Doomsday Axes
1,492
10
8
Published
Introduction: Doomsday Axes
This is a fun project I started after a random trip to the local hardware store. These are ridiculous by inherent design, and not intended to be used for anything other than conversation pieces or dank memes.
PLEASE NOTE, I am only including the instructions on how to make the Doomsday Ax heads in this Instructable. I will be making another Instructable in the near future focusing on making just the handles.
Step 1: Disclaimer!
While these are intended to be props, they are still fairly sharp and should be treated with the same respect as a real live ax or hatchet. Use is not recommended as the steel in a saw blade is fairly hard and you may break off blade teeth, with some risk of injury from flying metal shards.
The tools to be used also have certain risks inherent to their design. Please make sure your tools are in good condition, and that you have the required experience and safety equipment needed to use them properly.
Step 2: Safety Equipment
Leather Gloves
Welder's Mask
N95 Particulate Mask, 3M style is the best, IMO, but disposables will work
Apron, either leather or some Flame Resistant material
Heavy Cotton Shirt or Welders Jacket
Hearing Protection
Safety Glasses
Face Shield
Pants
Boots
Step 3: Tools Required
MIG or TIG Welder, 120v or greater
Angle Grinder With cutoff wheels and regular grinding disks
Steel File
Vice (Not absolutely required, but really nice if you have one)
Wire Brush
Ball Peen Hammer
Straight Edge
Marker
Pliars
Step 4: Materials Required
1 10 inch (or larger) circular saw blade
1 3/16 inch X 3/4 inch X 48 inch bar of mild steel
1 2 inch OD steel pipe, 6 inch piece will work from the hardware store. Make sure it is not galvanized or cast iron.
The exact dimensions are not that critical, as you will be eyeballing most of this anyway. The only major thing is don't get a blade under 10 inches in diameter, or it will look really small.
Step 5: Step 1: Splitting the Blade
Using the straight edge, mark a line down the center of the blade. I used the expansion gaps provided on my blade as helpful guides. The important thing is to not split a tooth. Make sure your cut goes between the teeth.
Step 6: Step 2: Notching the Blade Relief
Trace a section of the blade to cut out. This notch only serves to help up the "cool" factor of the finished ax, so exact placement and shape of the cut out is up to you. Don't go to close to the teeth, or you may have bending issues later on.
Once you are satisfied with your design, clamp the blade half into the vice and cut it out. Use the steel file to carefully de-burr the cut edge.
Step 7: Step 3: Symmetry
If you want both axes to look the same, use the half you just cut as a template to trace onto the other.
CAUTION! Make sure you flip the other half over so that the teeth are facing the same way. Otherwise, one ax will look awkward. And that my friends, will not do when the hordes of the undead are storming your house.
Once you finish tracing the notch onto the second half, repeat step 2. Don't forget to de-burr the cut edge when you are done.
Feel free at this time to use the steel file to get the cut edges to match as closely as possible.
Step 8: Step 4: the Handle Tops
If you look at the little diagram I made, you can see about what we are planning on doing. The red lines are the cut lines. The easiest way to cut this, is to clamp the pipe into the vice, use the marker to mark your cuts, and cut your way towards the vice. The angle is optional, if you don't feel like cutting it, feel free to make it straight.
Once you have cut these two pieces, make sure you de-burr them. If you want, you can also use the file to clean up your angles a bit.
Once they are nice and clean, either crush them a little bit in the vise, or use the hammer to flatten them a little. Not too much, just enough to make them oval as you see in the third picture.
Step 9: Step 5: Tack Welding
Alright! You made it this far, hopefully with all your fingers! Now comes the fun part; starting to put this together.
I used the file to make a little centering notch in the tube end, just to make it a little easier. Don't go crazy laying down metal at this stage.
The saw blade is really thin, and may warp as you tack it, just use the pliers to carefully bend it back into place, and make sure that it is straight with the tube as shown in the little diagram. Also, it is really easy to burn right through the blade, so don't rush this part.
Step 10: Step 6 Symmetry
Get them as close to the same as possible...
Step 11: Step 7 the Support Bars
The exact length of these will be determined by the shape and size of your notch, and the angle you tacked the blade to the tube. Mine were 6 3/4 inches long, but your required length may be different. Simple place the bar against your ax head, like in the first image, and decide how you want it to look, mark the length, and cut 4 bars the same length.
You will then bend the bars to look like in image 2, the bars are red. Mild steel bends very easily, and you should be able to bend it in your vice. Try to get all 4 bars looking the same.
Step 12: Step 8: More Welding
Weld the bars you just bent in the previous step to flat sides of the tube. Again, don't feel like you have to tow the Titanic off the bottom of the sea with this weld, you may still need to do a little bending to keep everything straight after you get it tacked into place initially.
Step 13: Step 9: Welding Continued
Once you are satisfied with the placement of the support bars, weld the free ends to the blade. Again, be careful with the thin steel of the blade. I accidentally got it a little too hot and had to do some repair work.
Step 14: Step 10: Additional Support
When we are knee deep in zombies, the last thing we want to worry about is the strength of our homemade junkyard weapons.
To that end, I added supports to the original tack weld. These pieces are just straight sections of metal left over from the first set of supports. There are four of them, about 2 inches long. At this time, add any additional welds you feel are needed to keep this together.
Step 15: Step 11: Clean Up
My welds got a little gross looking, due to being unfamiliar with welding thin metal and a mysterious fault in the gas flow of my MIG gun. So I became a grinder for a few minutes and cleaned up my welds a little.
If you are an amazing welder, you may not have to clean up at all.
I chose to leave the metal raw, but you may choose to paint it. At this point, you're all done! I hope you had fun!
    • Make it Move Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    8 Comments
    Like the man said. Although honestly, these aren't sweet. They're sour, because they're made of steel, not gingerbread.
    Gingerbread axes...dang, I'm a genius!!
    Nice build, anyway!
    So steel isn't sweet? I mean, it don't taste great, but it ain't sour.
    Just sayin.
    Na, you're right. It doesn't really taste like anything...except the tears of small children and grapes.
    looks great, why not just a few feet of pipe for a handle though? saving this for if/when I get a welder :)
    Glad you like it!
    The main reason I did not extend the pipe farther to be used as a handle, is because these ax heads are very light, and I thought it would feel wierd to have a handle heavy axe.
    That is about what I would expect to see in a doomsday apocalypse.
