Cool Chicks, Hot Coop
1,307
11
6
Published
Introduction: Cool Chicks, Hot Coop
"Why do most chicken coops have only two doors, if they had four doors they would be a sedan"
I love my Gals.
And having your own Backyard Chicken Coop is great for getting rid of scraps, keeping the yard clean (well of weeds and bugs) and having fresh eggs every morning.
But Living in Las Vegas, has some disadvantages, mainly the summer heat which can get to 112°(F)
So being Geek I am, I came up with a Solution.
Step 1: Play 'Misty' for Me
I decided I would make part of the coop 'Air Conditioned' for the gals, where I would use a mister to keep an area of the coop wet and cool, this also would make the ground moist
(not wet, I will go into the reason why further on)
It would evaporate and keep the area cool when the mister was turned off.
Step 2: Water / Filter / Valve
You can do this with a garden hose and a mister attachment, I wanted
something a bit more permanent as well as techie. I purchased most parts at Home depot, some PVC piping, mister nozzles, a solenoid 12v Value, etc.
12V (DC) is safe to work with, and flexible you can run it using cheaper wire from any power source.
I Put a PVC "T" from the feed to my sprinkler system, added a Drain and a Valve, ran it into a filter, then across the back of the coop with another valve
Step 3: Building the Thing
Installed the solenoid valve and then added Three "T's with 1/8" taps from the Mister adapters
(I later capped two of the taps, the area was getting over watered and muddy)
You don't want the ground to get wet and muddy, You would get wasps attracted to the mud, as well as the chickens walking around in mud.
Step 4: Electronics and Such
I purchased on ebay a few electronic 12V timers, as well as a 12v 'reverse' thermostat
(Turns on when hot, turns off when cool)
The reason was I didn't want the mister to turn on till it was above 90° which happened around 11AM,
but I also did not want the misters to be on constantly that would make the area muddy, so the timer was used to turn them on for 30 mins, then turn them off for 30 mins, The reason I added the thermostat was that there where some cool days so those days I did not want it misting
Step 5: Party in the U.S.A
Because the ground was moist, uneaten seeds started sprouting, and worms where attracted to the area, the gals partied and stayed cool!
and this is my 50TH INSTRUCTABLE!!!!!!
Pets Challenge
This is an entry in the
Pets Challenge
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    6 Comments
    be careful with the hardware cloth. its soldered together and the solder contains lead. A friend of mine lost some birds because of it.
    LOL -- back 'east we called it "chicken wire"
    My gals love silicon, I sealed a wet area, with it and they where pecking at it for weeks trying to get at it... They did eat some of it, they didn't get sick or die, but i did notice they had much bigger breasts
    Hardware cloth?
    sorry, its the galvanized coating that "may" cause problems. Having been there, it scares the heck out of me. Hardware cloth is the name of the metal wire mesh with which you made your coop. Since chickens don't crawl on it, south it or eat it its probably fine.
    Very nicely documented. Nothing like really caring for your feathery friends.
