Make an L.E.D Emblem Light!
80,402
1,433
31
Published
Introduction: Make an L.E.D Emblem Light!
About: I make science and how to videos on the interwebs. youtube- youtube.com/mist8k
How to make this cool L.E.D lit emblem using a sheet of acrylic. You can also watch the video for more guidance.
What you need
Thick A5 sheet of clear acrylic plastic.
Base - I used the lid from a Lego box
Strip of colour changing L.E.Ds
Hot glue
Stencil of emblem or custom stencil
Rotary tool with attachments
Step 1: The Base
The A5 sheet of acrylic (plexiglass) I purchased from ebay. It's 2cms thick so I found a Lego box lid for the base. I used this because its hollow underneath and simple to cut using a knife. I chopped a strip out of the centre so it was thick enough to hold the acrylic. I also mad ridges at either side so the acrylic would slot in.
Step 2: Carving the Design
I used a batman stencil for the design but you could easily create your own custom stencil. I taped the stencil to the acrylic and placed it down on a soft surface to prevent the back of the acrylic from scratching. I used a rotary tool to carefully etch the acrylic. I used a rounded pointy end piece in the tool for the out line and a the sphere end piece to colour in the design. It will take a while to completely fill the design. You don't need to carve to deep. Just enough to rough up the acrylic so the design looks etched.
Step 3: Adding the L.E.Ds
Once I finished the engraving I placed the base on to the acrylic and stuck it in place with hot glue. For the illumination, I'm used a mains powered strip of colour changing L.E.Ds I have loads of these left over from previous projects. I chopped off a small strip and stuck them directly under the acrylic with a few blobs of hot glue. I also used a curved file to file out a groove for the mains wire to fit through the back of the base. Simple!
Step 4: Finished!
Watch the video here-
There we have it! A cool lit up acrylic emblem!
Have fun and be creative!
  • Make it Move Contest
  • Oil Contest
    Oil Contest
  • Casting Contest
    Casting Contest
Does the acrylic sheet have to be polised on the edges
31 Comments
If it doesn't have to be "deep", just roughed up a bit, why can't you just attach the vinyl stencil with craft paste and etch the design in with a craft media blaster?
Great Instructable. I'm thinking of making one of these myself, except I'm planning on using one of those acrylic displays (like for baseballs) and doing the display on all four sides...do you think that would work? Thanks
I'm going to make this but i cant find any acylic can anybody send me a link or tell me a website to where i can find some
Thnx
What type of connector is it to the LEDs? Where can I find that? VERY COOL PROJECT
Might have to make one of these with a heart for the GF! Nice job!
cool I will have to try this so you can use any emblem?
I just voted this cool project. is there any probability to using leds with batteries?
I mean to try for wall decoration.
nice idea. bet you could get the same effect using another etching method. for example acid or sandblast, might save some production time.
I agree.I've made several similar projects using a sandbalster.Anything to make the surface opaque works,even steel wool or fine sandpaper sanding in small circles works well.
I was going to say sandblast as well as use two piece of media so the etch floats in the middle. Nice job by OP!
Sandblast would work, as would a chemical enchant such as a mild solvent. Acid however would likely not do much to plastic... that's why acid ships in plastic containers. A laser engraver or CNC machine would also work well. (I've used both)
One thing I would look for, some of these LED strips produce heat and have adhesive backing... they should be adhered to a strip of metal to dissipate the heat. I've built things like this with LED strips... and the LEDs will fail as they do not get proper cooling. It only takes about 1mm of metal to dissipate the heat... a thin strip of circuit board will even work... but solid metal is better.
or even just some sand paper
Hey Man this looks awesome and is quite possibly a gift for some of my friends in the future, just a quick question about how much does the entire thing cost? under $30 would be desirable for me but I fully understand if it's over that.
I bought my acrylic from lowes for like $3 for the sheet. The rotary tool I got from Radioshack for about $30
If you were to have a weather proof housing you could make an illuminated house sign.
You could even include a small solar cell and rechargeable batteries.
