Quick & Easy Faucet Wrench
2,747
41
13
Published
Introduction: Quick & Easy Faucet Wrench
About: Retired Tool Maker ( 1980 ) Retired Mechanical Engineer ( 2009 ) Full time Tinkerer
Hi Gang:
I had to replace some faucets and one sink had the hold down nuts in a really tight spot. Usually I can turn these with my fingers, but they just are not as strong as they used to be. Plus did I mention the spot between the wall and the sink was really tight?
Step 1: Materials
So I found that 1 1/2" PVC pipe was about the same diameter as the nuts. So I cut a piece about 10" long.
Step 2: Marking the Spots
The tabs on the nuts were 90° apart so I marked the end of the pipe to match the tabs.
Step 3: Table Saw Setup
So I set the fence of my table saw so the blade was about the center of the pipe. Accuracy here isn't very important so you could do this with a hand saw.
Step 4: Cutting the Slots.
Just get close to the marks. Cut about a 1/2" deep and then back out. It took two passes to get each slot to fit the nut, keep cutting until they all fit.
Step 5: Trial Fitting
So here is the "wrench" about to engage the nut.
Step 6: Success!
The "wrench" fits both the white nut with four tabs and the black nut with two tabs.
Step 7: Wrench in Place
So without the sink and wall in the way here is the 'wrench" on the faucet nut. I found the PVC pipe gave me plenty of grip to tighten the nuts. If you have problems you could use pliers on the pipe or drill some holes to add a torque bar.
Good luck, I hope this makes your faucet jobs easier!
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    13 Comments
    Might try gluing a tee on the end for a little handle, and if you need a little more torque you could just push a couple short pieces of pipe in the ends.
    Good Idea!
    I did find that for plastic nuts just my hands were enough.
    Thanks, Carl.
    how do you use it when there is a hose attached?
    The faucets had brass tubes that I broke off first. Then I tightened the nuts before the new tubes were put on. Carl.
    Elegant and cheap solution. Thanks for sharing,??
    Be sure to save that wrench!?
    Hello John:
    I did save it with the extra faucet parts. But it is so simple and quick to make it might save tool box space to just make a new one in twenty years!
    Carl.
    Nice tool! You could drill a couple holes up the pipe so you could put a screwdriver through and get some extra torque.
    Hi JmsDwh:
    I found that just twisting the pipe was enough. Much more and either the nut would crack or the sink porcelain give way. But in a tight spot it might really help.
    Thanks, Carl.
    Absent a saw of any kind, heating the edge of scrap metal piece and pressing it down on the scribe marks would work too. In any event, a nice bit of thinking here! ☺
    this is such an elegant solution!
    Nice.
    Thanks.
