Introduction: Super Glue Accelerator and Filler
Picture of Super Glue Accelerator and Filler
No BS!! You use BS (Baking Soda)
With cracks, gaps and holes galore, baking soda has helped make my super glue the SUPER HERO it’s toted to be.
Often when creating or fixing we get gaps and holes that need filling.
Sure, you can use epoxy, wood filler or modeling clay, but if you already have the super glue and baking soda you can use it instead. Besides time sometimes is a factor. This is quick.
Here are some quick fixes with BS and Super Glue.
Step 1: Supplies!!!
Picture of Supplies!!!
Baking Soda
Super glue ( Liquid runny type) not gel.
Sanding tools
Small spoon
Tape
Paper towls
And of course cracks,holes,splits and divots. Or anything else you can think of .
Always remember when using Super glue be very careful.
Step 2: What the Two Really Do.
We can’t just fill with super glue, because it would take time to cure and may even seep out.
Cyanoacrylates are fast curing adhesives but not always designed for mass filling applications. That is where the true super hero comes to the rescue (Baking Soda).
When super glue meets Baking soda (sodium bicarbonate) it starts the polymerization process fast. There have been tests with other powders but nothing as readily available and affordable as BS.
Together they form a cement like substance that is extremely durable. Water as well accelerates the curing.
I will show variations on how you can use this super duo to repair and create in a flash.
Step 3: Filling a Hole to Accommodate a Eye Screw.
Picture of Filling a Hole to Accommodate a Eye Screw.
This is a threading bracket I made from recycled paintbrush handles.
The hole is large but I just needed to fill it in so I can put the eye screw in.
I simply tape the back put in a little baking soda, then a little super glue (the reason you want runny super glue is so that it penetrates the BS).
You also want to do in layers till it gets filled. Alternating between glue and baking soda.
After I put the first layer in, the screw is set in place. Back-fill around it as described. This helps the items to have tooth. Let rest a couple minutes dust away leftover BS, remove tape and finished.
This technique can be used in many ways. Just remember do not do on anything that is hanging or on an item that can cause damage, if it fails or can harm anyone.
Step 4: Broken and Cracked Tile.
Picture of Broken and Cracked Tile.
This tile was cracked and a chip missing. first the piece was glued together.
Then a little glue was put into crevasse then a little baking soda. Let it sit for a minute then wipe the surface. Nail sanders are used to flatten the repaired area.
I have done this type of fix many times. A bathroom tile area, counter top, foyer area. It can handle a normal amount of ware. But affordable enough to repeat if necessary.
A friend of mine was doing a new back splash and had purchased clearance tile. One of the tiles fell and broke causing this same type of problem, she was concerned about color. You can add color in powder form to the baking soda, eye shadow works well, matte colors preferred. Repair completed.
Step 5: Hole in What?
Picture of Hole in What?
Holes and cracks in wood plastic etc. Clean the area, fill in layers, sand and paint.
Test before staining, depends on stain used.
If the object being filled isn't for mechanical purpose, you can pack a hole with paper towel first, add some glue then finish with the baking soda and glue.
So just remember this is not the answer for every repair or creation but it is a Super quick way.
Always wear protective gear and be very careful!
Thank you! The Juliart
titchtheclown (author)2017-12-30
I use the opposite approach. Super glue first then sprinkle baking soda. Tip off exess baking soda and build in layers.
Hello! If you read the Instructable I do that on something’s and different on others. Just depends. Thank you for sharing.
submariner_ss (author)2017-12-25
Good improvisation. I am, however, inclined to use dedicated products for my filling needs. Acrylic adhesives are expensive. Siomething like$5for less than an ounce. Sure, if there is a time crunch go with the rubber bands & paper clips . approach
We are artists and crafters,so sometimes it’s about availability and money. We have dollar stores everywhere and it is only a dollar for the glue. Super glue / nail glue is a product most people have in a drawer and Bs in kitchen cabinet. It is just an option that works.
Those who have access to various materials can do just about any repair. And well as for time the average person is away from home for many hours so yep I guess it’s paper clips and rubber bands for some.
Thank you for your comments .
Anything that works for you is fine. My experience with super glues has had its ups and downs. The variety store “bottles” clog up at the tip. The good stuff costs an arm and a leg and also clogs t the tip. I have tried the latest Loctite variety and would recommend it highly. It sets very quickly so you may not need the BS. My personal favorite is titebond glue and course sawdust mixture. By the way,Ilikethediligent experimentation you did to develop your process.
I get it! I agree Loctite is in my arsenal. Thank you!
I have been a product developer for over 20 years and an artist all my life. I love testing things.
petrovich23 (author)2017-11-28
I used super glue and baking soda as a form of liquid bandage. It works well on fingertips.
What in Boy Scouts, we used to refer to as finger carving merit badge....
Super Glue has been used at least as far back as Vietnam for wounds:
https://www.google.com/search?q=super+glue+battlefield+wounds&ie=utf-8&oe=utf-8
Absolutely! It is still being used in the medical field. I Remember doing cross country running and we would super glue blisters. Truly is an amazing product! Thank you for your sharing. Some may not know this. Your Friend! Julia
The Juliart (author)petrovich232017-11-28
Very cool! Better than bleeding all over the place. And sounds like you got you badge:). My friends in school called me MacGyver, I had a pair of kangaroo shoes and carried survival items in the tongue and soul of the shoe. Now my purse!
Thanks for viewing the Instructable!
CoconutPi (author)2017-11-27
where do you get Runny SG? How wil I know it,s right? Canyoumould shapes with it? Thanks.
The Juliart (author)CoconutPi2017-11-27
If you see in my picture I do have a silicone mold,I decided at the last minute not to talk about that ,because it takes some practice. But yes it can, I use to make gears . But now I use resin. So in a pinch you can. Just need to pack tightly and let dry well.
CoconutPi (author)The Juliart2017-12-07
Thanks for your replies ☺ I noticed what looked like silicone moulds ... I thought it might be wishful thinking to want to mould with those... So superglue won,t bond or damage silicone? What I really want is a cheap, easy safe alternative to concrete for small projects. Also any ideas for cheap or free coloured plastic suitable for cutting and shaping easily and with minimal and most basic tools? Many thanks ☺
The Juliart (author)CoconutPi2017-12-07
No it won’t stick but it can etch the surface of silicone if repeating process.
How small is small? Jewelry or sculptures?
I use all plastics,from packaging,resins,styrene sheets. You can take packaging and cut out shapes ,form with hairdryer,embossing heat tool,etc.
It can be remolded and formed easy. Recycling is always #1
I cast with resins and they are fairly affordable and can be clear or colored. You can use shape-crete it is a fiber reinforced Portland cement product used for art. Like a clay.
Maybe polymer clay it is priced good and lots of coupons. Toaster oven and it bakes hard. Just some ideas. There are lots of Instructables on all of these materials so you are never alone when creating! Will always help!
Thanks☺☺ It would be more likes small sculptures. There are two main objectives, to create attractive garden ornaments and artificial plants to fill out may garden "" while I wait for the real plants to take hold, and to protect the area from being driven on and protect the plants. Possibly both at the same time. Trouble is I don,t have transport or a suitable outdoor work space or much of an indoor workspace... It has to look good enough not to get thrown out, but not worth stealing. Similar dilemma with planting bulbs, to plant deep enough I need to use a container, but won,t have room for one that,s too heavy to lift.
Here is my suggestion then use the plastics that you recycle to create the art. Minimum room required and as needed and of course if it doesn’t turn out you can recycle. Next we save packing foam and block foam to create insulated planting chambers. And line them. And add a couple holes for drainage. Then when the get big enough you transplant or put bigger holes gor roots. I sculpt with aluminum foil ,paint and put outside. Wish you the best. Julia
Roughly what ratio of bicarbonate of soda to superglue do you use? Thanks ☺ BTW I used the method to splint a broken leaf on one of my plants!
It’s about 2 parts BS to one part glue. It really depends on how and what you fill. I just look for the BS to turn from white to a gray color. Like when you wet sand. Hope that helps.
Hello! Most of the thin wicking super glues are sold for hobbyists. Just choose one that doesn’t say gel or thick. You can still use them ,but if you do I mix on a plastic sheet with the baking soda and then quickly press in to place.
Some of the cheap super glues are runny like fake fingernail glue.
Hope that helps.
2 left thumbs (author)2017-12-04
Thanks for this super Instructable
When adding the superglue, do I have to worry about using 'too much' super glue?
Step 3 - what's the rule of thumb for how thick a layer should be?
Hello! Thank you! Largest repair for me was 1/4” deep 1 1/4” x 2”. You just want to add a little drop of glue to the top of BS and watch ,it should immediately wick in. You can build up layers no problem . Like water to a sponge. Do watch how much glue for sure. If the glue is puddled it will take more time to cure . The bs will be like snow or wet sand , it is a packed texture.
If my holes are deep,I do pack with tissue first and add a drop of glue , so like 3/4 of the way. Then finish with BS ,and super glue.
It should make a hard sound when tapped.
Whatever you don’t put a hairdryer or heat gun to the patch. You can create fumes that can harm you. Hope this helps. Turns light gray when absorbed. Thank you! Julia
loiscwright (author)2017-11-27
julia, as always you teach us so much! Thanks for your time!
The Juliart (author)loiscwright2017-11-27
So very welcome,!
lboliq (author)2017-11-27
Absolutely great!
The Juliart (author)lboliq2017-11-27
Thank you for thinking so!
Have a great week! J
Gofish (author)2017-11-26
Great for Guitar repairs too.
http://www.frets.com/HomeShopTech/hstpages.html
SherylinRM (author)Gofish2017-11-26
I have actually used super glue to emergency repair the nut and build one up a tad. Worked great.
Thanks for the memory :)
The Juliart (author)SherylinRM2017-11-26
That is great! I think it’s great for people to hear about lots of uses and techniques! Thank you!
The Juliart (author)Gofish2017-11-26
Thank you for sharing the link and viewing my Instructable!
SherylinRM (author)2017-11-26
Nice one. I like the tip of using runny glue. I think many of us would have chosen the gap filling one.
Nice heads up. Voted for you :)
Thank you so much! I teach a lot of creative workshops and just helps save some money and time for sure.
ItsGraGra (author)2017-11-26
Fine sawdust mixed with PVA wood glue makes a great wood filler.
The Juliart (author)ItsGraGra2017-11-26
Yes it does! Super glue is just pretty much instant. So depending on your project. Thank you for sharing!
ItsGraGra (author)The Juliart2017-11-26
Super glue cures super hard.
When sanding (by hand) wood or anything softer than the super glue, I find the super glue area is left higher than the surrounding wood. Even when using a flat sanding block.
Machining is ok, no problem.
I have built model aircraft with super glue, it's very quick and easy but as the super glue soaks right through the balsa wood, sanding is a real problem for the reason I mentioned above.
Sparks135 (author)2017-11-26
Where would one buy colored powders?
The Juliart (author)Sparks1352017-11-26
Hello! You can use eyeshadows, mica powders,glow powders etc.
I get them from technoglow, paint with pearl, mason stains .
Ebay and Amazon.
Hope that helps.
Sparks135 (author)The Juliart2017-11-26
Thank you.
Thanks, I have some small holes in my ceramic tile from screws.
You can use grout powder color. Or if you have scrap of the tile ,if it’s solid color all the way through. You can drill the scrap to get powder and use it. Just ideas.
Thank you for all the suggestions, once the doors are removed I will try my luck.
toasterizer (author)2017-11-26
The fine sawdust that collects inside my bandsaw makes a great superglue filler as well. Doesn't dry as fast as baking soda, but the bond is very strong.
The Juliart (author)toasterizer2017-11-26
Thank you toasterizer for helping give people more idea!
Keep up the good work!
JohnG491 (author)2017-11-26
I use this technique when i work on repairing guitar nuts and inlays. Never fails
The Juliart (author)JohnG4912017-11-26
I am so glad to have others who use this process. It will help lots of people.
Thank you! Julia
GerhardusS (author)2017-11-26
To keep superglue fresh put it in a deep freeze when not in use at less than 10 degrees centigrade I used superglue three years after opening it. To see if it is still useable if it is like water in the container it still works but if it is jelly it is kaput
The Juliart (author)GerhardusS2017-11-26
Thank you so much for sharing. This will help lots of people who read the post. I fill large hole with paper and then back fill with super glue and BS or other things.
Depends on what I’m working on.
Thank you! Julia
itsmescotty (author)2017-11-26
I might give this a try but my go to method is (depending on finish requirements) epoxy (quick or slow depending on when it needs to be functional).
Whatever the base material is I use the closest match in color/material and grind or sand the amount necessary for the filler then combine the epoxy and filler to whatever consistency I want then fill. This method can be drilled, sanded AND is structural. Much the same as JB Weld only you control the consistency and content of the filler - wood, steel, aluminum and PVC. They make a water clear casting epoxy in case anyone is worried about the epoxy yellowing.
RicksterInstructables (author)2017-11-26
Thank you for the Instructable.
I sometimes use wads or pieces of paper towel.
It cures astonishingly fast.
It produces a result that can be cut/shaped with a knife or sanded.
And I feel that the paper fiber adds strength.
mountainfish (author)2017-11-26
This is great! Thank you for sharing. I hope that I remember this because it seems like something that could come in very handy.
The Juliart (author)mountainfish2017-11-26
Your welcome! Yes I find myself needing something quick and as a filler and it works. Just tools and tricks for the diy arsenal .
Thank you! Julia
About This Instructable
11,107views
113favorites
License:
Bio: Make no mistake I love to create!!! Owner Lake Studio for the Arts. Invest in your community by sharing, what you know,so all can ... More »
More by The Juliart:Aluminum & Resin Rainbow Nebula Quick Chemical Dispensing Edible Centerpiece W/ Dr.Bird Cake
Add instructable to:
