Moisture Sensor Test Plan
Introduction: Moisture Sensor Test Plan
The goal of this test plan is to create a sensor that determines whether soil is wet.
Step 1: Materials
The following materials will be needed for this sensor:
Arduino Uno Microcontroller
Soil Moisture Sensor
Two LEDs
Laptop Computer
USB cable to connect the Arduino to the Computer
A beaker of dry soil and a beaker of wet soil
Step 2: Putting Together the Circuit
First, you are going to need to connect the moisture sensor to the Arduino. To do so, start by connecting the SIG pin on the sensor to the A0 pin on the breadboard, Ground to Ground, and VCC to pin 7.
Then, you need to connect the LEDs to the circuit. One LED should be connected to pin 8 and another to pin 9. Keep in mind that pin 8 will tell you that the soil is dry and pin 9 that the soil is wet. In the second picture, the blue is connected to pin 8 (connected by the white wire), so it lights up when the reading is dry, while the green is connected to pin 9 (connected by the blue wire), so it lights up when the reading is wet. If you encounter issues with the LEDs, make sure that the shorter leg of the LED is first -- meaning the shorter leg is in a lower number spot on the breadboard.
The grounds of these LEDs then need to be connected together on another line (in the second image, 20) so one wire can go from the breadboard to the Arduino ground, completing the circuit. The wires completing the circuit are the orange wires on the breadboard.
First Image Link:
Step 3: Programming the Arduino
/* Soil Mositure Basic Example
This sketch was written by SparkFun Electronics Joel Bartlett August 31, 2015
Basic skecth to print out soil moisture values to the Serial Monitor
Released under the MIT License( */
int val = 0; //value for storing moisture value
int soilPin = A0; //Declare a variable for the soil moisture sensor
int soilPower = 7; //Variable for Soil moisture Power
int wetPin = 9; // green LED in 9 pin
int dryPin = 8; // blue LED in 8 pin
//Rather than powering the sensor through the 3.3V or 5V pins,
//we'll use a digital pin to power the sensor. This will
//prevent corrosion of the sensor as it sits in the soil.
void setup() {
Serial.begin(9600); // open serial over USB
pinMode(soilPower, OUTPUT); //Set D7 as an OUTPUT
digitalWrite(soilPower, LOW); //Set to LOW so no power is flowing through the sensor
pinMode(dryPin, OUTPUT); // dry LED is an output
pinMode(wetPin, OUTPUT); // wet LED is an output
void loop() {
//Serial.print("Soil Moisture = ");
//get soil moisture value from the function below and print it
if(readSoil()>700){ //if the soil value is greater than 700
Serial.println("Soil is wet"); // print soil is wet
digitalWrite(wetPin, HIGH); // Wet LED on
digitalWrite(dryPin, LOW); // Dry LED off
Serial.println("Soil is dry"); // write soil is dry in serial monitor
digitalWrite(wetPin, LOW); // Wet LED off
digitalWrite(dryPin, HIGH); // Dry LED on
//This 1 second timefrme is used so you can test the sensor and see it change in real-time.
//For in-plant applications, you will want to take readings much less frequently.
//take a reading every second
//This is a function used to get the soil moisture content
int readSoil() {
digitalWrite(soilPower, HIGH); // turn D7 "On"
delay(10); //wait 10 milliseconds
val = analogRead(soilPin); //Read the SIG value form sensor
digitalWrite(soilPower, LOW); //turn D7 "Off"
return val; //send current moisture value
Step 4: Video!
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    That would be really helpful in the garden, I have a tendency to over water the plants ^.^;
