LED Speedometer
89,726
202
47
Posted in WorkshopCars
Introduction: LED Speedometer
My Peugeot 504 speedometer came to an end,  with a wire & wobbly needle. I don't like it anyway.
I made an LED RPM gauge before. I think an LED speedometer would be fine too. The main obstacle for me was the speed sensor. I thought of using variable reluctance magnetic pick up sensors or automotive ABS sensors. They operate on the same principle, fixed sensor over a rotating toothed ferrous wheel. As the teeth pass by the sensor, up & down electrical impulses are generated, as the speed increases, the frequency goes up too. Then we need to convert this frequency to voltage (using the LM2917 as in a tachometer), the increasing voltage will drive 30 LEDs through 3x LM3914 ICs. Good
I didn't spend much time looking for ABS sensors. I had a stepper motor from an old inkjet printer. I tought it can generate similar signal to be interpretted by LM2917. Later I found this motor can generate increasing voltage as the car speed goes up. So, I don't need a frequency to voltage converter (LM2917)
What to do:
1- remove the old speedometer with its wire
2- mount the speed sensor underneath the car to get movement from where the old wire got it
3- building the circuit
4- calibration
5-  finish
Step 1: The Speed Sensor
There are many Ideas when it comes to the speed sensors.
1- Variable reluctance magnetic pick up (ABS sensors)
2- IR LEDs & IR detectors
3- In my case, a stepper motor as a generator
I took this motor from my old ink-jet printer. It had two stepper motors, this is the stronger one in terms of size, weight, sensitivity & output voltage
The most challenging step is to mount the motor to the car transmission where the old speedometer cable used to be. So that the motor gets driven as the car move.
There should be:
1- Mechanical linkage between the motor head (gear) & the rotating speedometer rod inside the transmission
This was achieved using a small peice of copper folded upon itself. one end being rotated by the transmission, the second end to be inserted in a groove I made in the center of motor head (gear)
no welding needed :)
2- Good method for mounting the motor centrally in place. No shaking or to & fro movement is accepted
At my mechanic's, I drilled a 4mm hole in the transmission body, passed a screw & nut. Later on, I filled the gaps with epoxy resin glue. That was enough for good  fixation.
Now I have a speed sensor with a 4 wires cable :)
I took wire No 1 as a signal, wire No 2 as a ground
This motor can generate up to 48 Volts as I tested it. But When mount to my car's transmission, it rotates at near top speed generating 28 Volts. This is good. The relation betweed the car speed & voltage increase is linear. This is great.
Step 2: Building the Circuit
Attached the circuit schematics
12 Volts : from car battery
Ground :  Car chassis
Signal : from the sensor "stepper motor"
The No 5 Pin of LM3914 can withstand up to 35 Volts input. I added a 47K ohm trimpot potentiometer in series with signal input for calibration
Calibration was done using GPS equippied cellphone to get the car speed
:::::::::::::::::::: List of components: ::::::::::::::::::::::::
Integrated Circuits:
3 x LM3914 This is LED display driver. Each one can drive 10LEDs in either bar mode like this project or dot mode. Switching between both modes can be done, more instructions in datasheet.
1 x 7809 Volt regulator (outputs +9 Volts)
LEDs:
31 LEDs of any color you want. I used bright white ones. You can use some green, some yellow & some red for the red zone. You MUST use bright ones if you are planning to put paper covers over the LEDs or they are going to be simply invisible
 The first LED is continously lit as long as the +12V source is connected. The remaining 30 will be lit one by one as you increase the engine speed. I didn't connect the first one by the way
Diodes:
1 x 1N4007
Resistors:
2 x 1 Kohm
3 x 2.2 Kohm
Electrolytic Capacitors:
1 x 470 µFarad 25 Volts (µ = micro)
Polypropylene Capacitors:
2 x 100 nF (nano)
:::::::::::::::::: List of other things you need: ::::::::::::::::::::::::
Soldering equipment
Digital multimeter
Circuit board
Wires
Aluminium heatsink
A lot of patience
Step 3: Dashboard Work
See photos :)
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    47 Comments
    In my country it is highly illegal to make mods to the OEM safety and process critical systems. Nice instructable but for us here that will land us in serious trouble with the law.
    the stepper motor you used, is it DC volts output? or AC Volts?
    how did you put the 47k trimpot? i think the trimpot will burn if the voltage is too high
    Great Instructable!
    Does the 160 LED work?
    I didn't see it light up in the video! lol
    Great job!
    lol
    maybe next time when I use higher octane fuel & run on a better road.
    you can just jack up the rear portion of your car since your car is an RWD, jack up your rear wheels until fully hanging up then startup the engine and step on the throttle like you do on highways and watch the speedometer until it reaches 160 :D
    Awesome job and I'm sure maaaany hours! I'm trying to use a 2013 chrysler speedometer in my 1969 camaro. the 2013 gauges are controlled by an on board computer and extensive circuitry which I obviously don't have. If i remove everything but the stepper motor and gauge face do you think your circuit or similar could drive the motor accurately? basically I'd be replacing your led's with a motor to turn a needle.
    Abo_Hosni ... Assalamo Alaikom ...
    How about adding an Odometer and TripMeter .. your project is great and it would be perfect if you can add those two instruments ... simple using passive components like your SpeedoMeter and TachoMeter ...
    Thank you man ..
    what do the letters and numbers like "D2" correspond to? can I get a list of the circuits that they represent?
    Very cool project. I did something similar, but just used GPS and an LCD display instead.
    will this work with magnet and reed switch ???
    If yes what changes do i need to make in circuit ???
    am just beginner so please explain in detail, Thanks.
    & btw u really are creative like ur idea !!!!
    It would work, but a reed switch would wear out eventually. A Hall effect sensor is a better choice.
    On newer cars you can use a scanner tool to get the speed straight from the sensor.
    hello hosni
    how do we determine the wires from a stepper motor of a printer that it is No1 and No2?or output and ground?thanks a lot
    Is this mostly accurate, and does it drop out at high speeds when the stepper reaches its max
    could you draw a new diagram showing how this could be hooked up from a cars existing electronic speed sensor (AC Voltage) also, your in KMH, is there any difference between KMH and MPH? im guessing on the calibration of the potentiometer?
    actually, i just read about the diode bridge.. that is extremely simple. example for future people has been attached...
    from what ive read around, my car will put about 5v of a/c voltage at around 60 mph.. and just at .5v around 1-3 mph.. so i hope i can tune the input signal with the potentiometer to work with this level of voltage
    Hi,
    how did you made this one so accurate?
    https://www.instructables.com/files/deriv/FJC/84IQ/GFRWQY6J/FJC84IQGFRWQY6J.MEDIUM.jpg
    You can make the design you want with exact dimensions using Adobe PhotoShop. I used it to create 10x15cm prints
    Oh thanks, but I meant - after Photoshop. Is it a print on some plastic or painting? Or is it paper? It looks like film or plastic because of gloss.
