Drill Press Dust Collection
905
19
5
Posted in WorkshopTools
Introduction: Drill Press Dust Collection
About: 15 year old woodworker and maker
Welcome to my first instructable!
This will show you how to make a holder for a a drill press to hold a dust extractor. I have included some 1 to one templates to cut out and use but you will need to mark your own hole for the column of your drill press as these seem to vary in size a bit. Also make sure that your dust extraction / vacuum hose fits in the hole I have marked as although this seems standard for the hoses I have it could vary slightly for you.
You will need:
Attached templates
Plywood
45mm drill bit
6mm drill bit
2x 50mm screw
Jigsaw or coping saw
Belt / disk sander
100mm nail
small bolt
Step 1: Glue on Templates and Dill Out Hose Hole
Print out the templates I have made and stick them on some wood. i used some scrap plywood but use what you have available. After sticking on the templates drill out the hole marked with a 45mm hole saw or forstner bit.
Step 2: Cut Out and Sand
Using a jigsaw or coping saw cut out both templates then sand them to the line using a sander or with a bit more work by hand
Step 3: Measure Your Drill Press Column and Cut Hole
Measure the size of your drill press column and mark this on the 2nd piece of wood using the center line to help you drill this out then mark half way though this hole and drill two pilot holes to this line. Once the piece is cut in half you can continue these holes using a slightly smaller bit into what would be the bottom half.
Step 4: Cut Piece in Half and Sand to Fit
Cut the piece that goes around you drill in half so that it can be fitted around the column. You may have to sand some material away from the end to make it fit around the drill properly. screw both half's together around the column to check they clamp together nicely.
Step 5: Mark Hole Locations and Epoxy in Nail
To make it so these pieces are adjustable use a 100mm nail with the head chopped off. Drill a hole into the piece that holds the hose and epoxy the point end of nail into it.
Step 6: Make Locking System
In the piece that mounts to the drill press drill a hole like you did in the other piece but also drill a hole through the top to have a small bolt threaded in to make it possible to adjust the hose and clamp it in different positions.
Step 7: Install on Drill Press
Clamp the pieces together and onto the column of the drill. Install the hose and you're ready to go. Although this isn't 100% effective it helps greatly to cut down on the amount of dust and shavings that end up on the floor especially when using forstner bits.
Step 8: Update / New Clamp Design
After using this for a bit the threads in the wood stripped out so I cut a slot through the side and added a new bolt with nut that goes all the way through clamping the nail in the wood more tightly.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    5 Comments
    Definitely making one of these. Thanks for sharing!
    Thanks for the comment. Be sure to show me your finished one!
    Thanks. With a bit of modification I'm sure this would be great on any tool.
