How to Make High Power Led Dimmer+Dc Motor Speed Controller
1,040
20
Posted
Introduction: How to Make High Power Led Dimmer+Dc Motor Speed Controller
Hello everyone, I will show you how you can make a simple pwm control dc motor speed controller...
Also you can control the brightness of any led light....so this is a two in one circuit ..
order the pcb from jlcpcb.com who provides good quality pcb on a cheap budget..
I bought 10 pcs on 2$.....this is very cheap....
“Free Shipping on First Order & $2 PCB Prototyping on https://jlcpcb.com
The main equipment in this circuit is ic 555....In this setup we use ic 555 as an astable multivibrator...where it produce square waves.....In this setup we can control the duty cycle by varying the preset....
The output of the ic 555 is fed to a npn power transistor which can handle larger loads....you can use any npn power transistor or any n-channel mosfet....
if you want to control the led brightness just connect it across the transistor & positive power supply but if you want to control the speed of a dc motor then connect a 1n4007 or 1n4148 diode across the motor terminal & then connect it across the transistor & positive supply.....
My youtube channel-https://www.youtube.com/channel/UC8Af_aeyqsQijTBXT...
Step 1:
Watch the video
Step 2:
Order the components(I Bought the components from lcsc.com)
Components required....
1. IC 555.....................goo.gl/pasQKj
2. 8 PIN IC BASE............goo.gl/Sn1Rwi
3. 2*1N4007 DIODES.............goo.gl/6BCmwb
4. 100K PRESET.........goo.gl/s85MzF
5. MJE3055 NPN POWER TRANSISTOR...........goo.gl/LxnDmS
6. 2*103 PF.............goo.gl/KTHzXs
7. 220UF,25V CAPACITOR...........goo.gl/2Cbk3S
8. 12V POWER SUPPLY...........goo.gl/sKna14
9. 1K RESISTORS*2...........goo.gl/6imsuD
10. HEATSINK.............
Step 3: Order the Pcb
Step 4: Ready to Go
You are done
Now you can control your motor speed as well as led light brightness....
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
3 Comments
Don't waste your time on this. It's nothing more than an a PCB vendor promotion. No schematic, no theory of operation, incomplete parts list. It is not possible to replicate the project with the information provided. This is yet another junk circuit from JLCPCB.
Oh yes, a PWM circuit with a 555 timer does it every time. I would use the MOSFET because their on time resistance is way lower then any bipolar transistor. And since the on resistance is so low, it can handle a lot more current without getting too hot as well. JMHO
Nice circuit design. Do you have a schematic to show how the parts are wired together.?
