Diy Lab Power Supply
1,257
30
12
Posted
Introduction: Diy Lab Power Supply
this is lab bench power supply
i use atx power supply as main componet
Step 1: Component You Need
  • atx power supply(i use 450w)
  • banana connectors
  • switch
  • leds
  • wires(use thickness as per current requirement)
  • wood
  • and some basic componet
Step 2: Make Wood Box
make wood box and connect screws cable clamp
Step 3: Connect Atx Power Supply
put atx power supply in wood box and connect wire to screws cable clamp
the wire connect according to pin map
Step 4: Diagram of Power Supply
connect all think together as per diagram
and connect all think together on front panel
Step 5: Make Variable Output
  • now make variable output for variable output i use dc-dc converter with variable voltage and current limit .
  • it can output 1.3v to 27v and 3A max
  • connect all componet as per diagram
dc- dc converterhttps://www.aliexpress.com/item/DC-DC-Step-Up-Down...
Step 6: Done
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
8 Comments
why 4 potentiometers instate of 2 ??
i use 2 pot for voltage and 2 pot for current that give me small change in voltage and current value
you forgot to add a load resistor for stabilization...
no without load resistor it gives me proper out put but now i connect load resistor for safety
Oh yea, those old ATX power supplies had some pretty stout current capabilities. And they would make a really nice shop power supply. Thumbs Up!
good project thank u for suggestions
