HOW TO MAKE a RAISED PLANTER BOX
23,057
290
12
Published
Introduction: HOW TO MAKE a RAISED PLANTER BOX
I have made a few planters, but this is by far my favorite one.
This could be made for interior or exterior. Since this was made for indoors I used pond liner and a plastic planter box. I used pine lumber, so I didn't want the lumber to have direct contact with the soil. For exterior use, my suggestion would be to use Cedar lumber, this is common for exterior planter box and it's ok to have direct contact with soil. Of course, any protection wouldn't hurt. Cedar is also known for repelling some insects.
Although the stand looks like metal, this is all made from wood. I used select pine and pine common board.
Here is a list of what I used in this project
  • For the stand, I use 2 by 2 select pine.
  • For the planter box, I used 1 by 10 pine common board
  • Stain Golden pecan https://amzn.to/2jlDlOY
  • Pond liner https://amzn.to/2jpj Tkk
  • Stain Brush https://amzn.to/2JP ZiAW
  • Wood Screw https://amzn.to/2rgsP f7
  • Wood Glue https://amzn.to/2JPyN vn
  • 5/16 wood dowel rodSee my Downloadable Plans>> https://gumroad.com /diycreators
    Let's dive into the build.
  • Step 1: Cutting and Assembling
    First thing, I cut all my lumber down the length I wanted. You can apply this concept to any size you'd like. I wanted a clean look so I mitered the corners of the planter box. You can also use butt joints if miter corners are challenging.
    With the cutting now behind me I can move on to assembling. I drilled pocket holes using the Kreg Jig in the bottom. I attached the long sides first, applying wood glue in the joint then secure it with pocket hole screws. Next, I attached the two short side, to close up the ends. Again, using wood glue at the connection points.
    Since pockets holes are only at the bottom, I used a band cla mp to close up and tightened the joints. Lets that sit until the glue set.
    Step 2: Making the Stand
    When it comes to making the stand I kept it simple! I used butt joints and drove a dowel rod through it.
    Making the Legs:
    First, line up the 2 by 2 lumber as shown, then clamp it. Next, drill a 5/16 hole through both lumber. Then add wood glue in between the joints. Drop a small amount in the hole, then cover the rod with glue. Now drive the dowel through both parts. When you can no longer drive the dowel in, use a flush cut saw to cut it off.
    Essentially you'll be creating two U's. Clam and let the glue set up.
    Building the stand.
    Now, locate the two legs. At this point, I can attach them using 2 by 2 lumber. I measure 4 inches down from the top, that's where I place them. I then glued and clamped this until the glue set. To finish this off I inserted the dowel rod into it drove it in.
    Step 3: Cutting the Shelf Slats
    At the bottom of the stand, I added a shelf. The shelf also played a key part of the design.
    To get the cleanest look I cut dados into the slats for the shelf. This allowed the two stretcher to be flushed.
    I found it easiest to clamp the individual piece then cut the dados at once. If you have a dado stack that will make quick work of this.
    Next, there will be two of these pieces that will be used for the ends. These two will be addressed differently. I notched out two section of the end pieces. These sections will be in line with the dado cuts previously. You can chisel this out or you can use a oscillating tool that would speed things up dramatically.
    The next thing I did was attach the shelf ends. I used the same method as the previous step. Placing the shelf 4in from the bottom. Also making sure the notched section is facing in and down. Glue, clamp and add a dowels.
    Step 4: Applying Finish
    After sanding down everything. I applied stain to the planter box and the slats. After applying two coats of finish, I applied one coat of wipe-on-poly .
    For the stand, I taped off the bottom shelf then applied a satin black paint. After the paint dried I removed the tape and stained the shelf.
    Step 5: The Finishing Touches
    Adding The Slats
    I attached the slats. Each piece space evenly and was secured with two screws from the bottom.
    Pond Liner
    Since this will be indoors I added a small piece pond liner just in case the plastic planter overflow.
    Planting
    I used giant Iris for the project, these will not hold up inside the home they need 6 hrs per day of sunlight to survive.
    Adding Rocks
    To top this off I used landscaping rocks, which is my go-to option for wrapping up a planter.
    Step 6: The Reveal
    Here is some closeup of the finished product.
    If you like this build stop by my most active social channels.
    Follow me on Instagram
    Subscribe to my YOUTUBE Channel and ring the bell to get notified when I post.
    See my Downloadable Plans >> https://gumroad.com/diycreators
    Woodworking Contest
    This is an entry in the
    Woodworking Contest
      • Woodworking Contest
        Woodworking Contest
      • Flowers Challenge
        Flowers Challenge
      12 Comments
      Excellent job there. Looks very professionally done.
      Clean and elegant look. Love it!
      Beauty! I thought the legs were metal too. I want.
      Fantastic! At first glance I thought the stand was metal, which would be equally cool. But I dig how accessible this is for most people to duplicate, and the results are excellent. Great work!
      Thank you, yes many had that same impression.
      This came beautifully with a clean look. I also appreciate the tip on using the oscillating tool. That will be a time saver. And as always with your Instructables are well documented.
