Led Grow Light for Plants
1,326
26
4
Posted in HomeGardening
Introduction: Led Grow Light for Plants
About: Build useless things since 1980
I’m doing a bigger experiment with plants. It will be a long time project.
So first of all I designed a led module witch is stackable
Step 1: The Idea
First, I wanted to buy 2 or 3 Led grow lights, but they were too expensive or not what I needed. So I decided to build my own Led light
I designed my Idea in Sketchup 8 and with DipTrace I made the shematic and the board design.
It’s not the most complicated circuit, but I took the chance to design a PCB.
Step 2: The PCB
And here it is. A nice and practical PCB from china.
I added the gerber files, if you want to reproduce the pcb
Step 3: One Finished LED Module
And here it is. One module has:
  • 20 red led's
  • 10 blue led's
  • 10 resistors 240 Ohm
One module cost me about 5$
As calculated it takes at 12V 200mA and look at the nice pink spot :)
On the last picture you can see how easy you can stack the single led modules
Step 4: The Gardening Work
Now the gardening work.
This will be my first attempt to check if my growing light works. I use coir pellets witch provide a lot of substrate and as seed I use salad burnet herb. I took these seeds because of there size.
A small plastic Tupperware will work as a peel for my vegetables. With the addition of water, the pellets swell up. I press the earth over the seeds and put the whole thing under the light. Now I have to wait if it works or not. I also added a thermometer to check if it’s not to cold in my workshop.
Crossing fingers.
Step 5: It Works
After 7 days I had the confirmation that it works
    • Casting Contest
      Casting Contest
    • Spotless Contest
      Spotless Contest
    • Flowers Challenge
      Flowers Challenge
    4 Comments
    Where did you order the PCB ?
    Thanks for any reply
    Update done.
    I'm doing a timelaps of the growing process. As soon as I have a result, I'll post it here.
