PVC Pipe Shoe Rack
Introduction: PVC Pipe Shoe Rack
In this instructables i will show you how to make a Shoe Rack out of PVC Pipe
Step 1: Materials
60ft of 1 1/4 in PVC Pipe
20 1 1/4in Tee PVC Pipe fittings
Measuring Tape
Miter saw or hand
Step 2: What You Need to Cut
You will need to cut...
6 3ft pipes
4 1.5ft pipes
4 10 7/8in
12 1.5in pipes
8 2in pipes
Step 3: Putting It Together Part 1
Put Three Tee fittings together using the 1.5in pieces then at each end put a 2.5in piece.
Do that 4 times (Two for each Shelf)
Step 4: Putting It Together Part 2
Get the 6 3ft pieces and connect them to the three Tee fittings at each end.
(3 3ft Pipes per each shelf)
Step 5: Putting It Together Part 3
Connect a Tee fitting to one end of each 10 7/8 in pipe
Then Connect a 1.5ft pipe to the Tee Fitting then put a Tee Fitting on top of the 1.5ft pipes
Step 6: Putting It Together Part 4
Now connect the Shelving to the top and bottom of the main frame
And..... Your Done
You can make it taller if you want by making more 1.5ft,1.5in,2.5,3ft and Tee Fittings
Step 7: The Final Product
You should end up with something that looks like this
If you have any questions ask me in the comment section below
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    What a great idea and design! Thanks for sharing you great looking shoe rack!
