DIY Switch for Windows Games With a Big Battery
747
12
Posted
Introduction: DIY Switch for Windows Games With a Big Battery
First Time Author Contest 2018
This is an entry in the
Hello community,
as the Nintendo Switch was a big success I thought that I also need some cool mobile gaming console (other then the typical NDS or PSP ....). I had laying around a Chuwi Hi8 (Dual boot: Android and Windows) and some batteries (18650). My tablet didn't last that long with the stock battery, so I tought I'll add a big battery to it. My Idea was to play typical Windows games mobile (like Trackmania, Gothic 2, Borderlands, N64 Emulator ...).
Step 1: Aquire the Parts You Will Need
For a project like this you will need these parts
  • Windows/Android cablet (eg Chuwi Hi8) (Gearbest 98$)
  • Gaming controller (eg Ipega PG.9023) (Ebay ~ 28$)
  • 4x 18650 batteries (eg NCR18650B 3400mah) (Gearbest ~28 $)
  • Step-Down converter (eg Step-Down Led Voltmeter 4.5-24V To 0.93-20V Dc-Dc)(Ebay ~5$)
  • Balance cables from RC Hobby (eg 1x 5s and 1x2s Cable) (Ebay 5 $)
  • Balanced charger for 2s (eg Balance Charger For 7.4-11.V 2-3S 2S 3S Cells Li-PO) (Ebay ~ 11$)
  • Simple switch (eg took from broaken electronics or ebay)(Ebay 0,1$)
Tools:
Hot glue gun, soldering iron, maybe voltmeter, wrench, drill, (3d-printer)
Step 2: 3D Print the Battery Compartment
If you want to use my design, you have to 3d-print my design and glue the parts together
Design:
https://www.thingiverse.com/thing:2783700
Step 3: Solder Everything
Now you have to solder everything and glue all the parts together.
  • first remove the stock battery
  • then put the batteries as depicted (circuit diagram) together and solder each side two batteries in series (to get 2x 2s = 8,4V)
  • be careful when soldering the batteries, that you not short the + and - cables
  • before you glue everything in place, please test the electronics first (otherwise it will be difficult to change something)
  • in my case I had to set the output voltage to 3,6V, otherwise the tablet won't turn on
  • since the description of the step down converter says that the input voltage sould be always 2V higher then the output, our batteries can be run until 2,8V for each cell (check the datasheet of your battery)
  • if everything is working, then glue the battery to the case and drill beforehand a hole into the back of the case of the tablet and solder the wires to the tablet
Step 4: Have Fun
If all works, just have fun. The battery should last more then 8h and up to 10h I guess (depending on the game you are playing). Since in my case there are 4x 3400 mah (13 600 mah x 3,3 V = ~ 45 Wh) and the CPU has a max. TDP of 4 W. If we say, that the step down converter is around 90-95% efficiency (typical), then we are around 8-10 h gaming time wich is at least twice as high as the Nintendo Switch.
Video:
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
Thx, I've added the cost at the parts section (without the 3D-Printer its about 180$ if you buy it now). Parts like the tablet you can easily buy on sale for at least 20-30$ less. The batteries can be also much cheaper then 28 $ for 4 pcs.
