Introduction: Line Follower
LINE FOLLOWER
An autonomous robot that follows a predetermined path.The path is a black trail on a white background (The reverse is also possible). The Infrared sensors sense the black path and it indicates Arduino and based on the combination of different IR- sensors, Arduino is programmed so that the DC motor rotates.
Step 1: COMPONENTS AND CONNECTIONS
Picture of COMPONENTS AND CONNECTIONS
COMPONENTS
1.Arduino
2.Motor Driver-L293D
3.IR-Sensors (8 Array IR -Sensor )
4.100RPM DC Motor (2)
5.Chasis(Body) with 2 Wheels
6.12v Battery
7.Connecting Wires
CONNECTIONS
Arduino
Pin No 4 ----- Left Motor IN1
Pin No 5 ----- Left Motor IN2
Pin No 6 ----- Right Motor IN1
Pin No 7 ----- Right Motor IN2
Pin No 8 ----- IR Sensor 1 Output
Pin No 9 ----- IR Sensor 2 Output
Pin No 10 ----- IR Sensor 3 Output
Pin No 11 ----- IR Sensor 4 Output
Pin No 12 ----- IR Sensor 5 Output
5v ------ IR Sensor Vcc
Gnd -------IR Sensor Gnd
Motor Driver
Battery - Motor Driver Battery Slot
2 Motor connected to motor slots
5v (output)--------- Arduino Vin
Gnd --------Arduino Gnd
Step 2: Sensitivity Calibration and Code
Picture of Sensitivity Calibration and Code
Once Everything is connected, the sensors are adjusted via the potentiometer (POT), by adjusting the POT the sensitivity is varied.
Code Logic
Right Turn -------- IR5=1 and rest 0------ Right motor stop, Left turn
Left Turn -------- IR1=1 and rest 0------ Left motor stop Right turn
Straight -------- All IR =0------ Right motor run, left motor run
Stop ------- All IR=1---------Right motor stop, left motor stop
More Information can be obtained from the Line Follower PDF's
Dump the code to the board and check its working
Swansong (author)2018-01-08
Neat simple build, thanks for sharing :)
About This Instructable
328views
2favorites
More by Titanameda:Line Follower
Add instructable to:
