DIY: LEG EXTENSION EQUIPMENT
564
9
Posted in PlaySports
Introduction: DIY: LEG EXTENSION EQUIPMENT
About: I make a part time wood craftsmen and love to build things. I would be posting instructable mainly about the home decor things.
Benefits to using a reverse hyper extension.
  • Achieve greater hip extension than Romanian Deadlift.
  • Good to rehab your back (decompresses spine), run faster or just have a nice backside.
  • Can be done heavy or just bodyweight.
Step 1: Tools Required
  1. Miter Saw
  2. Skill/Reciprocating Saw
  3. Circular Hand Saw
  4. Power Drill/Screwdriver
  5. Clamps
  6. Pipe Wrench
  7. Assorted Wrenches/Socket Wrenches Staple Gun
  8. Speed Square
Step 2: Materials Needed
LUMBER
  • 12 Pieces 2x4x96 Pine
  • 1 Piece 1/2” 4×8 Plywood 2’ 1.5” Dowels
  • PIPING
  • 38” 1/2” galvanized pipe 2 Pieces 12” 1” pipe
  • 1 1” T Junction
  • 23” 1” pipe
  • 1” nipple
  • 1-1.25” increaser
  • 1.25” nipple
  • 1 1.25” T Junction
  • 2 6” 1.25” galvanized pipe 2 EMT couplings
  • 2 1/2 caps
HARDWARE
  • 22 4.5” Carriage Bolts with matching washers, nuts and snap washers 2 small boxes 3” framing screws
  • Wood Glue
UPHOLSTERY
  • 27”x36” 3” High-Density Foam 4’x4’ Vinyl
MISC
  • 1.5” Carabiner
  • 2 1” Utility Rings 3’ 2” Webbing
  • 2 1.5” Utility Rings
Step 3: CUTTING THE STRUCTURE
Cut all 2×4” pieces of the frame using a miter saw.
Many of the pieces will require either a single or dual 22.5-degree cuts. For the sake of simplicity, all prescribed lengths are in reference to the longest section of that piece.
Notes:
Where a single 22.5-degree cut is required the / icon will be used.
On pieces where there are multiple 22.5-degree cuts either the / / icon will be used to indicate that the cuts are parallel to each other or, the / \ icon will be used to indicate that the cuts are to be in opposing directions.The 2x4s will be cut into sections of the following length:
BASE PIECES
  • 2 Pieces cut to 57.5” with a single / degree cut 2 Pieces cut to 50” with / \ degree cuts
UPRIGHTS
  • 4 Pieces cut to 38” with / / degree cuts4 Pieces cut to 41.5” with / / degree cuts
TOP PIECES
  • 2 Pieces cut to 29.5” with a single / degree cut 2 Pieces cut to 14.25” with a dual / \ degree cuts
CROSS BEAM
  • 1 Piece cut to 30.5”
HANDLES
  • 2 Pieces cut to 18.5” with single/degree FLAT cut 2 Pieces cut to 10.5”
PLATFORM
  • 8 Pieces cut to 36”
BASE CROSS BEAMS
  • 3 Pieces cut to 36”
Step 4: FRAME ASSEMBY
Once all sections of 2×4 have been cut then it is time to assemble the frame.
For this step, the power drill/ screwdriver, wood glue, clamps and framing screws will be required.
Remember that long-term, it is the wood glue which will hold the pieces together.
The framing screws only ensure the wood glue has the chance to bind effectively. First, lay all the pieces out is in the picture above to ensure the edges line up flush with one another.
After the pieces have been aligned begin securing the following pieces to each other:
BASE x 2
  • Secure a 50” section of the base to a 57.5” section of the base using 3 screws, wood glue and clamps.
  • Repeat this step once more to construct to other pieces of the base.
  • To ensure the piece is aligned properly a 41.5” section of upright should fit flush and perpendicular in the space left (later this will be where the upright is secured to the base).
  • Make sure that when securing 2×4 sections to each other that as 22.5 degree cuts are parallel to each other.
  • The 50” section will be secured 3.5” back from the edge of the 57.5” sections.
THE SECOND PIECE OF THE BASE SHOULD MIRROR THE FIRST PIECE.
UPRIGHTS x 4
  • Secure a 38” section of upright to a 45” section of upright using 3 screws, wood glue and clamps.
  • The 38” section will be centered on the 45” section.
  • Make sure that when securing 2×4 sections to each other that all 22.5 degree cuts are parallel to each other.
  • To ensure the piece is aligned properly the assembled upright should fit flush and perpendicular in the space remaining from the base section.
  • Repeat this step three more times to construct the other uprights.
REMEMBER, THE FOUR UPRIGHTS WILL FACE EACH OTHER AND MUST MIRROR EACH OTHER.
TOP x 2
  • Secure a 14.5” section of the top to a 29.5” section of the top using 3 screws, wood glue, and clamps.
  • The 14.5” section will be secured 3.5” back from the edge of the 29.5” sections.
  • To ensure the piece is aligned properly a 41.5” section of upright should fit flush and perpendicular in the space left (later this will be where the upright is secured to the top).
  • Repeat this step once more to construct to other pieces of the top.
THE SECOND PIECE OF THE TOP SHOULD MIRROR THE FIRST PIECE.
Step 5: CONTINUE
Now that the Base, Uprights, and Tops to each side of the frame have been assembled, the various pieces of the frame can now be secured to each other.
At Each point where the pieces fit flush with each other, secure the pieces with 4 screws in a diamond pattern.
Ensure that there is enough space between the screws to run a carriage bolt through.
At this point, you should have to frames that mirror each other. If they are put together properly and if you are on the level ground they should stand independently.
Step 6: CONNECT THE FRAMES BY CONSTRUCTING THE PLATFORM
The next step is to connect the frames to each other across the top, forming the platform.
Begin at the top/front section of each frame.
  • Secure the 36” 2x4s across the top, making sure that at each connection a 90-degree angle is formed.
  • This cut ensures that the front brackets will sit flush between the uprights and the platform.
  • This cut should line up flush with the uprights.
  • Lastly, at the front of the platform perform a single 22.5 degree cut across the length of the piece using a circular hand saw.
  • Once all 8 pieces have been secured with framing screws, check each corner once again to confirm that a 90-degree angle is formed.
Step 7: ATTACH THE FRAMES AT THE BASE
Our next step is to connect the base cross beams to the base of the frame.
For this step simply secure a 36” 2×4 at the front, middle, and back of the assembly using framing screws.
Ensure that each connection is a 90-degree angle
Step 8: SECURE THE FRAME AT THE BACK OF THE STRUCTURE
After the platform has been secured to the frame secure the 30.5” piece between the two top pieces using framing screws.
When secure the back end of the assembly should appear closed off.
Step 9: SECURE THE BRACKETS
Next, connect the brackets at the base of the assembly, the top, and the front.
Make sure the brackets line up flush with the uprights and platform, or uprights and base. Secure first with wood screws and then with carriage bolts.
Step 10: ASSEMBLE THE HANDLES
For the handles first, screw the 18.5” piece underneath the section of the rear section of the platform.
The 22.5 degree flat cut that was made earlier should allow the 18.5” piece to fit flush in the corner of the rear upright and top piece.
Next, secure the 10.5” piece to the top of the 18.5” piece using wood glue and screws.
For the handle, you may use a piece of piping secured to a flange, or drill holes into the wood and use wooden dowels as adjustable handles.
Step 11: BUILD AND PLACE THE PENDULUM
Precisely 5.5” in from the front and 1.75” down from the top drill a 1/2” hole on each side of the top of the frame.
This hole will be for the 1/2” galvanized pipe to pass through.
  • Secure each piece of 12” 1” pipe to the 1” T Junction.
  • Feed the 1/2” pipe through the opening.
  • The hole will be snug and a pipe wrench will be necessary in order to Feed the pipe through.
  • Feed through the pipe through far enough to allow for 1” assembly to slide over the pipe.
  • Feed an EMT coupling over the 1/2” pipe followed by the 1” assembly.
  • Continue feeding the 1/2” pipe through the 1” pipe until the second EMT coupling can be placed over the 1/2” piping.
  • Once the 1/2” piping has been secured completely through the top sections of the hyper, secure the caps to the exposed threads on each side.
Assemble the remaining sections of 1” and 1.25” galvanized pipe to create the “pendulum arm.
The order will be:
  • 23” section of 1” pipe
  • 1” nipple
  • 1-1.25” increaser
  • 1.25” nipple
  • 1.5” carabiner
  • 1.25” T junction
  • 6” 1.25” x 2
Once the pendulum arm has been assembled, secure the arm to the 1” T junction.
Step 12: ADD PADDING AND VINYL
Place 3”high-density foam over the platform and wrap it in place with the vinyl.
Fold vinyl over the padding similarly to wrapping a Christmas present and secure using a staple gun.
While securing the vinyl loosen the top and front brackets to allow for the vinyl to cover all sections of the platform.
Re-secure the brackets back in place once the vinyl has been wrapped around/over the platform.
Step 13: ATTACH STRAP
Using the webbing make a water knot on each side.
Loop the excess webbing around a utility ring on each side.
Feed the excess webbing back through the water knot to secure the rings in place.
Clip the rings to the carabiner.
And there you have it! Please comment if you Like it.
    • Slow Cooker Challenge
    • Casting Contest
      Casting Contest
    • Spotless Contest
      Spotless Contest
