MINI LAPTOP
29,856
277
21
Published
Introduction: MINI LAPTOP
About: How to Everything.
Now this isn't my first time attempting to make a fully working laptop using a Raspberry Pi.The laptop I made “The Pi-Berry Laptop” is built around the Raspberry Pi 3. It has 1GB RAM, Quad core CPU, 4 USB Ports and One Ethernet port. The laptop meets daily life needs and smoothly runs programs like VLC media player , Mozilla Firefox , Arduino IDE, Libre Office, Libre CAD etc…
For convenience of using and reading the Display of the laptop was chosen to be 7 Inch (IPS technology) HD Display.
The 5600mAh battery pack provides the power to the laptop. Once fully charged the laptop runs for about 2 hrs.This means you can use the raspberry pi 2 for your future projects (good news for Raspberry pi enthusiasts).
NOTE : Please Vote This Instructable In Micro controller Contest.
Step 1: What You Will Need
Now when I first started making this project, I had other plans including way more complex electronics and designs. But in the end it all came down to these components
1x Raspberry Pi 3
1x 7" LCD Screen with lcd adapter.
1x Small Bluetooth USB keyboard
1x 5600 mAh USB Power bank
1x Mini speakers.
1x Mini Switch
1x 8-16 GB Memory card
1x 3.5 mm Audio Jack
1x Plastic Box 11 X 17 cm
Tools To Be Used :
Soldering iron
Hot glue Gun
Cuter
Step 2: Design Work
First things first, We got to design of case.
You need 11 X 17 CM Plastic Box Which have opening on top.I receive this box from stationary.
You Can also use 3D Printed case for this laptop.
Then Planning to how you adjust all component inside plastic box.
I Place Raspberry Pi Left Bottom side and Power bank at Right Bottom side of Box.
Then I Place 7" inch display to opening of Box.
Step 3: Review of All Componnent
1) The Display : The display / screen I opted for was a 7 Inch IPS technology HD display. This Display was extremely thin and suited my design
2) Key board : I use Bluetooth operated USB mini Keyboard as per my design.This was the best and smallest Key Board I found in the local market.You can use keyboard from a tablet PC case. This was the best and smallest Key Board I found in the local market.
3)Raspberry Pi 3 : The laptop I made “The Pi-Berry Laptop” is built around the Raspberry Pi 3. It has 1GB RAM, Quad core CPU, 4 USB Ports and One Ethernet port.
Step 4: Make Power Supply
The power-bank we chose should have important features : Pass-Through Charging (PTC) which means that we should be able to simultaneously charge and use the laptop at the same time.
I Take 5600 mAh Power Bank and open bottom case of this power bank.Then I apply some force bottom to top side.Then Take soldering iron and soldering two wire to negative and positive pole.Then close this case as per picture.
After closing you need to joint male USB pin to this + & - wire with one on/off switch as per picture.
Step 5: Choosing the Operating System
The choice of the operating system totally depends on the type of work you do. I wanted the functions of a desktop so I went with Raspbian Pi OS. There are a few other's to be considered:
1) Raspbian: Raspbian is the Raspberry Pi Foundation’s official supported operating system. You can install it with NOOBS or image. Raspbian comes pre-installed with plenty of software for education, programming and general use.
2) Ubuntu Mate: Ubuntu MATE is a stable, easy-to-use operating system with a configurable desktop environment. Ideal for those who want the most out of their computers and prefer a traditional desktop metaphor.
3) OSMC : (Open Source Media Center) is a free and open source media player based on Linux and founded in 2014 that lets you play back media from your local network, attached storage and the Internet.
Step 6: Installing the Operating System
Once you are decided with the operating system you want to go with, time to install it on the raspberry pi 3. Raspberry pi 3 boots from the SD card. So we have to get the image onto the SD card.
Which type of SD card is Best?
The recommendation of the size of the sd card depends on the Operating system we install. I used 16GB class 10 micro SD card. This gave me following advantage:
Class 10 cards are faster to boot and perform read write operations.
Writing the IMAGE of the O.S to the SD card is done by Burning the image file using theWin32 Disc Imager.
1) Using theSD Formattertool Format the SD card.
2) Open the Win32 Disk Imager and locate the image you downloaded. Click on "Write" once ready.
3) Wait for the writing to complete.
4) Once the writing is finished, safely eject the SD card from the computer.
5) If you followed the steps correctly the raspberry pi should Boot successfully with the OS.
Step 7: Assemble All Component to Test It's Working or Not ?
1) First of all Take Raspberry Pi 3 and take Display adapter to joint with raspberry pi 3.
2) Then take 7 inch display and joint with other end of display adapter.
3) Insert Raspbian OS imager 16 GB Memory Card inside slot of memory card of raspbian pi 3.
4) Then connect 5600 mAh Power supply to raspbian pi 3.
5) Switch ON and see yellow light glow up on raspbian pi 3 and 7" led display start or not ?
6) If working well then go to next step.
Step 8: Make Display Attractive
Take Fevibond glue or other glue and paste to frame of 7" display very carefully.Make sure Black part of display not affect with glue.
Then Take Black Paper Binding and cut in shape of frame.then paste on display as show in picture.
Step 9: Final Assembly
1) First of all Take Cutter and Make holder for raspbian pi 3 , power bank charging and switch.
2) Using small amount of glue to just hold the display in place.
3) Glue Raspbarry Pi 3 on their appropriate locations.
4) Hot glue the Power Supply on the respective places.
5) Connect the connections of the Raspberry pi 3 to Display Driver and power Supply.
Step 10: Make Audio System
Take one speaker from radio , toy or headphone and connect to 3.5 mm audio jack.
Connect this speaker to Raspbian Pi 3.
Sound of This speaker is low but If you need Loud sound you want to connect Audio Amplifier.
Make Closing Pad and glue this on top of this box.
Step 11: Final Step. START !
Finally. The Pi Laptop is almost done! Its fully usable and works like a small laptop. I hope you guys liked it!
Open and Switch on laptop.Raspberry pi should Boot successfully with the OS If all step is correct.
Connect Bluetooth USB Keyboard and enjoy your Laptop.
Microcontroller Contest
This is an entry in the
    • Woodworking Contest
      Woodworking Contest
    • Make it Move Contest
    • Microcontroller Contest
    12 Questions
    Shall we use LCD TV in place of 7" HD screen and used as a Android TV. What are the component to be require if we use in LCD TV.
    Micro idea.Yes you can make your tv as computer .You need one HDMI cable.connect raspberry pi and tv using HDMI cable.but TV should have HDMI port.
    is there any way i could remake the mother board with more ram or a ram slot
    Could anyone give me a link to the specific plastic box to use, along with the battery and speaker? I couldn't find them anywhere.Thank you!
    Ok I did find the battery but it's from an Indian company I believe, so I'm not sure how I can get it in the US. Does anyone know a battery that could fit well in that box?
    i was looking at zram does it work
    what did you use for the keyboard shelf or the cover
    CAN THIS PC BE CONNECTED WITH A WIRELESS SYSTEM
    Yes It connected with wifi module.I connect for only show how is experience of internet in this device.
    I can add upper than 16 MB?
    Can I get a link for where I can get one of those male usb pins? I cannot find them on Amazon.
    Cut the USB cable of your old android mobile charger.
    At the end of your video, after turning the computer on, you plug a small device into one of the USB ports. I was wondering what that is. Thank you!
    That one is a USB Bluetooth Receiver. He is using wireless keyboard tho..
    1 more answer
    Its a bluetooth receiver of keyboard.
    What is the grand total cost?
    21 Comments
    I already have most of the components, all I need is the raspberry Pi. Being a computer nut has it's perks. I collect and keep old computer and phone parts. The only negative comment I have is about the keyboard, the buttons are a little noisy when pressed. I use mine often and that is my only issue. I can see this being an awesome project for me when I have more time.
    i voted and am gonna make it PLEASE VOTE FOR THIS GUY HE DESERVES IT
    you built something this cool you deserve, also i have been wacthing your channel and i like your modo "creativiy can change the world."
    Very well done.
    ``This was the best and smallest Key Board I found in the local market.You
    Key Board I found in the local market.''
    You must really like this keyboard, because twice point that it is the best ;)
    I like it. Makes me want to get into Raspberry Pi uses.
    I wonder if something like this can be done with a tablet where it's screen doesn't respond to touch anymore. i.e. bluetooth keyboard.
    It looks like the bluetooth keyboard is already attached as the keyboard.
    This is so cool! I'm gonna need a computer for high school and I think that this would be a great option for myself. Thanks for the inspiring video and concept, it's light, portable, and small.
    Cool, very cool I thought of making one but your post shows a very easy method.
    Very cool.
    Thanks ....Please like and vote our projects.
    Nice little laptop. I would try using the built in Bluetooth to connect the keyboard, dispensing with the dongle. That would make it more visually appealing and make one more USB port available. Great work!
    Ok.Nice Idea.Please share your laptop pic here after making.
    This is pretty cool. I kinda want to make one too.
    Thanks.If you need help Please comment.I solve all problem.If you make perfect one Please share your laptop pic here.
    editing in the screen makes me have to question everything else.
    Well, I trust this more than the "how to make a DIY mains powered glue gun" video William Osman warned us about :) though it does use the same music which is a little unsettling.
    Maybe the battery powered screen isn't bright enough to show up well on video, maybe the one they made had some other issue like a broken ribbon cable and editing in a screencap was easier than fixing it, maybe the raspberry pi is too slow to make good video and they went with the smartphone advert "sequences shortened" approach :) whatever the cause, I'm relatively confident something like this could work even if it needs a couple of tweaks to perform properly.
    Very cool! I've been thinking about sticking a toe in the RPi waters, since the latest hardware seems to be powerful enough for browsing, plus the Raspberry Pi Desktop looks to be very useable. And your project might be within the range of my rather meager skill set for the most part.
    Thanks sharing!
