DIY Weber Grill Cart BBQ Station
24,905
230
22
Posted
Introduction: DIY Weber Grill Cart BBQ Station
This grill cart features a sturdy wooden base with an opening for a round charcoal grill, I used a Weber. The cart also has wheels so you can move it and a rack for pushing / holding tools. If you're looking for a better outdoor cooking experience, then this is perfect as it gives space for chopping, storing etc! Overall this is a great weekend project because it's pretty quick to put together, and if you're organized it can definitely be done in a couple of hours.
Step 1: Cleaning the Grill
The first thing I did was to clean the old grill. I sprayed it with water, scrubbed it with coarse steel wool and really focused on some rusty spots, and then I spray painted all those areas with some heat resistant black paint.
Then I took the grill apart, and removed the wheels - I'm going to be using those for the cart to make it movable.
Step 2: The Wood
Next up, the wood. I cut all the pieces to length on the miter saw, so they were all ready to assemble.
Step 3: Steel Pipes
OK, so I've got some steel pipes and connectors here. This is for a handle for pulling the cart and to work as a towel bar. Here I'm cleaning them up with some denatured alcohol before being spray painting, and I used an oil rubbed bronze color.
Step 4: The Top
Now, let's start putting this thing together! I started with assembling the top together. I put in two supporting pieces first underneath, and then put down the top pieces which I screwed down. Next I'm using a large compass, and I'm making a circle that is just a touch smaller than the grill's diameter. Then when I knew where the grill would come out to, I could mark and attach the last support piece. (watch the video for a clearer demonstration)
Step 5: The Legs
For the legs I'm putting together two 2x4s which I screw together. Two of the legs will be slightly shorter than the others to account for the wheels.
And here are the leg sections. I'm also going to add some support pieces in the middle, and then the wheels on the ends.
Step 6: The Wheels
Now before I left home, I drilled some very small holes in a steel rod, and the wheels will slide on the rod, and these cotter pins will make sure they stay in place. Then I drilled a hole in the two shorter legs for the rod to come through, and then I secured it with the pins.
Step 7: Cutting the Hole
OK, so time to cut out the hole for the grill with my jig saw.
I began with drilling a started hole, and then I followed along the marked circle with the jig saw.
Initially I had planned on putting in several screws in the wood to prevent direct contact with the wood. But after looking at it, I realized that the grill only touched a couple of areas, because the circle was not perfectly even, so I decided to skip that. There is no danger with this and if any scorching actually did occur it will be easy to add the small screws to decrease the contact.
Step 8: Bottom Shelf
I also decided to add some cap pieces on the ends to the cart to finish it off a bit.
On the underside I'm adding some cedar fence boards for a shelf, and this is where I picture you would store extra charcoal and things like that.
Step 9: Sanding
Next up - sanding, mostly on the top to make it nice and smooth.
Step 10: Finishing Touches
Now remember the cart handle I painted, well here I have it assembled and just screwing this bar in on the side of the cart. And you can hold on to this when moving the cart, or use it to hang tools or whatever. Lastly I put on a thick coat of spar polyurethane on the whole cart to protect it from the elements.
Step 11: Conclusion - Watch the Video
To get a look at the final result, and a much better idea of the process of the build, make sure to check out the video!
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    21 Comments
    how about putting in the dimensions of the BBQ station like height width etc.
    Hello, very nice job indeed ! Can you tell me the approx. weight of the whole cart ? In fact, I need to build a cart for moving my BBQ along a long climbing path round the house, for sure I will put 4 wheels but if I need to tow it with the car its not a godd idea :-) :-) Thanks again !
    It would have been nice to have a cut list for the wood!
    Yes , it would be nice to have a list of the cuts that were made.Can we get a list please? Thank you :-)
    This project is a wonderful idea!! I'm going try it. The one thing that I'd like to do is ,to make the table longer. I guess that I could make the table to the video's measurements ,and build a stationary table , and have the BBQ station attach together with the other when I want to BBQ? Any ideas or help with my idea anyone? Have a great day!! ?
    Great Ibble!! Hopefully will build next weekend!!
    Great instructable thank you. I wonder if you've used it yet and if you found any scorching? I like your idea of inserting screws to hold the bowl off the wood. Simple but effective!
    Good idea with the screws - you could easily add a few washers to work as spacers, to give an extra air gap - right where your jig saw cut went outside the lines.... :)
    Very good work ! You have the dimension to do mine?
    Nice Idea but any safety concerns? Wood in direct contact with the Weber. Maybe create an air gap between the grill and the table top and suspend the grill in a fire safe way.
