How to Draw a House in 2-Point Perspective
CraftArt by
Introduction: How to Draw a House in 2-Point Perspective
As an engineering and art student I spend a lot of my time learning skills that could benefit me in both classes.
In this Instructable I will be showing you guys how to draw a house in 2-point perspective because it builds the foundation needed to support your time in the field of art and engineering. And it's fun!
Step 1: Setting Up Your Drawing
Using a straight edge or ruler to draw a horizon line (HL). Label TWO vanishing points (VP) on your horizon line. The horizon line is line that represents the viewer’s eye level. The vanishing point is a point on the horizon line where lines that are parallel to the viewer’s line of sight appear to meet. Make sure to not place the points too close together (they can even be off the page) in order to avoid a distorted image.
Step 2: Starting the House
Draw a vertical line anywhere between both VPs BUT below the HL. This line is the closest vertical edge of the house.
Step 3: Starting the House
From this line, draw lines from the TOP and BOTTOM of the line to both VPs. These lines are called orthogonal lines.
Step 4: Establish How Big the House Will Be
Establish where each of the viewable sides of the house will end in space. Do this by drawing vertical lines between the orthogonal lines, essentially connecting two sets of receding lines.
Step 5: Draw the Back Corner of the House
From the tops of the newly drawn vertical edges, draw lines to the opposite vanishing point. Then the same thing for the bottom. The point at which the lines intersect becomes the back corners of the house.
Step 6: Adding the Roof
Find the center of one wall by drawing an “X” in it from corner to corner. From the center of the X, draw a vertical line as high as you would like the peak to go. Then draw a line toward the opposite VP. Connect the peaks to the top two corners. Then make a line parallel to the outside edge of the roof where the back corner of the house is. Or create an overhang by ending the roof a little lower than the two corners.
Step 7: Erase Extra Lines
Erase the extra orthogonal lines, leaving only the house.
Step 8: Add Details Following Perspective Rules
Using the perspective rules, add details like windows, doors, trees, or fences.
Step 9: Add Color!
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    That looks good, I've always struggled with getting perspective right when I draw :)
