Space Saving Vertical Onion Planter
705
14
Published
Introduction: Space Saving Vertical Onion Planter
About: Crafty mama and wifey.
Small living space? No garden? You still can get fresh spring onions
every day - make a vertical onion planter that fits on your table or windowsill!
Step 1: Gather the Materials
  • Plastic bottle
  • Soil
  • Papīra nazītis
  • Onions to plant
Step 2: Cut the Top
Cut off the top of the bottle. The opening should be wide enough to put soil and onions in.
Step 3: Cut Holes
Cut small holes in the bottle. Each hole will hold 1 onion. If your onions are big, make sure they will fit into the bottle! (I made a small planter with 10 holes/onions. You could use a way bigger bottle and more onions if you like.)
Step 4: Add Soil
Put in the first layer of soil until it reaches the first holes.
Step 5: Add Onions
Place onions in the hole, pointy side facing up and out of the hole.
Step 6: Fill It Up
Keep adding soil and onions until the bottle is full. Water the onion planter to encourage growth. TIP: Is the soil is dry and/or water has trouble getting to the lowest onions, make some small cuts in the bottle below the onions and place the bottle in a bowl with some water. Soil will absorb moisture through the cuts and onions will be fine.
Step 7: Water and Harvest
Water and harvest! Water your onion farm daily and harvest the spring onions when they are green and ready (it may take about a week or more)! Here you can see how my onion planter looked after 3 days and 10 days (already managed to eat some :) )
TIP: You can plant the second batch in another bottle when the first spring onions have sprouted and got bigger, so you will have fresh ones all the time.
Planter Challenge
This is an entry in the
Planter Challenge
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    Very savvy and efficient!
