Make a Wing Bolt From a Plastic Bottle
9,927
81
42
Posted
Introduction: Make a Wing Bolt From a Plastic Bottle
More than once I needed a wing bolt, but I did not have one.
In this Instructable, I show you a trick how you can make a wing bolt from a bolt and a plastic bottle.
Step 1:
I cut off the bottle neck
Step 2:
I put the bolt in the vice and heated up the bottleneck with a heat-gun.
If you don't have a heat-gun, you can use an oven or a candle.
Step 3:
I used my hands and pliers to shape the wings.
Step 4:
Then I cut off the excess plastic
Step 5:
That's it! Our wing bolt is ready.
You might assume that the plastic will break, but actually it's very strong.
I could no break it with my hands.
Apart from making the wing nut, you can use this method to undo nuts and bolts in emergency situations.
  • Gluten Free Challenge
  • Epilog Challenge 9
    Epilog Challenge 9
3 Tips
Pt.- Eu fiz e adaptei para um outro tipo também.
In.- I did and adapted for another type too.
This can be used to make a wing nut also.
I realize that it would be overkill to have ratcheting PVC pipe cutters on hand just in case you wanted to make a wingbolt, but if you happened to have them for the intended purpose of cutting PVC, they work great for cutting the necks off plastic bottles
1 Questions
SHOULD or is there one or the other type of plastic bottle that is better plastic to use? I mean it seems to me that milk bottles are of a more pliable plastic but maybe not as long lasting, ie more susceptible to sunlight degeneration? Love the concept, needed a wing nut a couple of days ago and drove 3 miles to get one.
I don't think milk bottle plastic will work very well as it's very soft.
In this Instructable I used a bottle from a sparkling water..... it's just like a like a coca-cola bottle.
It works very well because it's very hard.
I tried to use a cap from a juice carton, but it was too soft.
32 Comments
Great idea. But I doubt that in an "emergency situation" I would have a heat gun or a rotary tool handy ;o)
A lighter should suffice and the rotary tool would only be needed for aesthetics, unless you are in a really tight situation, in which case this might not work anyways.
Good points, but if in a true emergency, work with the tools you have available to get the job done.
Well...... Yeah, you're probably wright :)
I sort of thought as much, but sometimes my thinking is all wrong. I am finding half gallon milk bottles with the bottom part cut off at a slant great pet food scoops, easily replaced and I keep the caps on cause sometimes I can use also with cap removed as a funnel. Oh! made a wing nut out of a Pepsi bottle and I love it. Did it just so I would remember the exercise when I need it next time.
"Did it just so I would remember the exercise when I need it next time."
That is a great idea! I often read things like this but forget about it when the time comes, a practice run to cement it to memory would certainly help.
Excellent instructable. This will definitely come in handy as I always try to reuse before I recycle and plastic bottles are a prime candidate.
Neat idea. Thnx.
That's awesome, great job!!
