Glow Table
3,411,782
7,040
515
Published
Introduction: Glow Table
About: I'm Mike and I make crazy things at Instructables HQ in San Francisco. Follow me and try a few of my projects for yourself!
Really light up your next dinner party with a table that glows in the dark!
Photoluminescent (glow) powder mixed with clear casting resin fills the naturally formed voids in Pecky Cypress hardwood, creating a unique and stunning table. The glow powder charges up in sunlight and emits a cool blue glow when in partial or complete darkness.
Placing this table near a window will allow it to collect rays from the setting sun and then set off a pleasant glow from the transition from twilight to evening. Making your own is fun as you can customize it in any way you want. Instead of using hardwood you can use the technique of adding glow powder to resin to cast in all kinds of fun ways.
Let's make!
Step 1: Materials
The type of wood I used for this table is known as 'pecky cypress', which is regular cypress that has been naturally damaged with a fungal growth inside causing sections to rot - wiki on taxadium distichum (cypress).
These damaged pockets can be easily removed and create cavities in the wood which are perfect for filling with resin and glow powder. The pockets of damaged (rotten) cypress are soft and can easily be removed with compressed air and some light digging with a hand tool.
Aside from Pecky Cypress, we'll need:
Step 2: Mill Wood
The wood comes from the mill to the store in rough shape, it's up to you as the consume to decide how you want the product to look. In North America most board lumber is sold in board feet.
Knowing I was going to make a table top by joining a few boards, I grabbed a few lengths of the Pecky Cypress and used a jointer to square the edges of both sides of the board. These clean edges will make a great surface to bond the planks together.
Step 3: Cut Planks to Size
With the board edges finished I could cut the boards to the correct length.
After marking each board to the desired finished length I cut them down to size with a sled on the table saw.
Step 4: Join Planks to Make a Board
Using a plate joiner (biscuit cutter) I cut indents into the boards, then I glued in biscuits and clamped the boards together. To ensure the boards stayed even while being clamped I used a few scraps of straight wood on the top and bottom of the boards.
I let the glue dry overnight.
Step 5: Dig Out Fungus Rot
The damaged pockets of wood in Pecky Cypress can be easily removed by gently digging with small tools to clean out the cavities.
Starting with a vacuum I gently pushed a flat-headed screwdriver into each rotted cavity to dislodge the rot and remove it. After, I used compressed air to blast out any remaining debris and ensure the cavity was clear of detritus.
This can get very messy and dusty, so wear proper safety equipment.
Step 6: Sand Surface
After the glue has dried I sanded down the surface with a course 80 grit sandpaper on a random orbital sander. This cleaned up the transition between the glued boards. After, I brushed the surface clean to remove any dust. We'll need a super clean surface before we can move on to casting with resin.
Step 7: Mask and Prepare Board for Resin
Before casting resin we need to ensure the table will be able to retain the medium. Since some of the cavities in the boards go all the through the entire underside was taped off, that way any resin that goes to the bottom will pool and not leak out.
To keep the resin from oozing out the ends I put scrap strips of thick acrylic along both ends. I didn't worry about the sides, as these boards didn't have any open cavities along the sides. The acrylic scraps were clamped into place and a short border of masking tape was put along the sides, just in case any resin migrated.
Step 8: Resin and Glow Powder
I used clear casting resin, which is a 1:1 ratio type - meaning you don't need to measure out specific amount of catalyst, just equal parts resin and catalyst. I prefer this method as I'm not very careful and have mixed up the mix ratio before. This resin is super easy to use and begins to set in about 7 minutes.
There's plenty of glow in the dark powder colours available, I chose blue glow in the dark powder which I got online. I'd recommend using more glow powder than less, as the effect is much more striking.
For my 41"x22" table I used 64 oz (2 liters) of casting resin and about 3.5 ounces (100 g) of glow powder. Yours measurements will probably vary.
Step 9: Prepare Resin
To mix my resin I used large unwaxed paper cups. Pour equal portions of resin and catalyst into separate cups, ensuring to fill cups less than halfway full. Pour a portion of glow powder into either cup and mix thoroughly.
Know that when you combine the two liquids of the resin the chemical reaction will start, allowing you only about 5-7 minutes of working time before the resin sets.
When you're ready add the catalyst to the resin and briskly stir until the two liquids are one homogeneous mixture. Ensure to scrape the stir stick, and the sides and bottom of the cup. Pour the stirred mixture into the catalyst cup and continue stirring. The entire mixing process should take less than 2 minutes to ensure you have enough time to pour the resin without it setting.
Step 10: Pour Resin
With your resin mixed it can be poured into the cavities of the Pecky Cypress. Since the resin is not viscous enough to suspend the glow in the powder I had to take quick breaks from pouring to stir the mixture to ensure even glow powder distribution.
Gently pour the glow resin into all wood cavities. You may find that the resin gets absorbed into the wood, or that some cavities are slower to fill, this is normal. You can apply another layer of resin over previously poured sections.
I poured in smaller measures, about 10 pours in all. This process took about an hour to complete. I let the resin cure completely overnight.
Step 11: Let Resin Cure, Then Reveal
After allowing the resin to cure completely overnight the acrylic edges and masking tape can be removed.
The resin won't stick to the acrylic, allowing it to be easily peeled from the ends. The masking tape was a little more tricky, but can be easily removed with a little patience.
Step 12: Preliminary Glow Test
Eager to test out the results I took the cast resin table top outside and let it soak in some sunshine for about 5 minutes, then quickly took it inside an enclosed area and turn off the lights. The effect was incredible!
Picture 1 shows the table with the additional resin spill over in complete darkness. There is no photo trickery here, this picture is exactly as it appeared when the lights were off. If anything, the effect in person was more vibrant.
Picture 2 shows the same table top with the door slightly ajar, allowing some natural light to enter into the room. Here you can see the resin spill over next to the vibrant blue and grain of the wood.
Step 13: Clean Up Edges
Along the edges where the resin touched the acrylic or masking tape were small sections of raised resin due to capillary action. Even though the edges are going to be routed smooth, removing these raised edges now makes the sanding process easier. I used a sharp knife to cut away the raised edges.
Step 14: Rough Sanding
I have access to a 25" drum sander. This sander has a very rough grit and is great at plowing through large flat pieces like table tops. However, this machine is totally not required and you can work the table top to a smooth finish by just using a power sander.
I fed this table top through multiple times, each time raising the bed a small amount until the entire surface was level.
Step 15: After a Few Passes
After a few passes through the drum sander the table surface has been leveled and the resin spill over high spots are removed. Now we need to bring the resin surface back to a high gloss, and smooth out the wood surface.
Step 16: Finish Sanding
Using a random orbital sander I sanded from rough grit all the way up to 400 grit.
Since the drum sander I used had a 80 grit sandpaper, I started at 120 grit then stepped up progressively until I was at 400. Spending enough time with each grit of sandpaper to ensure a uniform finish.
Step 17: Fence for Routing
After the surface was sanded I could turn my attention to the edges. Though my router bit had an end bearing to keep distance from the table edge, the holey nature of Pecky Cypress made uniform distance on the edge impossible with an end bearing, meaning the blade of the router would occasional dig into the table more where there was a cavity on the table edge. To solve this I made a fence for the router.
With the rounderover bit installed in the router I measured the distance from the edge of the end bearing to the edge of the router base, this distance would be the setback for the fence. I clamped a straight edge fence at this setback perpendicular to the edge of the table sides.
Step 18: Routing Edges
With the fence installed I could run the router over the table edges to make a nice rounded edge.
Step 19: Polyurethane Finish
After routing and sanding I could finally apply a durable glossy polyurethane finish. In a well ventilated area I applied a coat with a foam brush and allowed it to dry completely.
Step 20: Wet Sand
To achieve a high-gloss finish I wet sanded in between coats of polyurethane. Once one coat was completely dry I sprayed the surface lightly with water, then used a 1200 grit sandpaper to smooth out any brush strokes from the previous coat of polyurethane.
The surface was then cleaned and dried completely before applying another coat of polyurethane. This process was repeated several time to achieve a very high gloss finish.
Step 21: Paint Leg Anchor Plate
With the top finished I could turn my attention to the base. I used retro hairpin table legs for my table (the ones in the link were cheaper to buy with a table top than just the legs). These legs bolt into the table bottom. Since this table design is different than the one the legs were designed for I had to make a new way to anchor them to the table.
To hide the leg attachment and really keep the focus on the glowing table top I decided to paint the leg anchor plate flat black.
Step 22: Transfer Anchor Openings
Once the paint on the leg anchors was dry I placed the anchor plates on the underside of the table and transferred the opening location to the table. An opening was drilled at the marks, ensuring to only drill as deep as the anchor nuts.
Step 23: Add Anchor Nuts + Plate
The anchor nuts were installed in the openings, then the anchor plate was installed over the anchor nuts. Since the Pecky Cypress had irregular cavities some minor tweaks were needed to ensure the bolts and anchor plates had sufficient coverage on the underside of the table.
I used E-6000 Industrial Strength Adhesive which bonds almost anything to anything else permanently. This stuff is nasty, but magic.
Step 24: Attach Legs
When the adhesive has dried completely the hairpin legs can be installed. Align the legs and screw in the anchor bolts to secure the legs to the underside of the table.
Step 25: Place Your Table + Glow!
Your table is all set to glow the night away. This glow powder needs UV light in order to activate, so dusk is a great time to enjoy the transition.
This table has a really neat effect, and looks great even in twilight. Depending on how much UV exposure your table has it can glow for up to 20 minutes.
25 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
  • Oil Contest
    Oil Contest
I’ve looked everywhere and I can’t find any pecky wood anywhere
1 Questions
Hey
Can u advise if this would work if i routed a design into 25mm MDF
Thanks
Glen
Yes, that will work! Check in the comments below, there's someone who did just that :)
Good luck!
515 Comments
Hey Mike, I'm pretty new to woodworking but this looks like a great project to have some fun with. I'm intending to use this on a frame. My question is, will the finished product glow inside with the glow powder? I see a lot of people talking about the powder needing to be charged with UV light, and their tables being outdoors which is where my question comes from. If not, is there a solution to this problem?
Thanks!
Like every glow in the dark product, the glow powder will need to be charged in order to glow when the lights are out. Sunlight is excellent, but some incandescent bulbs also work. Good luck, I'd love to see pictures!
Can I use some plastic roll, instead of masking tape and acrylic?
Stupendo ♡♡♡♡♡♡
Hi Mike,Great work
Just curious will it stand up to extreme weather! As i carve tiki masks and would like to use this technique and materials for some of my outdoor projects
Thanks Dale
Thanks for the awesome instructions Mike. Would this still work if I were to put a coat of stain and use an oil-based poly over the resin?
since no one has jumped in on this here's my two cents. Stain the wood before you add the resin in moderate coats, don't let too much go down in the cavities. If using oil based products allow plenty of time for the stain in particular to dry completely, I'm talking days at a time as oil based stains are very slow to properly dry and cure. Then add the resin followed by the poly top coats. Since I've become lazy and impatient I don't use oil based products unless I have to. My stain of choice is aniline dyed shellac followed by several coats of white shellac, light sanding with 340 or 440 grit to remove any nibs and two to four light coats of paste wax hand buffed in between. The heck with all that sanding, waste of time. A buttery smooth satin finish without all the work, you're done in a day and next to no cure time as opposed to up to three weeks for lacquer.
Excellent Instructable man! Gave me some ideas for resin/glow powder projects. Thanks!
Ideas:
If you have deep holes, fill partway with resin or wood putty first. This way the glow powder is near the top.
You may be able to get UV powder. This glows when struck by UV light. This will provide a stronger, more continuous glow. All you need is a blacklight flood light over the table. This will be all the better because it won't glow where shaded from the light. Put a mobile in the path of the light, and you will have these shadows oozing about the table, with no apparent cause.
Where do you buy pecky wood?
I put these ideas out here for everyone to enjoy, and modify to suit their own needs!
I think this project has been remixed so many times that it would be difficult to pin down the origin of any one source of inspiration :) Share the knowledge, and the DIY love
I just LOVE it! Although you have some super woodworking gear (I'm just jealous ^^ ), I'm sure it's possible with a cheapo router, and a sander of equal quality. The glow powder is only visible the night, I suppose, when it's been in the light (like those fluo stars that stick on walls?), so it's a beautiful surprise when the night comes. And if you can't or don't want naturelly fungus eaten wood, you can engrave/sculpt designs in the wood. It's such a super idea for a table, thank you so much. When I can make one (time's in short supply for now), I'll post a picture. So nice this :D
Truly a magnificent work of art.!!
Hi Mike,
Really, really love the table. I'm going to try something similar and have been conducting tests using the glow powder and resin linked in your article. However, I can't get anything that matches the glow intensity of yours. I've been testing the ratio of resin to glow powder using your ratio in addition to one with increasing glow powder, in addition to the depth of the void that is being filled. I'm wondering how deep your voids are and whether that's the variable I'm missing? I'm also wondering how opaque yours are during daylight? I'm guessing that the glow powder concentration can actually get too high, making the resin too opaque and therefore limiting the amount, or depth, of light that can get in and out.
Also, I was theorising how I could increase the glow and wondered whether you'd experimented with mirrors? Given the glow resin will emit light in all directions when excited, less then 50% of the emitted light will be visible as the rest will go into the walls and floor of the void. If broken parts of a mirror were lined on the floor of the void, it would reflect this lost light back out to the viewer. I will try it with some broken mirror shards, but wondered whether you had first.
Any suggestions would be appreciated.
Cheers,
P
Glow strength is determined by how much powder you use in your medium, the medium itself (UV blockers can inhibit charging) and maybe most importantly, the chemical makeup/color of the glow powder. Strontium aluminate doped with europium (such as in V10 powder available on Amazon) is a brilliant green and much brighter even than the blue used here. V10 will visibly glow all night and can be used in industrial/safety applications. Purple or white glow powder, on the other hand, tends to be very mild and the glow mostly disappears in a few minutes. The old zinc sulfide glow powders (the stuff that glow-in-the-dark stars in the 80's were made with) are too dim to use for a project like this.
I think you're right to ask about whether you're wasting the glow powder at a certain depth. Most glow powders are fairly transparent at light concentrations but if you add enough to the medium it does quickly become opaque. You could make a light-concentration powder/epoxy mix and fill the whole cavity, or you could make a higher-concentration mix but only use it in the top, say, 1/4". But if you fill a 2" tall cavity with highly-concentrated medium you're probably wasting money (and potentially a lot of it, since good glow powder is expensive).
The glow powder is heavier than what the resin can support, so it will sink to the bottom of the voids. A great trick is to do multiple pours, one to fill the voids most of the way with resin and another after the first is hardened with the glow powder so it's closer to the surface. My table voids are opaque during daylight hours, it's a bone-white color.
I think you'd really have to be overdoing it to have too much glow powder in your resin, the ratios I show work just fine. Adding mirrors I think is unnecessary .
I'd love to see some of your results and it's great that you're doing test pieces before committing. Good luck!
This is georgeous!
Can you use this resin that I found on Amazon??? It's a little cheaper....
EPOXY RESIN CRYSTAL CLEAR 1 Gallon Kit. FOR SUPER GLOSS COATING AND TABLETOPS
