Remote Control Lock
1,187
31
Posted
Introduction: Remote Control Lock
Hi,
Welcome to Creativity Buzz.
Here You can make wireless remote control door lock using Arduino Uno.
You need this materials for making this lock.
1) Arduino Uno
2) 4 Channel wireless switch
3) 100 RPM DC motor
4) Syringe
5) Nut and Bolt 2 inch lenght
6) M-seal
7) Wooden Block
8) Battery and wire
9) Stopper
It is awesome DIY PROJECT using DC motor and battery.
Step 1: Materials
1) 4 Channel wireless switch
2) Stopper
3) 100 RPM DC motor
4) Syringe
6) M-seal
7) Wooden Block
8) Battery and wire
Step 2: Stopper Placement
Take one 12 X 14 CM Wooden Block and Marking 4 Holes.
Drill 4 Holes using Drill Machine On this Marking Point.
Make Sure Holes are not Passing through Other side.
Then tighten screw through stopper.
Step 3: Placement of Wireless Receiver
Make one hole using Drill Machine and place wireless reciver on wooden plate.
Then tight screw using screw driver.
Step 4: Stick Nut
Take some M-seal and Mix properly.
Then place this M-seal Mixer on nut and stick with stopper handle.
Wait for 3 hours for perfectly stick with stopper.
Step 5: Take Bolt
Take 2 Inch Bolt and Pass through out the nut.
Step 6: Connect DC Motor
First of all Take one syringe cap and cut 1 CM Portion using cutter.
Then take 100 RPM DC motor and connect with bolt using syringe cap.
Step 7: Stick DC Motor
Take Glue Gun and spread glue on wooden plate as per picture.
Then stick DC motor on this.
Step 8: Try Its Work or Not.
Try this model is working properly using direct wiring.
Step 9: Wiring Diagram for Circuit
Wiring DC motor and Battery Connectors as per wiring diagram.
Step 10: Packing of Circuit
Pacing circuit using Cap of Box.
Step 11: Connect Battery
Connect two 9 volt battery to connector.
Step 12: Enjoy
Try this wireless remote control locking system from 5 meter distance and place with doors.
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
