The Multi Wooden Piece
2,038
33
11
Published
Introduction: The Multi Wooden Piece
About: HMN41 Creations
In this instructable I will show you how to make The Multi Wooden Piece which has several uses in the decorative field and other fields. Woodworking is one of the most things that I love to create and work in as a hobby. Woodworking is a big world to choose what your gonna work on, so I decided to create a unique piece of wood (hand maded "a lot of hard work") that anyone can use it in different ways and forms, like a vase, a wooden egg......, up to 13 different uses as shown below.
Important Note : This instructable is characterized by it's sustainability over the years.
Step 1: Tools and Materials
In this instructable you will need:
  • hand sander
  • scissor
  • cutter
  • wood
  • drill
  • hole saw drill bits
  • white glue
  • paper sander
Step 2: Drill
  • Drill three wooden circles using 2" or 2.5" hole saw drill bit.
  • Drill two wooden circles using 1" hole saw drill bit.
In this part I was going to drill all the 5 circles of the same size but then I realize that the upper one's will be sanded so I drill 2 circles smaller than the other's.
Step 3: Ready Wooden Circles
In this project no matter what kind of wood you prefer to use, but as good as you choose the kind of wood your project will be more attractive. Here's I use Oak which is one of the most popular woods utilized in furniture and craft making. There are many varieties of oak, but most have very similar qualities for woodworking. While oak has a very distinct, sought-after appearance which will be more decorative, it can be a difficult wood to work with especially while drilling and sanding. However, handmade makes always is been difficult while building a crafty wood but on the other hand it always get great results.
Step 4: Glue Them Up
This part is pretty easy, but be carefull while glueing to combine the wooden circles in a way to be centered on the same axis, here you will use a strong white glue and put an enough amount on each side of the wood parts, then press them togther to prevent the apearnce of air holes between each circle that will affect on the view after sanding, keep them tight for 6 to 8 hours.
Step 5: Sanding Tools
Sanding nowdays has been developed using like electric sandee but here in my project I used only sand paper to be hand maded and I also created a small sander tool to put in the drill just for the hard parts in the project as shown in the video above.
Step 6: Sanding
This part is the hardest one above all the steps since you will keep sanding and sanding and.....
So first after glueing it, start to sand it with rough grit sandpaper, then move toward fine grit sandpaper. Beside be carefull while sanding to preserve the shape of the wood.
Step 7: The Upper Hole
This step is optional, if you wanna keep it as it is it's not nessaccery to apply it, but here I prefered to make a hole using 3/4" hole bit to be able to add some other parts to decorate it.
Step 8: Sand After the Hole
After drilling a hole in the upper part of the wooden piece use a sand paper to smooth it from above.
Step 9: Ready to Polish
Keep sanding until you get the perfect surface for polishing.
Step 10: Polishing
After sanding, use a piece of fabric to polish the wooden peice until it gets that bright attractive view.
Step 11: Vase
You can drill a path through the center of the wooden piece to put such beautiful flowers in it, so you consider it as a gift for someone with these flowers or you can keep it as decorative vase.
Step 12: The Secret Letter
Using the same hole, you can write a secret letter and hide it in this secret part of the wooden piece and then you can cover it with some decorative materails.
Step 13: Decorative Egg
It's aleardy have the shape of a decorative egg.
Step 14: Gift
You can simply give it as a gift.
Step 15: Container (box)
You can close it using a wooden cover.
Step 16: Candle
Make it a candle by fitting it in the upper hole.
Step 17: Lighter
Add this classic lighter to the upper hole.
Step 18: Key Holder
Attach a rope to the wooden cover and connect it to the key.
Step 19: Ring Box
You can put a ring inside it and present it as a gift.
Step 20: Flash Light
Add a lid to the upper hole using hot glue.
Step 21: Pineapple
Add artificial leaves to the upper hole to make an wooden pineapple.
Step 22: Cigarettes Ash Container
Add an aluminum cover to the upper hole and make it as cigarettes ash container
Step 23: The Master Stick
You can add a stick through the upper hole.
Step 24: ?
Sorry there was a video to present but unfortunately an network error happens while uploading it, the video was not uploaded after I deleted it from my storage, So the video is gone.
Woodworking Contest
This is an entry in the
Woodworking Contest
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    Sand the top & bottom of each disk prior to Step 4
    1 Questions
    this one i use in such hand maded projects
    11 Comments
    Great job man keep on keep in on with your woodworking.
    Thank you very much!
    Vote for me if you like it ⬆️⬆️
    Thank you
    Vote for me if you like it⬆️
    Wonderful instructable. I definitely have to get me some of those grinding tools for doing things like this.
    Thank you
    Thank you
