Cordless Power Tool Conversion 18VDC to 120/240VAC
376,770
397
148
Posted in TechnologyTools
Introduction: Cordless Power Tool Conversion 18VDC to 120/240VAC
Necessity is truly the mother of all inventions....and my case was no different.  About a year ago, I found myself with a dead battery for my Ryobi 18V cordless tools and no means of getting a new one as I was working overseas. So I came up with a setup to run my tools off AC (household current) safely and with no worries of my tools dying halfway into the job.
Now I enjoy all the benefits of battery operated power tools just as much as the next guy....They're convenient, flexible, and you can usually get quite an assortment of tools that run off the same battery.  Then the inevitable happens....you get the dreaded blinking set of lights on your charger and the batteries die out almost instantly. Your faced with two options.....Drop $50-$100 on a new set of batteries or try rebuilding them yourself.  Neither one of those two options appealed to me nor did I have the time to order the parts from overseas.  As anyone in my situation might do, I scoured the internet for an alternative solution.  I found guys connecting car batteries to their drill...ummmm no thanks.  Then I came across the idea of using an old laptop power supply in place of the battery.....The voltage seemed right, but alas the wattage was too small.  Even at 180 watts, the biggest pc power supplies couldn't provide enough to overcome the start-up current of my battery operated circular saw or angle grinder.
The principal of the pc power supply was sound, I just needed something bigger.  After a little more research I found that the common everyday laptop power supply is what they call a "switch power supply".   Turns out, switching power supplies are very common everywhere in the world, affordable and come in a variety of voltage and power ratings... I eventually chose a 350w AC/DC power supply produced by a reputable company called Meanwell with a voltage range of 15-18volts DC.
Wiring of the power supply to a dead battery is very straightforward, but the following instructable goes through the details step-by-step.
Step 1: Electrical Warning
Before starting please understand you have a power supply capable of discharging 20Amps.  Although the setup is fairly simple, if you are not comfortable working with electronics, please seek professional help on this Instructable.
The cable exiting the battery and connector of the DC outlet from the power supply are made from an standard 120VAC wall plug.  The plug and cable was selected for ease of availability and to allow me to use a standard extension cable if needed.  For my case, I will be the only individual using this setup.
Under no circumstances would I plug an AC powered appliance, tool or otherwise, into this power supply.  If you choose to make this setup please think ahead who might be using it.  If there is the remote possibility of someone not trained to using this setup, I would suggest using a different type of connector and cable.  Something more unique but capable of handling the amps.
One recommended cable is that of a twist lock generator plug.
Step 2: Tools Needed
Material
• (1) dead 18v Ryobi battery
• (1) 15v 350w AC/DC switching power supply
• (1) IEC C14 electrical receptacle (for incoming AC power)
• (1) standard 120vac receptacle to be used as the DC output or a twist-lock generator receptacle
• (1) computer power cable (has the mating connector for the C14 receptacle
• (1) 16-18awg extension cord (male connector is needed or a male twist-lock generator plug)
• (1) small toolbox (big enough for the power supply and to store the battery)....a 50cal ammo can works really well too.
Tools
• small Philips screwdriver
• needle nose pliers
• wire cutters
• hot glue gun
• 2 part epoxy
• soldering iron
• razor blade
• hacksaw blade
• drill
• multimeter
Step 3: Gutting the Battery
1. Using the Philips screwdriver, remove the 6 screws at the base of the battery (special thanks to my lovely 5 year old)
2. Separate the two halves of the housing and pull out the battery pack
a. Save the (2) yellow square buttons and the mating steel spring
3. Cut the leads from the battery to the terminal block
4. Save the plastic terminal block and the positive (+) and negative (-) terminal strips
Step 4: Don't Mind the Wire..."doctor's Orders"
1. Using heavy gauge power cord (16 awg) cut off the female receptacle end.  The length of the cord is up to you.  Remember this cord is going to be connected up to your power supply, but you can always use an extension cord if your tool will be far from the power supply. I find 3-5 ft of cord is sufficient.
2. Routing the wire....There are 2 options
Option A: Drill a hole in the battery cover the diameter of the outer jacket of the wire.  The location of the hole is your choice.  You can even add a rubber boot over the wire as it exits the battery cover to act as a strain-relief.
Option B: Install a swivel adapter I've designed and will be making available on www.shapeways.com in the near future.  This swivel adapter allows the cable to pivot from the front of the battery pack to the rear anywhere within the 180deg angle.  The remainder of this tutorial will be using the swivel adapter.  I've also uploaded the stl files onto www.thingiverse.com under the title of "18V Battery Swivel Cable Lock" if you have access to a 3D printer.
3. Cut back about 6" of the outer jacket insulation from the cable
4. Strip and tin about 1/4" of the leads.
5. The swivel adapter consists of (3) parts
    (2) clamp halves
    (1) swivel base
6. Make sure the clamp halves can completely encircle the OD of the outer jacket of the cable
7. Sand the ID of the clamp halves until you get a snug fit around the jacket
Step 5: Start Cutting
1. Mark out a 1/2" wide path on the bottom of the battery cover to be cut off.
2. Using a 1/8" bit, drill a series of holes along the path long enough to get a hacksaw blade to continue the cut.
3. There will be two standoffs from the original screws on the inside of the bottom cover along the path of where you will be cutting.....cut them off.
Step 6: Break Out the Epoxy
1. Feed the wire through the slot of the bottom cover
2. Using some "Super Glue", attach the clamp halves to the edge of the outer jacket
3. Assemble the swivel adapter to the clamp halves, feeding the stripped wires through the small slot of the swivel adapter
4. Epoxy the swivel adapter to the inside of the bottom cover
Step 7: Fire Up the Soldering Gun
1. Cut off about 4" of the exposed 8" of unsheathed wire
2.  Strip the about 1/4" of insulation from the wires and solder them to the positive and negative terminal strips (see the attached image for the polarity of the cable)
3. Re-assemble the terminal block and install it into the top half of the battery cover
4. Use a hot glue gun to fill the cavity where the terminal block sits
5. Attach wires from the top half cover to the bottom half cover using wire nuts or cable lugs.
6. Reassemble the top and bottom halves of the battery cover using 4 of the 6 screws.  Remember to install the yellow side buttons and springs.
Step 8: Box It Up
Now its time to make the housing for the power supply.
1. Arrange the power supply in the box to allow room for the battery adapter and the AC inlet plug and the DC outlet plug
2. Make a template for the four M4x6 mounting screws of the power supply to transfer the location onto the box.  Drill holes in the box to mount the power supply.  But don't mount it just yet.
Step 9: Laying Out the Connectors
1. Locate where you want to mount the incoming AC and outgoing DC receptacles on the box.  I prefer mounting one at each end and dressing the wires under the power supply.
2. Solder (3) 12" 16awg gauge leads to the IEC C14 electrical receptacle for incoming AC power on the positive, neutral and ground leads.
3. Solder (2) 12" 16awg leads to the standard 120vac receptacle for outgoing DC power on the positive and negative leads.
4. Make a couple of templates of the receptacle profile and transfer the outline to the box.  Using a sharp utility knife, make several passes until you cut out the holes for the two receptacles.
5. Attach the receptacles either by screw, glue or snap fit; whichever it was designed for
6. Apply some hot glue over the leads on the receptacle to protect the exposed terminals
Step 10: Final Connections
1. Attached the leads of the connectors to the indicated leads of the power supply.
2. Install the plastic protective cover over the terminals of the power supply
3. Make sure the selector switch on the power supply is set for your country's voltage, either 120 or 240VAC.
4. Plug in your portable power supply using a standard computer cable for the AC receptacle.
5. Plug in the battery adapter into the DC receptacle.
6. Turn on the power supply with the switch located on the IEC C14 electrical receptacle
7. Using a multimeter, check the polarity of the battery terminals and adjust the pot on the power supply (small plastic philips screw to the far left of all the terminal connectors) to above 18VDC.
8. Once confirmed everything is reading correctly, mount the power supply within the box and dress the wires neatly under or behind it.
9. Plug in your battery adapter into your favorite 18V CORDLESS tool and enjoy continuous use.
2 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Make it Move Contest
  • Casting Contest
    Casting Contest
3 Questions
Also. If I get a PSU with too much amperage will it hurt my tools?
Hey TadL1, sorry for the late response. What power supply (PSU) did you use to make your setup? A larger supply should not hurt your tools, although I've never had to use more than a 20A supply.
Ok so I tried this using a 18v 20A PSU and it works on my drill when I start at a low speed. However it does not work when I use my grinder or saw. What amperage PSU do I need?
so why are you using such a large power supply. The battery is rated at 18V & 48 Watts, so thats about 3 amps top. Are you not concerned with burning out the motor, OR does the motor only take what it needs?
148 Comments
The people asking why not just buy batteries are totally missing the point. I built this as a gift for my dad because let's face it - batteries all get drained at exactly the same time - in the middle of a job. This is a great way to keep things moving while you charge up the batteries. Excellent article!
I'm an Electrician by trade. You can't beat name brand, quality tools. Using Ni-Cad packs you'llnever escape that problem.
Was it worth it? I use Makita and 2 battery's. Never gone dead yet. You've started on wrong foot. Throw all that Ryobi garbage in the creek. Initial outlay expensive but tool pays for itself in trouble free performance.
zapp
Hey Zapp,
You have a right to your opinion and I respect that, but to each their own. I'm sure there are guys out there that can make use of what I've instructed and that's why I did it. My needs overseas dictated I have a set of cordless tools. You might not be aware of this little fact, but consumers in the U.S. are privileged when it comes to availability and price of products. In southeast Asia where I'm currently working, you can't get a decent set of 18v tools for less than $1000!!! So I when I needed tools I brought them from the U.S. and I didn't want to drop a wad of $$$ on something that might get stolen on the job site. When the battery died, I improvised. Enough said.
I value and appreciate good well made tools just as much as the next guy, but my Dewalts, Porter Cables and yes....Milwakees stay home.
I appreciate your reasoning and well know the sinking feeling when quality tools grow feet and are never seen again. $1000.00 for a rechargeable Lithium set-up would reduce me to corded tools also. The corded tools do have an appreciable increase in torque and speed over battery operated though and in your situation I believe, given the cost, I would stick with corded exclusively and invest in heavy duty extension cords. If job site theft is a main concern when purchasing, choosing, and comparing available tools I believe I would locate workmates a tad more respectful of others tools. There's nothing I hate more than a derelict attempting to sell stolen tools on a jobsite for 1/10 what they actually sell for. I'm adverse to the cost of the required XFMR to supply needed power for cordless tools. I have been fortunate that the majority of jobs I've worked on were inhabited by person's aware that my tools are my living and have respected that fact . Sorry If I offended yet I still feel converting cordless to corded kind of defeats the original purpose, convenience, and increase in utility of the new cordless offerings. In the States availability of High end cordless tool's is evidently 1/2 what you are paying in your locale giving great credence to your solution. I must insert I've a Milwaukee Magnum 1/2" Holeshooter which is 20 years old and will outlive every cordless I've ever purchased as will the Sawzall, Circular saw, etc., Eliminating the umbilical cord though will always increase productivity while decreasing frustrations to an extent making cordless indefensible when power isn't available. You would be amazed the situations absent of mains power making cordless necessary. Good things to be said for both but in my mind if theft dictates selection of needed tool I once again thank my lucky star's for the market I labor in. I will forever have my original corded Milwaukee's purchased when I realized the offerings of local Electrical contractors consisted of the cheapest tools they could find due to the conscienceless, thieving, tool less electricians (?) they insisted on hiring. When the manufacturer's developed cordless my 1st purchase of a Dewalt 14.4 volt drill, though Ni-cad, became my constant companion and now you would have a fight if you attempted confiscation of my newest Li-ion cordless tools. I'll never relinquish my corded tools as there's still jo
I had lots of similar issues with the theft of my tools, and when I " frank-en-tooled my saw saw, I can say, that a mangled, black taped, funny looking thing that I ended up with, is still here and happy with me today
. Because when a thief is looking at what to steal, a home made modified saw saw just isn't at the top of the list of what a pawn shop or other similar place of business is going to be interested VB OK n buyng.. so an ugly tool is an in-depth stolen tool if you ask me
jobs they excel at (18" ships augers!), things only the outrageously priced and over the top 36 volt cordless are evidently meant for as well a stroking the Male ego. Sorry if I offended and good luck with those "footed" tools.
It should be mentioned that what you wrote 4 years ago is not necessarily true today. Today you can get 3rd party battery packs, inexpensively shipped from Chinese merchants to (almost) anywhere in the world, for the vast majority of major brand cordless tools.
Franco40,
Sorry for the long winded reply & if I offended. I have been wiped out of tools several times in a 30 year career but if I can't use my tools for the purpose I purchased them they are waste of money. I have worked for contractors using my tools since the 1st theft and refusal of my employer at the time to replace them. I continue to supply my own tools with my employer supplying consumables. On the occasion I was relieved of a tool the cost of consumables increases accordingly. Maybe underhanded but have had no complaints from employers. Their insurance may not replace lost personal tools but they haven't seemed to mind replacing said tools through unexplained increases in consumable's cost even when my drill bit, blade purchases, etc. briefly rise to match cost of stolen tools. I guess I'm fortunate to be employed by persons appreciative of the fact I always have the required tool available without searching an entire job-site. I still believe purchase of cheap (Ryobi) tools beats the adaptation of PWM power supplies of adequate output to power a cordless tool. Please accept my apology,
Zappenfusen
it's possible that the power supply you used has one already, but I would recommend adding an inline fuse holder on the output side to avoid excessive current damaging anything
Franco: I bought a Mean Well SE-450-12 supply for my old Panasonic 12-volt cordless drill. It works just fine. This power supply can deliver up to 35 amps at 12 volts. I'm able to drill 1-1/2 inch diameter holes thru 2 x 4's, with a spade bit, without the drill stalling or even slowing down. When the bit snagged on the bottom rim of a hole being drilled, the current to the drill spiked, and the current overload circuit quickly shut the power supply down, saving my wrist from a nasty sprain.
Thanks for the post. due to this i did the job well---- thanks so much, only i pay about $45 bucks (like 900 mexican pesos)
Glad to hear the setup worked out for you. Did you use the power supply I mentioned, or opted for a different wattage?
Thanks for the very informative instructable.
This will make my Makita brushless router able to work in my CNC machine. If I used the 5AH battery it would quit 1/2 way through the job.
I hate replacing brushes on my AC powered unit and the only ones you can get brushless are DC.
I have just a low amperage RYOBI 18v radio in my shop bathroom that drains batteries quickly and notice it has a USB port to charge cell but will it back charge battery with Male-2-Male input? Tried 1/2 amp cell phone charger first and battery still drained. Trying 2.1amp now...
Sf94121@gmail.com
Are you intrest in this Ryobi ONE+ 18-Volt Replacement Battery?
Thank you for the post. I followed it and made one for my cordless tools. I am not a big fan of battery usage, thinking that all the batteries are environment hazard.
would this work
http://www.rcmoment.com/battery-charger-accessories-2128/p-rm3764eu.html?currency=GBP&aid=rmsplagb1&gclid=Cj0KEQjwn_3GBRDc8rCnup-1x8wBEiQAdw3OAaH-8_QDpg0ScFDkH1qe4F9ug6h6mY3zQhDW5WXQfTgaArY38P8HAQ
