Personal Applause Sign
29,520
139
32
Published
Introduction: Personal Applause Sign
About: My name is Randy and I am a Community Manager in these here parts. In a previous life I had founded and run the Instructables Design Studio (RIP) @ Autodesk's Pier 9 Technology Center. I'm also the author ...
For the longest time, people have been neglecting to applaud my myriad accomplishments. I could not abide by this and henceforth set out to resolve this issue. The solution wasn't immediately obvious, but after mulling it over for a while, it suddenly hit me. People have been culturally conditioned to clap for light-up signs that read "APPLAUSE."
From that moment on, it became clear to me that I had to make my own light up "APPLAUSE" sign that I could wirelessly trigger whenever the moment necessitated a round of admiration. And let me tell you, it works like a charm. You can get people to applaud you for almost anything.
I feel that this notion is really catching on. People are always asking me how they can make their own applause sign. There is a much larger admiration deficit in this world than I had initially anticipated. So, as a community service, I am sharing how people can make their own personal applause sign and seek the blind adulation they so rightly deserve.
(Obligatory Warning: This project uses high voltages and power tools. Consult professionals when in doubt. I take no responsibility for any of the information here or what you do with it! Proceed at your own risk.)
Step 1: Go Get Stuff
You will need:
3' x 4' sheet of 3/4" playwood
36" x 5.5" x 1/8" mirror acrylic
36" x 5.5" x 1/8" milky white acrylic
Black acrylic paint
Black house paint
Fine paint brushes
House paint brushes
Quick release clamps
1-1/4" wood screws
3/4" wood screws
A power drill and bits
5 amp puck relay
6 lamp sockets
6 40 watt round bulbs
Power junction box
Power socket
Heavy gauge lamp cord
Wireless doorbell
Arduino programmer
PCB
7805 5V regulator
3V regulator
(x2) heat sinks
22pF capacitors
16 MHZ crystal
Atmega168 chip
28 pin socket
Momentary switch
100uF capacitor
Audio isolator transformer
(x2) 1K resistor
A 4148 diode
0.1uF capacitor
9V battery connector
9V battery
Lamp cord
Wire nuts
4.5V adapter
Cable organizers
End caps
Wood putty
A putty knife
Sandpaper
15' 3-prong extension cord
Step 2: Cut Boards to Size
Cut 3 boards out of your plywood that are 36" x 6" and one that is 36" x 7".
While you're at it, you may as well cut two 5.5" x 5.5" squares.
Step 3: Cut Channels
First thing's first, we are going to need to make a 1/4" deep channel in each of the 36" x 6" boards.
Clamp your board to a work surface. Next clamp a guide parallel to one edge, such that you will cut the channel 1/2" in from that edge. Set your saw to cut 1/4" deep and make the cut.
Repeat on the second board.
Step 4: Start the Box
Stand a 36" x 6" board upright such that the channel is closer to the table and facing inwards. Lay the 36" x 7" board on top of it, such that they are joined at a right angle. You can use the second 36" x 6" board to keep it upright for the time being. Drill a few pilot holes and then fasten them together with wood screws.
Repeat this process on the opposite side, forming a U-shape.
Step 5: Finish the Box
Insert your 5.5" x 5.5" squares into each edge of the box such that they close the "U".
Clamp, drill pilot holes and then fasten with wood screws.
Step 6: Laser Etch the Sign
Keep the protective coating on your milky white acrylic and then laser etch the front panel using the file attached below called applausesign1. Do multiple passes until it etches down a few millimeters.
While you're at it, vector cut the mirror acrylic with the file below called applauseMirrorcut. Don't forget that the reflective side must absolutely be face down.
Step 7: Paint the Sign
Apply multiple coats of acrylic paint to the front of the sign until you are positive it is opaque.
An easy way to check this is to peel off the protective coat from the backside and hold the sign up to a light bulb and see if you can see through the paint. Keep applying coats of paint until you can't.
Step 8: Clean Up Imperfections
Clean up any uneven surfaces with wood putty and sand it smooth.
Step 9: Take Apart the Doorbell
Carefully remove the doorbell receiver from its casing and sit it aside for later.
Don't lose the screws (like I did).
Step 10: Prepare the Ringer Casing
Using the 4 holes on the edge of the mirror acrylic as a guide, drill holes in the wireless doorbell casing.
Step 11: Drill Holes
Place the mirror acrylic into the back of the applause sign casing and use the holes in the acrylic as guides to drill pilot holes.
Also drill a 3/4" hole through the case below where the power junction box attaches (in the next step).
Step 12: Attach Things
Use 3/4" wood screws and fasten the wireless remote box, the power junction box and the sockets to the casing.
Step 13: Wire It Up
Wire up the sockets in parallel with lamp cord.
Have a few inches of cord sticking off the end closest to the wireless doorbell box.
Step 14: Paint It Black
Put a few even coats of black paint on all visible surfaces of the box and also the two strips of wood on the edge of the case that will sit directly below the applause sign.
Step 15: Wire Up the Socket
Cut off the female end of the power cord and strip the cord back until three wires are exposed. Strip and inch of jacket off of each of these wires.
Wire up the socket such that the white cord goes to one terminal, the black to another terminal and the green to ground. Secure the socket into the junction box.
Step 16: Build the Circuit
Build a Hackduino board as explained here.
Cut the speaker off of your wireless doorbell receiver. Leave as much wire connected to the receiver as you can.
Wire that as analog in to the Arduino. See the schematic for what parts are necessary for this and what wires go where.
Program the Arduino with the following code (source file attached below):
* Based on:
* http://www.arduino.cc/en/Tutorial/Knock
int relayPin = 13; // led connected to control pin 13
int ringDetect = 0; // the knock sensor will be plugged at analog pin 0
byte val = 0; // variable to store the value read from the sensor pin
int statePin = LOW; // variable used to store the last LED status, to toggle the light
int THRESHOLD = 50; // threshold value to decide when the detected sound is a knock or not
void setup() {
pinMode(relayPin, OUTPUT); // declare the ledPin as as OUTPUT
Serial.begin(9600); // use the serial port
void loop() {
val = analogRead(ringDetect); // read the sensor and store it in the variable "val"
if (val >= THRESHOLD) {
digitalWrite(relayPin, HIGH); // turn the led on or off
delay(8000);
digitalWrite(relayPin, LOW); // turn the led on or off
delay(100); // we have to make a delay to avoid overloading the serial port
Step 17: Wire the Relay
Connect the wire from pin 19 to the positive DC terminal of the relay. Connect the negative terminal of the relay to the ground wire.
Connect one of the lamp wires coming from the sockets to one side of the AC portion of the relay and connect one of the terminals from your AC power cord to the other side.
Twist together the free lamp cord with the free wire from the power cord. Twist on a wire nut to keep them insulated and secure.
Step 18: Clean It Up
Screw in the bulbs.
Organize the wires and fasten them to case.
Install and secure the rest of the electronics.
Step 19: Slide in Sign
Plug in your 9V battery and then slide the sign into the front channels of the case.
Step 20: Hang the Sign (optional)
When you are done, you can hang the sign if you like. I accomplished this by drilling some holes in the top and using strings to tie it to a conveniently suspended cord near the ceiling.
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    32 Discussions
    impied
    4 weeks ago
    RANDY THIS IS AMAZING. Quincy just showed it to me. I feel privileged to work with you.
    Thank you! :)
    One of these days I will live in a place large enough to hang it up again.
    Everyone but you. We have been trying to keep it a secret for as long as we could. We figured that you wouldn't react well if you found out.
    Okay, if that's the way it's gonna be.
    But I think that you should know that I have made it my life's mission to get revenge - and your job. It is an awesome job, and I think we both know that it is truly my job, in the grand scheme of things, but YOU took it, even though you knew it should be my job, thereby throwing the entire universe out of whack with you accepting job offers all willy-nilly without giving even a passing thought as to how it would affect the rest of us.
    I am coming. I am coming to take my rightful job, and you know what? I will make you regret taking it. I will smear peanut butter and jelly on your macbook touchpad. I will scratch all of your CDs. I am going to steal your fish flakes, so that the fishies go hungry, and sprinkle them in your latte, and then stir the latte so that they dissolve into it, so you will drink it unaware that you are depriving the poor, poor goldfish of vital nourishment that is an important part of this nutritious breakfast. And then I will put extra sugar in the latte. To hide the taste of fish flakes.
    So in conclusion no it's not a problem at all and I very much understand and this in no way changes our relationship.
    Before I came along, community management was performed by an army of interns chained to a radiator in the Instructables basement. They needed to be taken care of. They were provided with daily meals stolen from dumpsters and occasionally hosed off in a utility sink. I changed all of this. I rode onto the scene and said, "I will perform this community management of which you speak and you need not chain me to a radiator for I shall not run away! The hordes of internet trolls, spammers and pen gun manufacturers do not scare me, for I am Randofo!" Perhaps I did not say it quite like that.
    Anyhow, what I am getting at is that you can scratch my CDs and starve my goldfish; you can cover my computer in processed nut paste and candied fruit jam; you can even steal my job; but you shall never do anything to my latte because I don't drink coffee, as caffeine makes me twitchy. Even more twitchy than I already am.
    Actually, wait a minute... you can't steal my job! For you see, as I was explaining earlier, I forged this job out of the eternal heat of the Instructables basement radiator, thus breaking the chains of intern filter-clearing slavery and thus taming and systematizing the beast, until it was a beat no longer, but a daily chore that I mumbled halfheartedly about at the daily meeting. And thus, with the interns freed to do other more grueling tasks, and the filters cleared daily, and the website tamed, I was able to begin the age of Randofo. Fortifications were fortified and ramparts were ramped and somewhere along the way I made a whole bunch of stuff. Thus, I was knighted Sir Community Manager of Instructables by Dr. Eric J. Wilhelm himself.
    For you see, I could not possibly have stolen your job because I braved the fire, broke the chains, freed the interns, tamed the beast, systematized the system, mumbled at the meetings, begun the age, fortified the fort, ramped the ramparts, made some stuff and was thus knighted Instructables first Community Manager... or something like that.
    So, in short, I as well look forward to maintaining our relationship with no unexpected twists or unforeseen changes.
    "...an army of interns chained to a radiator in the Instructables basement. They needed to be taken care of. They were provided with daily meals stolen from dumpsters and occasionally hosed off in a utility sink. "
    Oh.... how true! Utility sink showers are the best!
    Nice. Want one. Definitely with some interchangeable messages :) Incidentally, I found on a previous project that if you can't get milky acrylic, then using a disk sander on some clear perspex works very well to get the diffused light effect for the background.
    Great idea! I'm workign on designing a "Quiet Please" sign, and this looks pretty adaptable. One thing that should be mentioned is that the ATMega168 needs to have the Arduino bootloader programmed into it. One needs to buy it pre-programmed (I know SparkFun sells them), or else have an AVR programmer available to do it yourself.
    Haahaha! Great idea and better execution.
    Love it! I've found a few places online (I just bought one from SVC.com) that you can buy small wireless car-alarm style remotes that would work great with this, too. They're cheap, simple enough to wire up, and the remotes are keychain-size.
    If I can find a way to label this from the inside, so you can't see what it says until it's lit, I'm going to have to do this.
    I need one of these for my meetings. Somehow I am the only that knows that I just said something applause worthy.
