Electric Pickle Lamp
20,789
20
21
Published
Introduction: Electric Pickle Lamp
About: Married to Domestic_Engineer (but I call her Meghan).
Plug a pickle into a 120V AC outlet and watch in glow.
Materials:
  • Pickle
  • AC power cord
  • Thick copper wire
Procedure:
  1. Cut and strip the power cord.  Wrap together the neutral and ground wires.  Cut the live wire about 6 inches shorter than the neutral/ground.  This will reduce accidental shorts.
  2. Cut 2 pieces of thick copper wire, about 3 inches long  I used a piece pulled from a household electrical wire (the kind that go in the wall)
  3. Stick the wires in the pickle
  4. Connect the AC power cord to the copper wires.  I've used a cheap set of jumper cables between the power cord and the pickle.
  5. Plug the the power cord into an electrical outlet.
  6. Wait for the pickle to glow.  It took about 10 seconds to get going.
  7. Unplug everything.
  8. Be careful -- safety eighth!
Science:
The sodium in the pickle burns yellow.  Yellow street lights are sodium-vapor lamps.
Video 1:
Video 2
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Oil Contest
      Oil Contest
    21 Comments
    It will work on 110V? I thought it needed more than that.
    Yup - This is from a regular 110V household outlet (North America) - on a 15amp fuse.
    On 240 volts??
    It might blow up with 240. Safety glasses, yo.
    I don't see why not -- careful though. My only 240V circuit is behind the dryer. Did not work with a 12V car battery.
    I am doing it for my science fair project. HAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHA
    Works fine on 240v, 50cyc. in New Zealand.
    Does it work on a cucumber or a tomato?
    nice lamp.
    I wouldn't eat it. There's likely to be metal from the wires /nails dissolved in it, and possibly even a bit of metalic sodium (toxic)
    One of those chem ironies that sodium ions in salt is a necessity for life, but metallic sodium is toxic. I don't really know if the current will separate sodium.
    Is said pickle still edible after the experiment?
    Sure - but it is a little cooked.
    We do this all the time in physics, because we can.
    This is a really cool project. On an unrelated note, I just thought of an awesome band name.
    Wow!!! Itz cool!!!!
    Nice work!!!!!!
    Shocking!
    You can cook a hot dog that way too.
    love it! So will this work with anything that is saturated with salt?
