Enterprise View Screen LED Scroll
895
10
Published
Introduction: Enterprise View Screen LED Scroll
This tutorial will show you how reproduce the scrolling LED effect from this scene from Star Trek: The Next Generation with the ArduinoUNO, and assumes basic familiarity with the Arduino system.
The viewing screen from the bridge of the Enterprise features a scrolling LED effect just beneath and in the center:
Step 1: What You'll Need:
In the picture:
1 generic brand ArduinoUNO circuit board and connecting USB cable
1 solder-less breadboard
1 extra long solder-less wire
Use more or fewer or these in equal measure :
10 solder-less wires
10 white LEDs, 1.8-2.2v, 20mA forward current
10 resistors, 150ohms
Step 2: Circuit Configuration
The negative leg of the LED is inserted in the negative rail of the breadboard, the positive leg is inserted inline of the negative leg on the central portion of board with a 150ohm resistor and one end of a solder-less wire.
Step 3: Repeat
Repeat the configuration for as many LEDs as you require.
Step 4: Connecting to ArduinoUNO
Identify the input/output pins on the ArduinoUNO circuit board. Connect the other ends of the solder-less wires in the same order, starting at pin 2. The first two pins, 0 and 1, are unavailable for the type of connections we're making without extra steps.
Step 5: Completing the Circuit
Locate the GND pin in line with the other output/input pins. This is the ground for completing the circuit. Connect the extra long solder-less wire at the GND pin and to the negative rail of the breadboard. In the configuration shown, I accidentally left no room for the ground wire toward the center of the board, so I crossed to the end of the breadboard so as not to interrupt the continuity of the LED effect.
Step 6: Coding
The Arduino programming software includes an example program called Blink. Starting with this code as a template, I named the LEDs led1-led10 as constant variables and assigned them to the input/output pins.
Set each pin to output.
The basic concept for the effect is that the two LEDs in the center of the line:
5 and 6, will turn on, then off, then
4 and 7 will turn on, then off, then
3 and 8 will turn on, then off, then
2 and 9 will turn on, then off, then
1 and 10 will turn on, then off.
Between each pair of LEDs turning on and off, there is a timed delay. After playing with the values using the find and replace feature of the coding software, I selected 200 as the duration that matched the sample clip most closely.
const int led1 = 2;
const int led2 = 3;
const int led3 = 4;
const int led4 = 5;
const int led5 = 6;
const int led6 = 7;
const int led7 = 8;
const int led8 = 9;
const int led9 = 10;
const int led10 = 11;
void setup() {
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
pinMode(led4, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(led7, OUTPUT);
pinMode(led8, OUTPUT);
pinMode(led9, OUTPUT);
pinMode(led10, OUTPUT); }
void loop() {
digitalWrite(led5, HIGH);
digitalWrite(led6, HIGH);
delay(200);
digitalWrite(led5, LOW);
digitalWrite(led6, LOW);
digitalWrite(led4, HIGH);
digitalWrite(led7, HIGH);
delay(200);
digitalWrite(led4, LOW);
digitalWrite(led7, LOW);
digitalWrite(led3, HIGH);
digitalWrite(led8, HIGH);
delay(200);
digitalWrite(led3, LOW);
digitalWrite(led8, LOW);
digitalWrite(led2, HIGH);
digitalWrite(led9, HIGH);
delay(200);
digitalWrite(led2, LOW);
digitalWrite(led9, LOW);
digitalWrite(led1, HIGH);
digitalWrite(led10, HIGH);
delay(200);
digitalWrite(led1, LOW);
digitalWrite(led10, LOW);
Step 7: Launch Code
Connect the ArduinoUNO circuit board to a computer with the USB cable. Make sure that the correct port is selected to upload the code to the hardware.
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    2 Comments
    honestly i think it the the IMGUR gif maker website, I havent been able to embed gifs in my other instructables...i dont remember how i did this one
