Portable Bluetooth Speaker (FREE PLANS)
27,661
237
24
Published
Introduction: Portable Bluetooth Speaker (FREE PLANS)
About: Nice to meet you! I'm Donny from Lithuania and I have a passion for designing aesthetic, yet durable and practical projects. Check my YouTube channel for more! ▶ http://www.youtube.com/c/DonnyTerek
Hello everyone! In this Instructable I will show you how I built this Portable Bluetooth Speaker that sounds as good as it looks. I have included Build Plans, Laser-Cut plans, all the links for products that you would need in order to build this speaker by yourself and the Wiring Diagram is free download and you can find it at the end of this intro or in the Electronics Step. Make sure to zoom in to see the connections up close!
I was always astonished by the design of Bose - the manufacturer of amazing speakers. With that I mind I wanted to create my own portable speaker for the fraction of the price. Many hours were spent designing the speaker and sourcing materials in order to build this speaker. Therefore I will share the whole building process with you!
Step 1: Idea and Design
To begin with I created a 3D model of the speaker in Sketchup keeping in mind the inner volume of the speaker enclosure required for the drivers. Sketchup is a great tool for visual assembly and designing of the speaker. I then made drawings in CAD for the panels needed for the build and brought them to my local laser-cutting company to cut the panels out of 4mm plywood. The laser made incredibly accurate and clean cuts in the plywood resulting in perfectly fitting parts and easier assembly.
Step 2: Parts and Materials
https://ebay.to/2HgrDDuThe materials and parts for this speaker are available from the links below and/or your local suppliers. For the enclosure of the speaker I used 5 layers of 12mm MDF. The main and supporting panels where cut out of 4mm plywood sheet. The Wiring Diagram for the electronics is provided so make sure you take a look!
COMPONENTS:
TOOLS and MATERIALS:
Step 3: Speaker Enclosure
I have uploaded free build plans for this speaker! You can find them at the end of this step. Make sure you print the plans and make sure that the measurements are correct using a ruler! Also you can download the .dxf plans and ask your local laser-cutting company to cut them out for you in few minutes instead!
To build the enclosure I used a router and a laser-cutter to achieve almost perfect results with minimal effort but I have also uploaded a set of plans for those who may not have access to such tools. Using the plans provided, the speaker can be built using the same materials (12mm MDF and 4mm plywood) and simple tools, such as a jig saw and a drill. The most important thing is to make sure that you print the plans at the correct scale. To check if you have printed the plans correctly, simply print out a page and using calipers or a ruler check whether the speaker holes match the dimensions written.
I traced out the plywood template on all 5 MDF pieces. Four holes where then drilled through the boards with a decent sized drill bit and a jigsaw was used to cut around the template staying as close to the edge as possible. Once I had the 5 pieces cut out, I applied narrow double sided tape on the plywood template and stuck it down on the MDF cutout. A spiral flush trim bit was loaded in to my router and the height adjusted to cut the MDF only. Turning the router and dust collection on, made the job of creating five copies of the template quite easy. I lightly sanded both sides of the enclosure pieces to get rid of any burr left on the edges. Using a plastic card I spread the wood glue on the enclosure piece and glue one on top of another stacking 5 layers of MDF together. Once the glue has dried, I sanded the enclosure for a smoother finish. I then took a flush trim bit, removed its bearing and replaced it with a smaller one in order to cut very little into the MDF enclosure. The lip that is carved out by this process on both sides, ensures that the supporting panels sit nice and tight in the enclosure. I made sure to use sufficient dust collection because trimming MDF with a router makes a LOT of nasty dust. After that I used a roundover bit to roundover the edges of the enclosure. This makes the enclosure a lot smoother and nicer to hold in hand and also provides curves that are more easily wrapped in vinyl later. I then proceeded by drilling a 16mm hole in the enclosure for the main switch. A step drill bit was used to drill the hole – this tool is amazing! A healthy amount of wood glue was then spread along the edges created by the router bit and the support panels put in place and allowed to dry.
Step 4: Plywood Panels
I then sanded the faces of the laser-cut plywood panels using fine grit sandpaper to remove any burn marks on the wood from laser cutting. I placed both panels on a sheet of paper and sprayed couple of coats of lacquer. This brought more depth in the wood grain, highlighted the text and created a protective layer on the plywood.
Step 5: Gluing in the Plywood Panels
I then applied glue around the edge of the speaker enclosure, spread it out and pressed in the supporting plywood panels which sit nicely on the edge that is made with the flush trim bit with a smaller bearing. The panels are pressed in place for a few hours until proceeding to the next step.
Step 6: Covering in Leather Vinyl
For this process it is necessary to have good ventilation and to cover both sides of the speaker enclosure in masking tape to protect any plywood surfaces from unnecessary contact adhesive on the edges which would later prevent the plywood panels to be attached close together. It is important to only cover the MDF in contact adhesive. Once both sides of the enclosure were covered in tape, I started applying the contact adhesive with a soft brush, making sure to cover the whole enclosure where the leather vinyl would wrap around.
Once the enclosure was covered in contact adhesive, I cut a long and narrow piece of vinyl leather and applied the same adhesive on the back side of the fabric itself, being careful not to apply any glue to the leather side of the vinyl. Once the glue has become dry to the touch on both surfaces (drying takes only few minutes), the vinyl can be applied.
Unfortunately, I have lost the footage of me wrapping the material around the enclosure and gluing in the passive radiators, but I will try to explain the process as best as I can.
It is important that the leather vinyl piece is a rectangle with straight edges on all four sides. That is important because when wrapping the enclosure in vinyl we will end up with a seam on the bottom side of the enclosure. This seam can be almost invisible if the edge of the vinyl is cut as straight as possible and the tucked into another side of the vinyl piece once the vinyl is wrapped all the way around the enclosure.
The most difficult and skill-requiring part of wrapping the enclosure is taking care of the corners. Using the roundover bit in the previous step helps a lot since it creates soft curves which are more forgiving for wrapping the material. The key is to pull the vinyl with a lot of force and tuck in the inside of the speaker and slowly working your way down to avoid any wrinkles and bumps. A plastic gift card is a great tool here.
Once the vinyl is tucked around the edges, a sharp (brand new) blade is used to cut along the plywood support panel in order to remove the excess of the vinyl.
Step 7: Electronics
Feel free to download the wiring schematic and zoom in for a better view!
These tactile momentary button switches were used to turn on the Bluetooth and the battery capacity board. The face of the button was lightly sanded and two-part epoxy was used to glue them in place. It is important to seal the edges so that no air leaks out of the speaker once it is done. A dab of epoxy was placed on the switch and the plywood disc pushed in place. I also used epoxy to glue in four (1 red and 3 green) LEDs. Four 330 Ohm resistors were soldered in place of the LEDs that were on the battery capacity tester board. The shorter wires that were soldered to the board will later be soldered to the switch. The longer wires that were soldered to the board will later be soldered to the outputs of the BMS (Battery management system) board. Then four pieces of wire were soldered to the board which will be connected to the four LEDs glued on the panel. A piece of double sided tape is used to attach the board to the panel. Three 18650 cells were then glued in a triangular arrangement for better fitment inside the enclosure. Then the cells were connected to the BMS board. The wiring diagram is shown above. I then soldered black (negative) and red (positive) wires to the DC jack for charging. I then proceeded to wire up the audio sources. I began with soldering the blue LED to the KRC-86B Bluetooth audio receiver board. I then took a 3.5mm audio jack and soldered two 1kOhm resistors. One from Left channel to Ground and the other from Right channel to Ground. This almost entirely eliminates any background noise when using the AUX port. The wires from the audio jack were then soldered to the Bluetooth board to the according terminals. I then soldered wires to the ‘GND’ and ‘VCC’ pins of the Bluetooth board from a 555 timer chip and a few components to create switching circuit that only turns on when a button is pressed and that way the battery energy is not consumed when the speaker is not in use. A step-down converter and an isolated converter was used to supply power to the Bluetooth board and eliminate any ground-loop noise. I then took the White LED switch and soldered two of its pins together to make the LED turn on when the button is pressed in. The remaining wires were then soldered to the PAM8610 amplifier. The two remaining wires from the battery capacity baord were soldered to the DC jack. The blue LED from the Bluetooth board was then glued in place and the wires from the switching circuit soldered to the button. The audio jack was ten attached in place and the wires from the DC jack soldered to the ‘P+’ and ‘P-‘ terminals of the BMS board. The remaining wires were soldered to the main LED switch which was the pushed in place.
Step 8: Final Assembly
For the final assembly the full-range speakers were bolted down using M3 bolts and nylon nuts from behind. This creates an air-tight seal around the drivers. Once the speakers were bolted in place, the output wires from the amplifier were soldered to the speakers. Wood glue was spread around the edges of the panel and pressed in place for a tight fit. I then stuck a long piece of double sided foam tape around the back panel support to create an air-tight seal once the back panel is screwed in place. Four adhesive rubber pads were put on the speaker bottom. With that done the speaker is now ready for a quick charge and proper use.
Step 9: Finished Product
Once the speaker is charged it is ready to produce some noise. The battery indicator lights show that the battery is now full. The white LED switch is pushed in turning on the speaker. With the button pressed, the Bluetooth is enabled and the speaker is ready to pair with an audio device. Once paired, the music can be streamed for up to 6 hours on full volume and nearly 5 days on 50% volume! The battery life on this speaker is stellar due to high capacity Lithium-Ion cells and very efficient class-D amplifier board.
The audio recorded on my end and then played through your speakers may not be the best depiction of audio quality but I can ensure that this speaker delivers great sound quality and decent bass filling an entire room.
Thank You so much for following me through this tutorial! I hope I have managed to inspire you to create your own speaker using my or your own design :)
And that's how my Portable Bluetooth Speaker came to be! It was a pretty cool project that helped me improve my skills, and I truly hope that you learned something new as well. If you have any questions, feel free to ask in the comments. Also consider visiting my YouTube channel for more videos. Thanks!
Also, take a look at my Etsy shop!
Thank You!
- Donny
    • Planter Challenge
      Planter Challenge
    • Clocks Contest
      Clocks Contest
    • Microcontroller Contest
    3 Tips
    Use some sound absorbing material inside (eg. cotton wool) to avoid acoustic standing waves.
    And,
    if you settle for lower volume for more bass, measure the frequency
    response of the completed speaker+cabinet system and use equalisation.
    It's just some passive RC-components and an OP-AMP...
    My speaker
    is an 8cm driver in a 2liter closed box. It needed +8dB @50Hz and -4dB
    above 2kHz. I measured with white noise from youtube and Spectroid
    android app. Checked the sound with foobar's EQ before build the
    phisical EQ circuit.
    I've been soldering wires together for 40 years. Vibrations are not going to break a well-soldered joint, but do use the heat shrink for insulation. If the joints need to be strengthed twist the wires around each other or bend hooks in each end then close with pliers. Messier joint, but strong.
    Use heat shrink on the wires to add mechanical strength, as vibrations may break some solder joints.
    7 Questions
    Hi, I have a couple of electronics questions (I am beginner in electronics):
    1) Could I charge the batteries from a 5V micro-USB standard connector instead of a 9V? The only problem I see is when speaker is connected to socket, thus PAM would only receive 5V, right? Maybe I could add a step -up (5V to 12V) converter to feed PAM while on charging?
    2) Why there is the need to add a 555 timer (and its resistors and capacitor)? What is its function exactly?
    Awesome project, thanks for sharing!
    Hi. This looks like a really fun project. Thanks for the plans and the wiring, it is very helpful. I noticed that the front and back panels are laser cut. As I don't have a laser cutter, is there any chance in getting a DXF file for the front and back. I have a friend who works in a laser cutting business and could do the work for me. Thanks
    Robert
    Hi! Thanks! I have just uploaded a set of DXF plans for the build, feel free to give those a try!
    1 more answer
    Thanks again. Wasn't sure where to ask hence the message here and on Youtube.
    Couldnt we power the Bluetooth module directly from one part of the 18650 cell, i.e. 3.7v off the single cell and let the remaining amp work on 12v? Is that even possible seeing that you have not used a balancer?
    Hi! You could power the Bluetooth module directly from one 18650 cell but that would result in a bigger amp draw from one cell which would later cause problems while charging since the cells need to be very close in voltage in order to charge properly through a BMS.
    Hey. Sorry for asking.
    But, what is the size of the panels? I mean on the 4 sides?
    Example: Back Panel, On the 4 sides of this one?
    Best Regards
    Hey.
    I want to make this myself but i need the sketchup file. I have no experience in sketchup and I don't know what sizes it uses. Is there a way that you can send me a file or something?
    Thank you :D
    Hi!
    I have recently uploaded a set of build plans for the speaker, I hope you will give it a try! Good luck!
    Fantastic project! I am wondering what your final cost ended up being?
    Thank You! Around 40$ which is way less than most commercial speakers!
    Are u sure about this noise isolation method? Is safe to close L R and GND?
    Yes, it drastically reduces the noise when plugging in an auxiliary cord.
    24 Comments
    Hi, thanks for all the instructions, it's one of the most complete I have read on DIY bluetooth speakers. I will definitely take some information from it !!
    Just a short remark : the link to the passive radiator goes to the amplifier, it the same link than the previous line.
    And,
    My speaker
    Beautiful piece of work. Thanks for posting this clear and concise ible!
    Thank You so much! My pleasure!
    This is, quite possibly, the most impressive build I've seen on Instructables.
    Thank You! That truly means a lot..
    BT Speaker builds is the main reason I started on this site. Beautiful speaker and well made ible. Question, as I've not been able to start on any build yet, how long does a speaker like this last while connected and playing audio? I obviously wouldn't expect you to sit with a timer just curious for an estimated time...
    Turns out, the speaker has been used for 5 days now, playing music for around 2-3 hours a day on half loudness and the battery is still doing good without a single charge in that period of time!
    Thank you! That is a great question indeed. I get around 4-6 hours of playtime depending on the volume.
    Nice job. I've always wanted to build a battery indicator. How do you know that the battery is fully charged after being plugged in the outlet? My concern is leaving it plugged in the wall too long and the batteries may "explode".
    Thanks! Not only does the indicator show when the battery is fully charged, but there's also an LED mounted in the charger which turns from red to green once charged!
    Lithium cells need some complicated charging, luckily that is what the BMS board takes care of. Once you plug it in to charge it will stop charging when it is full automatically :)
    ahh. so you need the BMS board. Otherwise, it'll over charge and bad things may happen. As for the battery indicator, would you know what the max voltage it supports up to? I'm trying to use 12v amplifier for a project.
    The previous comment pretty much explains the purpose of the BMS board in such project. Since I am using three 18650 cells with the max voltage of 4.2V each, I would say the maximum voltage the battery indicator could support is 13-14V. Make sure you adjust the resistance of the resistors used to supply power to the LEDs according to your supplied voltage.
    Although there is little doubt that a bluetooth speaker of equal or better techniques could be bought much cheaper than this design, this is a good essay. The physical build techniques are well thought out and presented. The bluetooth connection can be used for other more esoteric projects. Kudo's for giving sources and links. Thumbs up!
    I agree, you did a very nice job explaining everything and I, too, will use parts of your project for other projects. Nice job Donny...btw do you have a schematic that you either followed or developed?
    Your comment is highly appreciated, thank you! I will post a detailed schematic in a few days.
