Mickey Mouse Mug Holder
586
23
Posted
Introduction: Mickey Mouse Mug Holder
Some friends of mine are really, really into all things Disney. They were setting up a new coffee station in their house, and they wanted a large, Mickey Mouse mug holder for the wall, so I made one. Watch the video to see how it was made or follow along to see all of the steps!
Step 1: BACKGROUND
Some of the requirements for this project were as follows:
  • Be over 3' tall
  • Butcher block style with different hardwoods
  • Hold a ton of mugs
  • Pegs spaced for odd-sized or large mugs also
Step 2: TOOLS & MATERIALS
Step 3: GATHER MATERIALS & CUT TO ROUGH LENGTH
I started off by getting a bunch of different types of wood and cutting them to rough length on the miter saw. You can see me stacking them up on the bench to see if I have enough.
Step 4: FLATTEN ONE SIDE AT THE JOINTER
Then, I took them to the jointer to get one flat side.
Step 5: ANOTHER STRAIGHT EDGE
After I had one flat side, I used that side referenced against my table saw fence and ripped strips out of each board.
Step 6: ARRANGE
Once I had them arranged in a way that I liked, and all of the edges were flat and parallel, I started one of the most stressful glue-ups I've ever done! There were so many boards, and I wanted a good amount of glue coverage, so there was glue everywhere!
Step 7: QUICK TIP
Quick Tip: if you drip wood glue onto your floor, don't try to wipe it up. That will only smear it into the concrete more. Wait until it dries. Then, you can come back with a scraper and pop the glue spots right off. Ask me how I know this?
Step 8: SCRAPE OFF EXCESS GLUE
After I took the panel out of the clamps, I used some scrapers to remove the excess glue.
Step 9: SAND IT FLAT
Then, I ran it through the drum sander a few times. This thing was so heavy, I had a hard time using the drum sander to flatten it effectively. It CAN be used for this kind of thing, but maybe I don't have the knowledge of how to use it for something so wide and heavy yet.
Step 10: PRINT TEMPLATE
I took the dimensions my friends wanted the final piece to be, and used a site called rasterbator.com to blow it up into a poster. I didn't particularly like how it did it. It was quite hard to assemble and get it to look right.
Then, I sprayed some adhesive on the template, and stuck it temporarily to the board.
Step 11: CUT OUT SHAPE
I took it to the bandsaw to cut off some of the bulk, but it was really to heavy to do much at the bandsaw. I finished cutting out the template with my jigsaw, which was awful. Even as tightly as I could clamp it, I got a lot of vibration. I generally don't like the jigsaw.
Step 12: REFINE EDGE
I refined the shape and edges through a series of belt sanders, files and my random orbit sander.
Step 13: ROUNDOVER
I added a 1/8" roundover to all of the edges with my router.
Step 14: ADDING FINISH
Then, I sprayed on a few coats of clear lacquer, sanding between with 320 grit sandpaper.
Step 15: MARK FOR MUGS
This next part was interesting...I used a few mugs of various sizes to sketch out where all of the pegs needed to be. They wanted to get a lot of mugs on this board, so I had to try to squeeze in as many as I thought looked good. I think it ended up with 40 spots to hang mugs, depending on their sizes.
Step 16: DRILL HOLES
I put together this little jig to help me drill the holes for the pegs at a slight angle. They didn't have to be exact, but since I was using a handheld drill (too large to use on my drill press for many of the holes in the center), I needed something to help me repeat the angle. I drilled a starter hole in a scrap block at the desired angle, and then used that to guide my holes in the piece. This was a lot of drilling! I drilled 40 holes that were 1/2" wide, and at least that deep!
Step 17: CUT DOWELS
I used a stop block at my table saw sled to cut out all of the oak dowels. Then, I rounded over the edges on the random orbit sander
Step 18: SECURE DOWELS
I decided to use some epoxy to glue in the pegs, just for a little more holding power. They had a nice, tight fit.
Step 19: ADD FRENCH CLEAT
All that was left at this point was to attach the French cleat and try it out!
Step 20: CONCLUSION
I love it this Mickey Mouse mug holder turned out! My friends loved it too, so that makes me smile.
Thanks for taking the time to read this and watch the video. I will see you on the next project!
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    2 Comments
    Thank you! I appreciate you following along!
