Easy Build Grill Cart - DIY Guy
Introduction: Easy Build Grill Cart - DIY Guy
This week, we built a fast, easy, grill cart for the back deck.
The best part is, we built it using inexpensive, preassembled crates from Lowe's.
Also, we grilled burgers afterward, which is always good.
Step 1: Watch the Video
This video gives an in-depth, step-by-step description of our build.
Anything you don't find here in the Instructable, you'll find in the video.
Step 2: Gather Your Materials
You'll need the following:
(3) Wooden Crates
(1) 2-1/2"x 3-1/4" Pine Board
A board for the top (your choice ... pick something pretty)
(4) Casters
Minwax Polyshades Stain (Mission Oak)
Miter Saw
Jig Saw
Table Saw (or have Lowe's cut your top for you)
Kreg Pocket Hole Jig
Some clamps are handy too.
Step 3: Cut a Bunch of Blocks
Cut your pine board down to 3-1/2 inch blocks.
If you want to put a top on your cart like we did, you'll need 12 of these blocks
Step 4: Prepare the Blocks
Drill two pilot holes in each block.
Set aside 4 blocks. These blocks will go on the top crate, and attach to the top.
For these 4, you'll also need to drill a pocket hole in the center.
That way, when you attach the top to the cart, the screws are hidden.
Step 5: Attach the Blocks to the Crates
Glue and screw one in each corner.
Do this for all three crates.
Remember to put all the blocks with the pocket holes on the same crate.
Step 6: Cut Some More Pine
Cut the rest of your pine board into two strips, 11-3/4" long.
Go ahead and mount these to the bottom crate with screws and glue.
This is what we'll use to attach the wheels for the cart.
Step 7: Cut Out Some Slats
Measure 1-1/5" in from the sides of your crates, and cut out the top three slats on one side with a jig saw.
Step 8: Cut Out a Top
We cut a board down to 15" x 20" for our top.
Step 9: Stain Everything
There are a bunch of options for stain, but we used a simple spray-on stain with included protective finish.
Make sure to completely and evenly cover all surfaces.
Step 10: Attach the Wheels
Drill holes for your wheels on the bottom crate. We used locking casters, but you can use whatever strikes your fancy.
Secure those suckers with locking nuts.
Make sure if you have locking wheels, you mount them both on the same side of the crate, otherwise they won't work.
Step 11: Put Them All Together
Stack your crates and line them up.
The crate with the wheels goes on the bottom (obviously)...
and the crate with the pocket holes goes on the top.
Fasten these together with screws through the blocks we attached earlier. (Pre-drilled pilot holes help)
Step 12: Attach the Top
Screw it on using the pocket holes you drilled earlier, and you're done.
Step 13: Bask in the Glow of Your Own Handiness
Just look at that thing, classing up your deck like a champ. Even E-dub, the DIY Dog loves it!
Step 14: Subscribe
If you found this Instructable helpful, we'd love it if you subscribed here, as well as over at our new DIY Guy YouTube Channel.
Link to DIY Guy on YouTube
We'll release new episodes every Wednesday morning, as well as extra stuff throughout the week. And remember to turn on notifications at YouTube so you'll know each time we upload a new video. Thanks again!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
