Doughnut Chuck
17,338
104
19
Posted
Introduction: Doughnut Chuck
A Doughnut Chuck is a great jig to hold turned bowls on a lathe. It grants access to flatten and finish the bottom of any bowl. This simple chuck can be made in an afternoon and can be customized to fit any lathe and bowl.
Step 1: Tools and Materials
Tools:
Materials
Step 2: Hardwood Tennon
Glue two pieces of hardwood together to make a blank that will hold the doughnut chuck on a face plate or nova chuck.
Mark the center of the hardwood. Cut the corners off using a bandsaw and mount it between centers.
Step 3: Turn Tenon
Turn the block round and create a tenon on one end (if using a face plate just turn flat). Remove from the centers and mount in the chuck. Turn the face of the block flat. Verify with a straight edge.
Step 4: Cut Circles
My lathe has 6 inches of clearance between the headstock and the bed. Because of this, I cut the radius of my circles a half an inch shorter to ensure that the two disks spun clear of the bed. Cut out the circles with a bandsaw or jig saw.
Step 5: Glue and Turn Circles
I used regular wood glue to attach the circles to the hardwood. Use the tailstock of the lathe to clamp the circles in place. Once the glue is dry, turn the circles round.
Step 6: Drill Holes
Mark a line around the face of the disc a half inch in from the edge. Drill four 1/4 inch holes around the edge along the line previously marked.
Step 7: Insert T-Nuts
Drill a hole from the back side the size of the t-nut. Tap the t-nut in place. Mark index numbers on the face plate.
Step 8: Mark and Part Inner Ring
Measure the size of bowl you want to hold in the chuck. My bowl needed a chuck with a 7 inch diameter hole. Mark the hole and use a parting tool to remove the circle.
Step 9: Install Foam Lining
Multiply the inner diameter of the ring with pi (3.14). This will give you the needed circumference of the foam lining. Add two inches because the foam will compress and cut to length. Open the split side and place it over the inner circle. This will give padding when holding the bowls in place.
Step 10: Finish the Bottom of the Bowl
Attach the loose ring with bolts and washers. To place a bowl in the doughnut chuck, loosen all bolts (removing one) and slide a bowl in from the side. Tighten all bolts equally (I use a socket in my drill for quick changes). Now go flatten and finish the bottom of any bowl.
This doughnut chuck took inspiration from two great videos by Peter Brown and Gord Rock. Go check out their projects for other great ideas to implement on the lathe.
  • Put in $15 and some ...-HenrikM13
    HenrikM13 made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
15 Comments
I have a set of Cole jaws. Depending on the shape of the bowl, they are not always very secure. It can be a problem when the sides of the bowl are close to vertical close to the rim. This looks like a nice alternative. With turning it's not either/or, but more options is always better.
Sometimes you find an idea so simple that you wonder why you didn't think of it... this is one of those ideas!
Outstanding!
Is that blue bowl made of wood or is it just a bowl you put in the chuck to show how it works for the instructable?
Thanks XTL, but you're a little late to the party. That instructable wasn't up yet when I asked that question.
That is actually a bowl made from half a bowling ball. That instructable should be out sometime over the next few days.
Years ago, I wanted to drill and tap a hole in a billiard ball, but didn't know how. Thanks to you and the other two gentlemen you referenced to. Now I'm too old for the job I was after.
Best regards
good idea but very limited to size bowl you can finish with it.
In your link for the nova chuck there is this 'NOVA 6006 Mini Cole Chuck Accessory Jaw Set'
https://www.amazon.com/NOVA-6006-Mini-Chuck-Access...
the soft grip wedge pieces could be screwed onto your wooden face plate then have several rows of threaded holes for different sizes like the cole jaws, you could even make then out of soft wood.
What is the material the blue bowl is made from, looks interesting?
