secure the brackets on 7'' wood piece in the center and make a hole in the 5'' peice from the center side
Drive a bolt from brackets and the wood making it a lever
Step 3: Cutting Out
Put the lever in the plastic container and mark the area from where it can be pull and from where the plastic cup will come out,cut out the plastic by cutter make it big enough so the wood don't stuck with the sides
Step 4: Jointing
when lever inside drive the screws from outside the plastic bowl to secure it ,now it can easily push from outside
Secure the bracket on inside lever just for load so the lever outside is always upside
Step 5: Placing the Feeder
Place the plastic cap over the inside lever and secure it with a screw,put some treats in the cap.
If you like this instructable please vote this :)
Pets Challenge
This is an entry in the
Pets Challenge
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Stick It! Contest
      Stick It! Contest
    2 Comments
    Smoochy definitely loves her treats...might give this a try.
