Nano ESP32 BLE Scanner
3,980
53
4
Posted in TechnologyWireless
Introduction: Nano ESP32 BLE Scanner
About: Make it yourself if you cannot buy one!
This instructables show how to use ESP32 to make wireless BLE signal scanner, all scanned data will send to the HTTP server via WiFi.
Step 1: Why BLE Scanner?
BLE (Bluetooth Low Energy) signal is very common for current digital device, mobile phone, wrist band, iBeacon, assets tag. This signal not only help you pair up the devices, it also can report the device status, such as battery level, heart rate, motion (walking, running, falling), temperature, panic button, anti-loss ... etc.
It is a valuable big data for location tracking if we can collect the BLE signal at certain number of position.
In long run, the BLE scanner should fix in selected position. However, selecting a right place require trial and error. A tiny wireless BLE scanner is handy to help you check where is the right place.
Step 2: Preparation
ESP32 board
I am using ESP-WROOM-32 board this time.
A Tiny Container
Any small container should be ok, I have some tiny TicTac box in hand and it just fit an ESP32 board in it, what a coincidence!
Lipo Battery
ESP32 peak current is around 250 mA. For not drawing over 1C current at anytime, Lipo Battery should over 250 mAh capacity. 852025 is the maximum size that can fit into the Tictac box and it claim it have 300 mAh, it's good enough.
Power Regulator Circuit
A 3.3 V LDO regulator, some capacitors, I have some HT7333A regulator, 22 uf and 100 uf capacitor in hand
Others
A 10k Ohm SMD resistor for pull up EN pin, a small piece of multi purpose PCB, a power switch, some coated wires, 7 pins header
ESP32 Dev Dock
In program process, it also require a ESP32 Development Dock, you may find how to make it in my previous instructables:
https://www.instructables.com/id/Battery-Powered-E...
Step 3: Trim the PCB
Measure the dimension of your tiny container and trim the PCB to fit into it.
Step 4: Soldering Pin Header
Let's start soldering work from the 7 pins header and PCB.
Step 5: Soldering Power Circuit
Here is the connection summary:
LDO Vin  -> Vcc pin header(1) -> power switch -> Lipo V+, Charge pin header(7)
LDO GND  -> GND pin header(2), capacitors V- pins, ESP32 GND
LDO Vout -> capacitors V+ pins, ESP32 Vcc
Step 6: Soldering Pull Up Resistor
It is the most difficult soldering work in this project, the pin width in ESP32 board is only 1.27 mm. Fortunately, Vcc and EN pin is nearby, it can direct soldering resistor between both pin without wire.
ESP32 Vcc pin -> 10k Ohm resistor -> ESP32 EN pin
Step 7: Soldering Program Pins
Here are the connection summary:
Tx pin header(3)      -> ESP32 Tx pin
Rx pin header(4)      -> ESP32 Rx pin
Program pin header(5) -> ESP32 GPIO 0 pin
RST pin header(6)     -> ESP32 EN pin
Step 8: Cleaning Up the TicTac Box
  • Eat all sweets
  • Remove the stickers
Step 9: Squeeze Into the Box
Squeeze all component into the TicTac box, be careful don't tear off any wires.
Step 10: Prepare Software
cd [USER HOME]
cd Documents
cd Arduino
mkdir espressif
cd espressif
git clone <a href="https://github.com/moononournation/arduino-esp32.git">https://github.com/moononournation/arduino-esp32.g...</a> esp32
cd esp32
<p>git submodule update --init --recursive</p><p>cd tools</p>
  • Download the compiler
Linux / MacOS
python get.py
Windows
get.exe
The above tailor-made arduino-esp32 source extended the app partition to 0x1800000 to fit BLE and WiFi logic in the same program. If you already have Arduino with ESP32 support, some files require to modify manually:
boards.txt: replace all 1310720 to 1572864
<p>esp32.upload.maximum_size=1572864</p>
tools/partitions/default.csv
<p># Name,   Type, SubType, Offset,  Size, Flags<br>nvs,      data, nvs,     0x9000,  0x5000,
otadata,  data, ota,     0xe000,  0x2000,
app0,     app,  ota_0,   0x10000, 0x180000,
app1,     app,  ota_1,   0x190000,0x180000,
eeprom,   data, 0x99,    0x310000,0x1000,
spiffs,   data, spiffs,  0x311000,0xEF000,</p>
Ref.: https://github.com/espressif/arduino-esp32/compar...
Step 11: Program the ESP32
#define WIFI_SSID "YOURAPSSID"
#define WIFI_PASSWORD "YOURAPPASSWORD"
#define POST_URL "http://YOURSERVERNAMEORIP:3000/"
  • Upload
Step 12: Receive Data
If you are not yet have any HTTP server to receive the POST data, you may try to use this simple Node.js program: https://github.com/moononournation/post_data_rece...
Here are the sample data received:
Tue Mar 20 2018 08:44:41 GMT+0000 (UTC): [
  "Address": "6e:3d:f0:a0:00:36",
  "Rssi": -65,
  "ManufacturerData": "4c0010050b1047f0b3"
  "Address": "f8:04:2e:bc:51:97",
  "Rssi": -94,
  "ManufacturerData": "75004204018020f8042ebc5197fa042ebc519601000000000000"
  "Address": "0c:07:4a:fa:60:dd",
  "Rssi": -96,
  "ManufacturerData": "4c0009060304c0a80105"
Step 13: Power Measurement
The program scan BLE signal for 30 seconds, then deep sleep 300 seconds and then scan again. For each loop, it consume around 3.9 mWh.
Theoretically, it can run: (I will update the testing result later on my Twitter)
300 mAh Lipo / 3.9 mWh @ 330 seconds
= [(300 mA * 3.3 V) mWh / 3.9 mWh * 330] seconds
~83769 seconds
~23 hours
2018-04-08 Update:
I have changed to use XC6503D331 LDO regulator and made 2 measurements:
Round 1: 12:43:28 - 16:42:10 (~20 hours) 210 BLE scan POST received
Round 2: 10:04:01 - 05:36:47 (~19.5 hours) 208 BLE scan POST received
Step 14: Happy Scanning!
It time to find a place to setup you BLE tracking network!
    • Microcontroller Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    Hi Sir!
    Excellent and very detailled build, but I'm affraid your battery autonomy calculus is wrong.
    And in terms of power management, it could be much upgraded!
    You use a linear voltage regulator, these components are made to theoriticaly only be abble to lower the voltage, and come with no safety, so it will drain the battery until the integrated safety of the cell cuts out (around 3V this type). It means very deep discharge each time, not good for it.
    The available energy is not to be computed with the average 3.7V!! The true capacity is depending on the discharge curve, but can be roughly estimated by the capacity (mAh) over the difference between full voltage and empty voltage (4.2-3V = 1.2V this type), not 3.7!
    Also, just putting your calculus in a calculator doesn't match the 11h.
    Very clean on other aspects, I like your programmer and charger.
    1 Questions
    I can't even imagine how to work without a shematic, have you got one ? Thx
    I meant "schematic" !
    4 Comments
    I am having issues with the Arduino sketch being too big. I am using Arduino IDE V1.8.5 on windows 10. Here is the error message I receive. Can you help?
    "Sketch uses 1357670 bytes (103%) of program storage space. Maximum is 1310720 bytes.
    Global variables use 72828 bytes (24%) of dynamic memory, leaving 222084 bytes for local variables. Maximum is 294912 bytes.
    Sketch too big; see http://www.arduino.cc/en/Guide/Troubleshooting#size for tips on reducing it.
    Error compiling for board ESP32 Dev Module."
    okay, I didn't follow step 10. Once I did I did receive a different error...."Error at line 7: CSV flag column contains unknown flag
    '</p>'". Once I removed the </p> from the same line it all worked fine. I am working on the HTTP server connections next so please disregard my earlier comment- you did a great job here!!
    Hi billp119,
    Yes step 10 is very important, thats why I need clone the main branch and amend it.
    Hi FabriceV1, I have revised the calculation. The theoretic live time should around 23 hours and the actual measured time is near 20 hours.
