Introduction: Kiridashi Kogatana Marking Knife - With a BBQ and Grinder
Before we start off, a little background on why I wanted to try out a knife making project.
As teenager I had a little hobby of collecting pocket knives, bacl then I was interested in the emchanics of an object so it didn't take long before I did some reseach how a knife was made. Ever since I wanted to try to make one!
I do not have wide array of metal working tools, not even a bench grinder. Also I don't have a forge or big propane torch. I do have a BBQ grill, multiple acctually and I sell them as a side hustle, so BBQ's in abundance :p But could I heat up steel hot enough to anneal or quench it?
So I set off only having a grinder and a BBQ.
A Kiridashi knife is a Japanese utility knife If I understood the internet correctly. It is the same as we would name a 'stanly' knife. I really like this design of a knife with one sided bevels so that's why I chose this design.
I have 1:1 plans and drafts available from my website so if you are interested check it out:
www.seamm.nl
Step 1: A File
Picture of A File
My friend Paul gave me an old file. So without spending anything I had small chunck of good quality steel. Steel from a file is quite good material because you can harden it by quenching it. After this hardening process the material is still tough, not too brittle so that is good combination.
Steel is always an combination of iron and a small amount of carbon, the small carbon particles strengthen the metal crystals. In the case of the file there might have been a small amount of chrome and vanadium. This is typical for a cost effective steel used in tools.
Step 2: Annealing
Picture of Annealing
So Ilined op the BBQ and fired up the charcoal, put in the file without the handle. Positioned it in the hottest part of the grill waited for 1 hour and kept it at temperature, every now and then, by waving air with a news paper. Afterwards the steel was quite soft, I could 'file' this old file with a new file so you can anneal a file with your BBQ.
There are ofcourse temperature differencies in the grill so the whole file has not the same hardness. but in my case it functioned adequately.
Step 3: Make the Template
Picture of Make the Template
I made a design on paper just by drawing and experimenting with different shapes. I then put this design on a piece of thin wood. I check the size by putting the file onto the wood.
I used a coping saw to remove the facets of the design. With a standard file the round radius are smoothend and finished.
Step 4: GRRRinding Away!
Picture of GRRRinding Away!
With the pattern I could mark the desing onto the steel. I used a thin cutting wheel and started grinding away. The grinder made quick work of removing material so I did take care not too cross my lines.
I love the shape of these sparks, because the higher carbon content the sparks look 'fuller'
Step 5: Creating the Bevel
Picture of Creating the Bevel
I made 'round' bevel on the knife, that way the tip of the blade was the sharpest. This will be a making knife so that is good.
Step 6: Quenching
Picture of Quenching
I repeated the process of heating up the steel with the BBQ and made sure the tip of the blade was in the hottest spot of the grill. This time around the tip needed even be hotter so I kept adding heat until the steel was 'orange' hot.
At that point I put this in a glass container filled with light machine oil. When quickly lowering the hot metal in the container I was carful and mindfull the glass did not explode or the oil caught fire.
This process of quenching is actually trying to 'freeze' or forcefully holding the metal crystal in the most 'dense' configuration making the steel object harder. So with 'colder' oil the steel freezes in an instand to this configuration.
After quenching and everything was cool again I checked if the tip was hard. I tried to file it but I didn't succeeded. The file slide across the hard tip. After this you could temper the steel by putting it in an oven to soften it again and make it less brittle but the tip was nicely hardened the rest was tough so I skipped the tempering step.
Step 7: Sharpening
Picture of Sharpening
I used my oil stone to sharpen the tip of the blade. The trick is to keep your hands steady and the bevel in the same position while 'grinding' away the metal. I only got this right by practicing, you cannot fail in this step if you try hard enough and keep looking and assess if you sharpend correctly.
After this I repeated with a finer grit and ended by polishing the facets of the blade with a leather strop. I charged the leather with a green block of polishing wax, other colors are fine as well.
Step 8: Test!
Picture of Test!
And now check if it actually works!
The tip was sharp enough so knife lines could be drawn with it! The bevel is on one side so that's a bit different when using but it works conveniently enough!
I would encourage anyone to do this If you want to make knife the easy way!
I hope you enjoyed this!
Mihsin (author)2017-12-21
Very good project. I'll inspect all my flat files and choose the damaged ones, so next time we're barbecuing, they'll be ready for annealing.
haha you should! right after the steak or burgers!
dekeros (author)2017-12-19
Great instructable and good video!
thank you!
Nate5b (author)2017-12-15
Thanks for sharing!
happy to do so!
Kane Measham-Pywell (author)2017-12-15
Great instructable
I might try to make one out of a saw blade and if that works i will post it voted it in the metal contest
hi thanks!
MillennialDIYer (author)2017-12-12
Now you need two or three more of these for every time you lose it somewhere around the garage. Seems like a pretty neat thing to have.
Haha, more reasons to make another one.
Jake_Makes (author)2017-12-12
Very nice, well done. Just don't drop it! With no tempering cycle, that thing is going to rather on the brittle side :)
Thanks, I treat it with extra care!
deluges (author)Jake_Makes2017-12-14
+1 on that comment, don't drop it!
Ralphxyz (author)2017-12-14
Nice marking knife, but better yet is how you work in a small shop.
You have everything thought out, like your metal vice clamped in your wood vice
and other items.
Thank you for posting.
Ralph
Hi Ralph, thank you for the compliments!
PeterS226 (author)2017-12-14
Good work. Really good for marking out woodwork cuts.You will need both a left one and a right hand one.See videos on Japanese wood working.
Thanks, oh yeah that would certainly be better!
miloolim (author)2017-12-14
Nice video.... Your bbq, is that cut out on a cnc table?
Hey thanks, on a Laser.
DennisO22 (author)2017-12-14
Nice Instructable. Just a couple of points I hope will be helpful. The purpose of quenching is to try (in the case of an uncontrolled environment i.e DIY heat treatment) and produce a martensitic structure (a very hard but brittle atomic structure) that will be retained at room temperatures. The carbon content of the material will determine the success of this. In the case of your file, it has a high carbon content and that will require less heat than other lower carbon content steels, but as has been stated it will be VERY brittle. You could modify this brittleness by holding the knife with a pair of tongs etc and heating up the HANDLE END ONLY until it is red heat. Remove it from the heat and watch the cutting end change to a 'Straw' colour and immediately quench in oil (tempering). The thicker the oil the better. Also. Swirl the item around in the oil to hasten the quench. I see many internet videos where the operator just plunges the item into the oil. They do not realise that a gas bubble forms around the item being quenched, thereby reducing the effect of tempering. Swirling the item keeps the surface in contact with the oil.
I hope this is helpful to anyone having a go at heat treatment of steels.
hi Dennis, Thanks! and thanks for you input!
Mikhandmaker. (author)2017-12-14
Nice job! Congratulations
oops Download is working it is just such a small file my browser did not detect it downloading.
The download is not working!!
Dekiyangzom (author)2017-12-14
That's really cool! I never thought of using a barbecue grill as a forge!
Thank you!
Sebastiaan Mollema (author)2017-12-12
Hi all, I hope you could enjoy this project. Let me know what you think!
About This Instructable
9,331views
100favorites
License:
Bio: I am a maker and here I am sharing the fun stuff of making and creating! Apart from fun my goal is to share knowledge ... More »
More by Sebastiaan Mollema:Segmented Oak Clock, From FirewoodKiridashi Kogatana Marking Knife - With a BBQ and GrinderDIY Electric Bike // Bionx Conversion
Add instructable to:
