Knife Making-micarta Tutorial
980
18
Published
Introduction: Knife Making-micarta Tutorial
this is the material you're gona need for this build.
-cartboard -saw
-epoxy(resin) -press
-wood
Step 1: Cardboard
the first step is to cut the cartboard the size you want your micarta to be.
Step 2: Epoxy
after you make your epoxy and put it between every cartboard.
Step 3: Press/dry
after that you put the cartoard between two piece of wood and you press it while it's drying
Step 4: Final Cut
last step is to cut all four corner to get something clean and ready to use.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    gm280
    6 months ago
    You could also do this with clear polyester resins and do the same thing. Nice idea either way. The color combinations are endless.
