How to Make a Drill Power Water Pump - Step by Step
3,271
46
4
Published
Introduction: How to Make a Drill Power Water Pump - Step by Step
Make your own Homemade water Pump using drill Machine.
Step 1: List of Materials
1. White acrylic sheet
2. Metal sheet
3. PVC pipe
4. Ball bearing
5. Bike Tyre tube
6. Nuts and bolt
7. Drill Machine
Step 2: Cut the Acrylic Sheet
give the shape of centrifugal pump and also cut the round shape for inner propeller.
Step 3: Attach PVC Pipe to Acrylic Sheet
using hot air gun, mold the PVC pipe and fix it to one part of acrylic sheet
Step 4: Attach Ball Bearing to Acrylic Sheet
Step 5: Cut the Metal Sheet
Make the propeller blade using metal sheet, attach six blade to round shape acrylic sheet and attach hole propeller to water pump
Step 6: Make the Arrangement for Inlet
Make the arrangement for Inlet and joint whole part togther
Step 7: Make the Arrangement for Outlet
Step 8: Connect Drill Machine to Water Pump
Step 9: Water Pump Is Ready to Use
Step 10: Https://www.youtube.com/user/nfornavin?sub_confirmation=1
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    Good looking pump. How much suction is on the inlet side? If much this could be a easy answer to pump water from a well. Again good job.
    4 Comments
    Full marks for creativity! Congratulations!
    very nice. its good to see a project that doesn't require a 3d printer, cnc , arduino, and so on. thank you for this ble.
    Very cool. And if yo use a cordless drill you can take it anywhere.
