Introduction: How to Bend PVC & Make Incredible Shapes
Picture of How to Bend PVC & Make Incredible Shapes
I was recently working on a project where I needed to bend pvc pipes into smooth, round shapes. After some trial and error I found an easy way to get great results.
Step 1: Testing
Picture of Testing
First of all, cut your pipe to size, I used a variation of different sized pipes for this test. I found that if you heat up the pipe only with a heat gun from the outside it's hard to get a smooth curve, and you easily get kinks. Plus, you can only heat up a small section at a time. What I needed to do was find a way to heat up the pipe from the inside out.
Step 2: Tape the End
Picture of Tape the End
Duck tape on the end makes a nice block and then I measured out how much sand fit inside the pipe. I used regular sand that I had on hand and then I heat it up in a pot until it was pretty hot.
Step 3: Filling the Pipe
Picture of Filling the Pipe
I filled the pipe almost to the top, maybe with two inch empty space, and taped it shut.
Let the pipe rest for a few minutes to heat up thoroughly. Then with gloved hands you can start bending and manipulating the pipes. You can either do this freehand, or bend around something, like a jig or something round to get a precise shape.
Step 4: Different Pipes
Picture of Different Pipes
Once I held the shape for a little while, I poured out the sand, and there you go!
I tried this technique with a couple of different sized pipes. The larger pipes took longer to heat up and were a little harder to bend, however it's still possible to get slight curves. The thinner pipes however become very maluable and easy to bend into all sorts of crazy shapes!
Step 5: Conclusion - Watch the Video
For a much better perspective, make sure to watch the video that goes over the steps, and to see how easily the different pipes bend.
Haunted Spider made it! (author)2017-10-31
I used a very similar technique last Christmas for a chandelier at my Church. I used sand as well and heated it up in an oven at 500 degrees. That seems to be the right temp to get it to bend the PVC properly. I had several tins of sand going as I had multiple pieces to bend in a row. The jigs definitely help to shape the pieces over and over the same.
That Looks Awesome! Great Job!!!
WillisJ1 (author)Haunted Spider2017-11-13
That's pretty awesome! I wonder what it would look like with balloons covering it?
DustBunny (author)Haunted Spider2017-11-02
Amazing!
kwhit190211 (author)2017-11-24
that's really neat! I was a Pipefitter for 39 years and during that time I installed miles upon miles of pipe. This was one product that we never bent,(plastic). God knows how much steel pipe & tubing I've bent. And, this goes on the same principal in bending steel pipe. You have to fill it up with packed sand before you bend a tight radius.
MikeM241 (author)kwhit1902112018-01-04
Well Mr. kwhit, baybe you can tell me why all steel pipe is 21 feet long and PVC is 20 feet long? Something I have never been able to find out.-mike
kwhit190211 (author)MikeM2412018-01-04
Mike, that's just the way it is. But, with steel pipe you can't actually go by that 21 foot length either. I've unloaded large bundles of pipe that were of varying lengths when a shipment came into the shop. Most of the time they were 21" but sometimes they weren'tIt all depends on how the were cut when them came down the hotbed.
KenM17 (author)2017-11-01
Fill the pipe with BBs if sand residue is a proble,
Eric_Methven (author)KenM172017-12-31
Sand residue can usually be blown out with a compressor, or a hair dryer.
AntietamI (author)KenM172017-11-27
BBs sounds good - but would't it cost a fortune?
KenM17 (author)AntietamI2017-12-15
If making only 1 or 2 bends, yes, but if you are making a lot of them, then no it amortizes out vs the time cleaning out the tube after each bend.
veryrealperson (author)2017-12-25
what kind of sand
WernerT8 (author)2017-12-19
There are spring benders to bend condute pypes...
rdölz (author)2017-11-04
Anyone attempting this should be aware that, when heated, PVC may release CARCINOGENIC VAPORS. So always be in a well ventelated area and always wear suitable breathing protection
skylane (author)rdölz2017-12-10
When it burns, it's toxic.
dotrowebot (author)2017-11-20
awesome indestructible, i cannot wait to do this, thank you for sharing!
IqbalG2 (author)2017-11-19
Thanks for share, nice instructable
tinaciousz (author)2017-11-03
You're so great <3 Thanks for always sharing your wisdom with us!
HjoacoM (author)2017-11-03
Excellent work!
bpark1000 (author)2017-11-02
I use a propane torch, applied carefully, for gradual bends on heavy-walled pipe, for making underground irrigation sleeves into which the flexible line is inserted . It takes about 5 minutes of carefully moving flame to do it. This allows me to selectively heat only the parts to be bent. You could integrate this heating scheme with your hot sand method to heat the pipe from both inside and outside. You could also dump out and reheat the sand multiple times.
truesprocket (author)2017-11-01
The sand also keeps the pipe from folding. The fuller the better
iceng (author)2017-11-01
+1
iceng (author)iceng2017-11-01
Voted for you !
GTO3x2 (author)2017-10-30
Duct tape - It came from using it on furnace ductwork.
MillerI (author)GTO3x22017-11-01
Seconded! Also, malleable: a term meaning the ability to change shapes with ease.
jexy9 (author)2017-10-30
Great one. Thanks. The pipe will try to maintain its round shape due to the fact that a circle has the greatest area for a given perimeter, therefore the pipe will maintain its internal volume and its round cross section. The technique of filling a copper pipe with sand before bending, to avoid kinks, has been used for ever. Of course being as I am I had to figure out optimum temp for the sand. A quick search found
https://www.plastikcity.co.uk/useful-stuff/materia...
which indicated that the best moulding temp for PVC was between 20 and 60C depending on grade. 60C is about the upper limit for being able to hold comfortably - and that only for a short time.
Maybe the problem of heat penetration of thicker pipe could be overcome by not only filling the pipe with hot sand but also burying it in hot sand as well. Would obviously need more sand and some sort of trough but may be worth a try.
erniewallbanger (author)jexy92017-10-31
Jexy, I have to correct you there. The mold temperature is the setting for heating up the mould when injection molding. It simply does not relate to the plastic properties of PVC
The charts also gives the MELT temperature. This is the setting for the process of the injection molding. This temperature will produce a melt viscocity enabling a melt flow into the mold. This would be called the molding temperature.
Your point on the thickness issue is spot on! Plastics conduct heat poorly compared to metals so it will take a while for the heat to reach the outside, if ever!
I think there are some instructables on Injection Molding, have a look if you are interested,,,
Best regards, Ernie W.
jexy9 (author)erniewallbanger2017-10-31
aha thanks for clearing that up Ernie. I still wonder then what the optimum temp would be for this process. Maybe a bit of trial and error. Although the melt temp gives the temp for injection moulding, I was under the impression PVC pipe was extruded. Imagine that if the PVC pipe is heated too high, it would lose integrity and tear or rupture. Searching further for properties it seems that the loss of stiffness is fairly linear (and slow) until it gets to about 55C where it stars to lose stiffness more quickly. From 80 to 90C it again seems loss is linear but quite rapid. So perhaps the ideal temp range is somewhere there.
erniewallbanger (author)jexy92017-11-01
I would go for trial guided by error! You are right when looking att properties, this will give you a guide but practical result is what counts. Just for bending, anything that looks ok is ok. As long as it keeps its circular shape and bends with little resistance
But for a pressurized och chemical system I never would use bending, cold or heated, as there is a risk of damaging the properties of the tube. Then it is pipe and fittings.
As pointed out here, never use an open flame!
PVC can be extruded as well as molded. Just different grades with differnt additives.
Good luck to You, learning by way of doing!
Ernie
WinsionL (author)2017-10-31
Interesting , and helpful , thanks girl !
eddand (author)2017-10-31
we needed to bend abt 150 pcs of 3/4 inch sched 40 pvc into large sweeping bends. we cut the top off an electric water heater propped it at abt 45 degrees and filled it with water. we had to ocassionally turn the heater off because as the water reached boiling the pvc became to soft and would flatten when bent. we put a piece of wire mesh in the heater protecting the hearing unit from contact with the pvc. we could keep abt 8 to 10 pieces soaking in the heat at the rate we were able to bend them if the water is to hot you must bend faster or cool the water down.
hammockhiker (author)2017-10-29
Electricians use this tool: http://www.greenlee.com/catalog/Bending/PVC-BENDERS
pdavis19 (author)hammockhiker2017-10-30
True, but I think her solution is more flexible and allows for sizes that the Greenlee's don't. I'm a big Greenlee fan, but they're not cheap: $400+ for the 1/2" to 2" bender, $900+ for the 4" and $1400+ for the 6" puts them out of reach of most hobbyists.
DavidG809 (author)pdavis192017-10-30
Do you think a heat blanket could be used to bend pvc or acrylic sheets?
DennisT33 (author)DavidG8092017-10-30
For acrylic sheet people use strip heaters to soften an area of sheet clamped to a bench, and then bend it much like a sheet metal brake. You can use a propane torch but it's easy to singe it and the area of bending is not as confined.
This trick for PVC pipe is pretty clever, and is likely the only approach that doesn't risk kinking the tube. I have deformed PVC pipe with a torch (i.e. to pinch a constriction near the end) but it wouldn't suffice to bend a tube like this.
DavidG809 (author)DennisT332017-10-31
As I understand it. Strip heaters are only good in making sharp angles
What I meant was to use a blanket for curving sheets
Ie make a wood jig in the curvebyou want. Lay an open. Blanket over it then the acrylic sheet on that
I never bent plastics before I’m just spitballing ideas
Chipper Bert (author)DennisT332017-10-30
Electricians use a bending spring without any heat but you need some practice get an even curve. Also without heat the curve relaxes somewhat so you have to over-bend. The spring can also get stuck in complex bends so has its limitations. Very fiddly so the hot sand method is about as nifty as it gets other than as someone else has suggested, to use common salt instead of the sand.
Syncubus (author)DavidG8092017-10-30
Unlikely on the heat blanket. PVC's melting temperature is around 160 °C (320 °F), which would be dangerously hot for an electric blanket/heating pad (which are normally intended for direct skin contact).
https://en.wikipedia.org/wiki/Polyvinyl_chloride
ed-romes (author)hammockhiker2017-10-30
As an electrician that tool was used to make small offset bends to allow for a wall mounted circuit box to be connected to the pipe that's mounted to the wall but for the bends called sweeps they come pregame from the factory !! To make the bends shown here having sand in the pipe is a must even with the greenlee hot bender without the sand one size of the pipe can kink or suck in while the other size stresses out and becomes to thin !!
Oncer (author)2017-10-31
Voted for! But how hot is "pretty hot"? Within the range say of a sugar thermometer? It's just I can see me doing this and ending up with a puddle of PVC with extra sand!
Blackanga (author)2017-10-30
Very good idea. It has been used for ages to bend various metal pipes (not only copper - steel too, although the much higher temperature is required). However, for PVC, I would suggest using a table salt instead. It's cheap enough and it has been used as a poor man room heater (in the pot/pan over a stove) for ages. It heats up nicely and additionally, it will not leave any deposits inside the pipe, that can't be dissolved and washed off after.
Chipper Bert (author)Blackanga2017-10-30
The salt is a grand idea except when you are getting creative on a Sunday morning and there is not much salt in the cupboard and the shops are closed.
To get any residue out an ordinary vacation cleaner works pretty well. If you want to really be sure, tie a small rag onto the end of some thin fishing line and suck it through with the vacuum. Then tie a sliver of sponge to the line and pull it through. Repeat until you are happy.
You can do really long lengths this way. I wired up my garden for lighting and used HDPE pipe as a sleeve. I laid about 60m with multiple curves around ponds and flower beds and had no problem sucking the fishing line through.
jemuel sands (author)2017-10-30
I used a hair dryer as I didn't have a proper tool. It worked really well!
azapplewhite (author)2017-10-30
Very clever and simple with fantastic results. Nice job, thanks for posting.
ooohlaa (author)2017-10-29
i love this, but wondering what kind of uses to put it to, artistically its really wonderful but nothing comes to mind except lamp base and floor lamp base, picture/mirror frame, chandelier? None of which do I need, anybody?
chris.gaines.71 (author)ooohlaa2017-10-30
I've been doing this for parrot perches, swings and toys ... easy clean in the dishwasher!
Syncubus (author)ooohlaa2017-10-30
Tool holders, towel racks, grab bars, truck rails, bumpers or landing gear for RC cars/quadcopters, custom hula hoops, marble machine pipes, Archimedes screw pumps, etc., ad nauseum...
shrivver (author)ooohlaa2017-10-30
I was thinking it would be great for plumbing hard to reach areas! so much better than all those couplers!
skylane (author)shrivver2017-10-30
It absolutely can be used for plumbing. You can make your own coupling on one end of PVC by heating it with a heat gun. The pipe to be inserted needs to be beveled. Force the cool beveled piece into the heated pipe about an inch or so, let cool then remove. Now glue as usual.
I'd be cautious about using this technique for actual "pressurized water plumbing".
As you can see from the pictures, sand gets trapped in the plastic - which may come out and clog your fixtures.
More importantly, there will be some "thin" spots in the tubing after bending which might compromise the integritiy of the pipe for pressurized water.
About This Instructable
225,315views
584favorites
Bio: Hi I'm Linn and on my Youtube Channel I have lots of great videos about building, construction and fun projects. You can also check ... More »
More by darbinorvar:Mini Workbench W/ Woodworking Vise & ClampsBent PVC LED Desk Light8 Easy DIY Leather Christmas Gifts
Add instructable to:
