Introduction: The NanoStillery™ - Automated Whiskey Distillery
Picture of The NanoStillery™ - Automated Whiskey Distillery
Historically, in Europe at least, it used to be very common for enterprising folk to travel around the land with their distillation equipment strapped to the sides of their donkeys providing a valuable service for owners of orchards and fruit bushes who wanted the produce turned into alcohol rather than having it wasted or eaten by birds and rats. In modern times, due to the advances of science, the equipment necessary for the process is much more sophisticated, but could, in theory, still be strapped to the back of a donkey.
It's not an old wives tale - The process of distillation used to be rather dangerous, often involving the lethal combination of naked flames, self intoxication and explosive alcohol vapours. Now, thankfully, there is much more awareness of sensible drinking and the potential dangers of industrial processes.
For me, the challenges are to automate the machine and make it as safe as reasonably possible, giving us lots of scope for using all kinds of weird and wonderful gadgets and sensors to monitor the process and minimise the risk of explosion.
Disclaimers:
  • Distilling alcohol is illegal in many parts of the world so check out your local laws. Often, there is also a tax to pay on the product.
  • Alcohol vapour is potentially explosive. Explosions can be triggered by naked flames, relay switch contacts, hot surfaces, cigarette smoking, mobile phones etc.
  • This design uses 240 v power and should be wired up by a qualified electrician.
  • Most beer and wine contains small quantities of methanol which need to be removed during the distilling process. Methanol is a neuro poison that causes permanent nerve damage with symptoms such as blindness.
  • Always drink in a responsible manner. Don't make your own spirits if you're prone to alcohol addiction.
Step 1: Features
Picture of Features
  • Alcohol vapour detection and automatic machine shut down.
  • Safe heating with 'under floor' heating coil.
  • Fully automatic - just press the start button - includes all pumps and valves.
  • Inline hydrometer to automatically remove methanol.
  • M2M and IoT (Machine to machine and Internet of Things) technology.
  • Real-time custom made webpage graphical display for quality control.
  • GPRS cellular network data transmission to online database - no wifi required.
  • Audio messages for machine status and error warnings.
  • Stainless steel and copper fabrication.
  • Easy boiler cleaning.
  • 4 different temperature sensors.
  • Small, lightweight and compact for transport by donkey.
Step 2: How It Works
Picture of How It Works
Home made beer or cider is pumped into the boiler and then rapidly heated to about 85 degrees C after which the power is reduced and the alcohol starts to boil off. Vapour travels into an air cooled condenser and then trickles out the other end into an inline hydrometer.
The hydrometer is connected to a pressure sensor which detects the level of fluid at any given time and a solenoid 'dump valve' at the bottom of the device allows the product to be dumped into a separate container to separate out the methanol.
The rest of the product goes into the conical flask and the process finishes when the boiler temperature hits a preset level controlled by a potentiometer on the control panel.
To learn how to distill home brew into alcohol, check out my purpose made instructable HERE.
Step 3: The Boiler
Picture of The Boiler
A great deal of the work involved was in making the boiler. The 3D image above hopefully should show how it is put together.
Step 4: The Boiler - Parts
Picture of The Boiler - Parts
  • 10 litre Cornelius type keg
  • 1500 watt counter top electric hotplate element
  • Flanges and discs - see files attached.
  • 2" stainless steel half socket
I did consider making my own heating element or even using an inductor coil, but the desire for a simpler life got the better of me. The same is true of using the smart looking stainless keg. The boiler needs to have an access lid large enough to get your hand in for cleaning the inside and the heating elements must not protrude into the keg so need to be underneath or around the sides or both. Protruding elements would be far easier but they are dangerous as if they are not fully submerged in liquid they can glow red hot and ignite the alcohol fumes - AVOID!
Step 5: Boiler Fabrication - Keg and Outer Skin
Picture of Boiler Fabrication - Keg and Outer Skin
The boiler is double skinned to provide some degree of insulation. The bottom of the keg is removed, the outer cylinder has a flange welded onto it to connect to the top of the keg and the keg has a hole cut in it at 45 degrees to accept the 2" socket.
The 10 litre keg, though of very high quality manufacture, is made of very thin stainless steel which makes it very difficult to weld without over heating it and forming a large hole. I used a combination of MIG and TIG techniques and it probably took me about 2 days until I got it leak proof.
The boiler was tested for leaks after the reflux pipe was finished and attached. This made it easy to attach a compressed air supply and pressurise the whole thing to about 30 psi. A bit of soapy water sprayed on the outside revealed the leaks when it formed bubbles.
Step 6: Boiler Fabrication - Weld in the 2" Socket
Picture of Boiler Fabrication - Weld in the 2" Socket
The brass connector is screwed into the 2" socket to prevent distortion and splatter on the threads during welding.
Step 7: Boiler Fabrication - Heating Element
Picture of Boiler Fabrication - Heating Element
The thick stainless disc (see attached dwg files) is welded onto the bottom of the keg and the 1500 watt heating element assembly is bolted onto it with some thermal grease in between. It is then slotted into the keg and wired up for 240 volts. The heating element was extracted from an electric hotplate found on ebay.
Fortunately, the heating element worked really well and the thick stainless disc helped even out the heat when the electricity supply was pulsed on and off at 10 second intervals to reduce the overall power.
Step 8: Reflux Pipe
Picture of Reflux Pipe
Parts:
  • 6620 3/8" x 1/4" BSP HEX REDUCING BUSH, BRASS
  • 6620 3/8" x 1/4" BSP HEX REDUCING BUSH, BRASS 4 £0.20 £0.80
  • 6621 1/2" x 1/4" BSP HEX REDUCING BUSH, BRASS 4 £0.49 £1.96
  • 6675 6 mm COMP x 1/4" BSP TM, ADAPTOR, UK 4 £1.36 £5.44
  • 6705 15 mm COMP COUPLER, UK 2 £0.90 £1.80 6768 15 mm COUPLING, EF 4 £0.08 £0.32
  • 6787 15 mm x 10 mm FITTING REDUCER, EF 2 £0.25 £0.50
  • 6798 15 mm EF, 90° ELBOW 4 £0.13 £0.52
  • 6809 15 mm EQUAL TEE, EF 4 £0.26 £1.04
  • 7160 54 mm EF x 2" BSP TM STRAIGHT ADAPTOR 1 £13.81 £13.81
  • 7958 35 mm x 15 mm FITTING REDUCER, EF 1 £1.30 £1.30
  • 7984 15 mm OBTUSE BEND 45°, EF 4 £0.35 £1.40
  • 8280 2" BSP PLAIN HOLLOW PLUG, BLACK 1 £2.12 £2.12
  • 9175 42 mm x 35 mm FITTING REDUCER, EF 1 £2.15 £2.15
  • 9177 54 mm x 42 mm FITTING REDUCER, EF 1 £4.07 £4.07
  • 14360 1/4" BSP HALF SOCKET, 316 S/S 3 £0.48 £1.44
  • 14367 2" BSP HALF SOCKET, 316 S/S 1 £4.33 £4.33
  • 14479 2" BSP TM, WELDING NIPPLE, 316, S/S 1 £4.16 £4.16
The reflux pipe is made of a series of brass and copper reducers which go from 2" to 15mm in size. The parts are soldered up using lead free solder to help prevent heavy metal poisoning. Paradoxically, copper is thought to be beneficial as the copper will react with the acid sulphurous fumes and remove sulphur by falling back into the boiler. Unfortunately, some of it will carry on into the condenser which will contaminate the product with copper ions. These can be detected by using a conductivity meter and removed with ion exchange resins at a later stage if necessary.
During the heating process, the fluid vapours will react with the copper in the reflux tube and also the fluid itself will react with pieces of copper tube cut up and dropped into the boiler.
Step 9: The Condensor
Picture of The Condensor
Parts:
  • 5912-QG030-353/12, MFG Part No:QG030-353/12, ebm-papst Blowers, TARIC:8414592090 ECCN:EAR99 COO:HU
  • 3/8 radiator tube with 15/16" discs.
Normally, the condenser would be made with water cooling, but I did not want the hassle of having running water in this system so I opted for air cooled instead.
A 3/8" pipe was fitted with special cooling discs (Anybody know what they're called?) and a condenser assembly was fabricated. The actual power of the system is estimated to be about 500 watts.
During operation, the boiler is programmed to reduce it's effective power after it passes the 85 degrees C mark. Looking at the graph on the features step, the heating curve shows where the power was reduced and how the increase in temperature slopes off to an almost flat line. At this point, the temperature increases very slowly as the boiler itself is 'cooled' by the vapours being emitted. It's very important not to 'over cook' the condenser or else vapour will be emitted from the breather pipes.
Step 10: Frame
Picture of Frame
Parts:
  • 20 x 20 x 3 mm steel box section x 12m
The frame allows all the components to be mounted securely which is important for reliability and safety. Remember we have potentially explosive vapours and 240 volt electricity.
Step 11: Hydrometer
Picture of Hydrometer
This elaborate pipe fabrication allows the alcohol product to be split off at different parts of the process and has a very sensitive pressure sensor chip in the control panel that senses the level of fluid in the main tube. More is explained in a separate instructable HERE.
The hydrometer allows the 'foreshots' to be automatically separated from the distillate produced by detecting the level of fluid in it's pipework. After this, during the rest of the process, it can indicate the concentration of alcohol being produced although at present it's not really accurate enough to give very meaningful results. I might upgrade this to a capacitance probe if I can bench test one successfully.
Step 12: Breather Pipes
Picture of Breather Pipes
Many parts of the system require a breather pipe to the outside eg the receiver tank for the product and the cold end of the condenser. The exception is the boiler itself as it vents directly through the condenser.
All the breather pipes are yellow and are quite small as during normal operation they only vent a very small amount of vapour/air. If there is a major malfunction in the machine, which would necessitate multiple safety failures, then the tubes will vent excess pressure.
Step 13: Alcohol Vapour Detector Probe
Picture of Alcohol Vapour Detector Probe
Parts:
The orange MQ-3 module is wired up, tested, and slotted into a 20mm tube and permanently embedded in epoxy resin. This is the best way of protecting the connections against shorting and giving strain relief for the cable itself.
The sensor is easy to use but does use quite a lot of power - it has a very small heating element inside it. For this reason, the machine must never be powered from the USB cable going to the Arduino Mega or the Mega's onboard power supply will be destroyed. The sensor needs to be wired directly to the main power supply and can be isolated with a Schottky diode.
Step 14: Control Panels
Picture of Control Panels
Parts:
There are 3 panel boxes in the NanoStillery™, the main panel is driven by an Arduino Mega and the secondary one houses an Adafruit Feather GPRS board for transmitting data to the interweb. The third box has a large 12 volt power supply and a bank of relays in it.
More details of how the system talks to itself and the outside world is detailed in a separate instructable here: Machine ⇒ I2C ⇒ GPRS Cellular Network ⇒ DIY Webpage
The main control panel receives information from the various sensors in the system - temperatures, pressure and alcohol vapour levels and controls various valves, pump and the boiler heater via the relays. It then communicates with the Adafruit Feather via the I2C bus which then sends the data to a database where it is accessed from this webpage: NanoStillery
The GPRS module could very well have been bolted into the main control panel, but, for one, I had run out of room and secondly, I wanted the module to be removable so that it could be used for other projects in the future. Getting the two 'machines' to communicate with each other effectively was quite challenging. It was ok if the numbers were just simple small integers, but as soon as more complex 'floats' were involved, some serious number crunching code had to be developed. This can be seen in the 'Code' step.
Step 15: Electrical Schematics and Parts
Picture of Electrical Schematics and Parts
Electrical parts:
  • DS2 DS18B20 1-Wire Temperature Sensor Probe Cable
  • DS3 DS18B20 1-Wire Temperature Sensor Probe Cable
  • DS4 DS18B20 1-Wire Temperature Sensor Probe Cable
  • DS5 DS18B20 1-Wire Temperature Sensor Probe Cable
  • IC1 Voltage Regulator chip 78005; variant sink; voltage 5V; package to220-igo
  • J1 Piezo Speaker LCD1 LCD screen type Character; pins 16 LED1 Red (633nm)
  • LED color Red (633nm); leg yes; package 5 mm [THT]; part # GPRS CONNECTED
  • LED2 Red (633nm) LED color Red (633nm); leg yes; package 5 mm [THT]; part # DATA RECIEVED
  • Part1 Adafruit Feather 32u4 FONA variant variant 1; part # Adafruit #3027
  • Part2 Arduino Mega 2560 (Rev3) type Arduino MEGA 2560 (Rev3)
  • Q1 NPN-Transistor type NPN (EBC); package TO92 [THT]
  • Q2 NPN-Transistor type NPN (EBC); package TO92 [THT]
  • Q3 NPN-Transistor type NPN (EBC); package TO92 [THT]
  • Q4 NPN-Transistor type NPN (EBC); package TO92 [THT]
  • Q5 NPN-Transistor type NPN (EBC); package TO92 [THT]
  • R1 Rotary Potentiometer (Small) type Rotary Shaft Potentiometer; size Rotary - 9mm; maximum resistance 100kΩ; track Linear; package THT
  • R4 4.7kΩ Resistor tolerance ±5%; pin spacing 400 mil; bands 4; package THT; resistance 4.7kΩ
  • R5 100Ω Resistor tolerance ±5%; pin spacing 400 mil; bands 4; package THT; resistance 100Ω
  • R6 1kΩ Resistor tolerance ±5%; pin spacing 400 mil; bands 4; package THT; resistance 1kΩ
  • R7 1kΩ Resistor tolerance ±5%; pin spacing 400 mil; bands 4; package THT; resistance 1kΩ
  • R8 1kΩ Resistor tolerance ±5%; pin spacing 400 mil; bands 4; package THT; resistance 1kΩ
  • R9 1kΩ Resistor tolerance ±5%; pin spacing 400 mil; bands 4; package THT; resistance 1kΩ
  • R10 1kΩ Resistor tolerance ±5%; pin spacing 400 mil; bands 4; package THT; resistance 1kΩ
  • R11 Rotary Potentiometer (Small) type Rotary Shaft Potentiometer; size Rotary - 9mm; maximum resistance 100kΩ; track Linear; package THT; part # HEATER
  • R12 Rotary Potentiometer (Small) type Rotary Shaft Potentiometer; size Rotary - 9mm; maximum resistance 100kΩ; track Linear; package THT; part # PUMP TIMER
  • R13 Rotary Potentiometer (Small) type Rotary Shaft Potentiometer; size Rotary - 9mm; maximum resistance 100kΩ; track Linear; package THT; part # END TEMPERATURE
  • R14 10kΩ Resistor tolerance ±5%; package 2512 [SMD]; resistance 10kΩ
  • R15 10kΩ Resistor tolerance ±5%; package 2512 [SMD]; resistance 10kΩ
  • R16 1kΩ Resistor tolerance ±5%; package 2512 [SMD]; resistance 1kΩ
  • R17 1kΩ Resistor tolerance ±5%; package 2512 [SMD]; resistance 1kΩ
  • S1 SWITCH-MOMENTARY-2 variant 12mm; package tactile-pth-12mm
  • S2 SWITCH-MOMENTARY-2 variant 12mm; package tactile-pth-12mm
  • U1 RELAY-2 variant g5q; package relay-g5v; part # HYDROMETER DUMP
  • U2 RELAY-2 variant g5q; package relay-g5v; part # PUMP LH
  • U3 RELAY-2 variant g5q; package relay-g5v; part # PUMP RH
  • U4 RELAY-2 variant g5q; package relay-g5v; part # HEATER
  • U5 RELAY-2 variant g5q; package relay-g5v; part # PUMP
  • U6 GAS_SENSOR package mq-3 VALVE1 Plastic Solenoid Valve part # HYDROMETER DUMP
  • VALVE2 Plastic Solenoid Valve part # PUMP LH VALVE3 Plastic Solenoid Valve part # PUMP RH
  • VCC1 Battery block 9V voltage 9V; part # 12V (NOT 9V)
  • VCC2 4 x AAA Battery Mount voltage 4.8V
Step 16: Pump and 3 Way Valves
Picture of Pump and 3 Way Valves
Parts:
This system allows the same pump to be used for filling and emptying the boiler, depending on how the 3 way valves are set. The pump itself is a diaphragm type that is self priming so can be positioned anywhere in the frame.
The pump and valves are controlled via small 'sugar cube' 12v relays. Some of the relays or perhaps the solenoids, I'm not sure, interfered with the LCD screen for a while but this was cured by using large 470uF capacitors wired in parallel with the offending device. The capacitors must not be too large or else the solenoids would not open quick enough.
Step 17: Arduino Mega Code
Picture of Arduino Mega Code
The code in the main control panel is fairly standard except for the part which sends data down the I2C bus to the Adafruit Feather slave. This code can be found in 'void sendData()' below and involves disassembling complex float numbers eg 89.29 and turning them into a string and then using character manipulation to turn them into a seires of individual integer digits, ie 8 ...9 ...2 ...9. To make it even more complicated, each series of integers had to have an identification marker so that the slave could recognise that a particular stream of digits had been initiated and it had to also have a number representing the number of digits being sent (string length) AND, just to completely fry my already half cooked brain, the digits themselves had to be sent back to front!
#include <Adafruit_ADS1015.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <Wire.h>
#include <LiquidCrystal.h>
#define ONE_WIRE_BUS 10
#define TEMPERATURE_PRECISION 12
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress sensor0,sensor1,sensor2,sensor3;
char digitCharAAAA[10];
char digitCharBBBB[10];
String testAA;
String nothing;            // This is important - the string precursor.
String testAAAA;          // File names need to be of sufficient complexity!
String testBBBB;
int stringLengthAA;
int numberId =101;
int dataPrecursor = 198;  // A randomish number below 254. Be careful it does not conflict with numberIds.
int digitAAAA;
float tempZ=20.01;
int n = 0;
unsigned long currentTime=0;
unsigned long previousTime=0;
unsigned long intervalTime=0;
float tempC;
int deviceCount =0;
float boilerTemp;
float refluxTemp;
float hydroTemp;
float condensorTemp;
float previousTempC =0;
float totalTempC=0;
float deltaTempC =0;
float previousDeltaTempC =0;
float doubleDeltaTempC =0;
Adafruit_ADS1115 ads;  /* Use this for the 16-bit version */
// Adafruit_ADS1015 ads;     /* Use thi for the 12-bit version */
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
byte delta[8] =
  B00000,
  B00100,
  B00100,
  B01010,
  B01010,
  B10001,
  B11111,
  B00000
byte percent[8] =
  B11001,
  B11010,
  B00010,
  B00100,
  B00100,
  B01000,
  B01011,
  B10011
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
const int densityEthanol = 789;
long sensorValue = 0;        // value read from the pot
int outputValue = 0;        // value output to the PWM (analog out)
int outputValueMin = 1000;
int outputValueMax = -1000;
int loopToStart =0;
int a=0;
int i=0;
int k=0;
int c=0;
int x=0;
int z=0;
int y=5;
int h=0;
int f=0;
int T00=0;
int T01=0;
int T02=0;
int T03=0;
int T04=0;
int T05=0;
float endTemp =0;
int alcoholCount=0;
float alcoholX=10.00;
int alcoholLimit=550;
double potReading01=0;
double pumpTimer1=0;
double pumpTimer2=0;
int pumpTimer3=1;
int pumpTimer4=0;
int adjustmentTimer=200;
int mappedPotReading01=0;
int potReading02=0;
int mappedPotReading02=0;
int potReading03=0;
double powerFactor=0;
int levelSwitch =HIGH;
int foreshotsDumpValue =0;
int startAndEndDumpValue =0;
int tempCount=0;
int momentarySwitchStatus =0;
int mins=0;
double ethanol =0;
float av=0;
long totalAdjustedOutputValue=0;
int adjustedOutputValue = 0;
float hrs=1;
double pressure =0;
double avPressure =0;
//Digital pins:
//D13:
//D12:LCD
//D11:LCD
//D10:TEMP01
//D09:Relay
//D08:Dump relay
//D07:Relay for equalising hydrometer pressure
//D06:Heater relay
//D05:LCD
//D04:LCD
//D03:LCD
//D02:LCD
//Analogue pins:
//A0:Tone
//A1:Pot
//A2:Pot
//A3:Pot
//A7:Alcohol
void setup()
  pinMode(A8, INPUT_PULLUP); // Boiler level switch
  pinMode(6, OUTPUT); // Relay for heater
  digitalWrite(6, LOW);
  pinMode(8, OUTPUT); // Relay for dump valve.
  digitalWrite(8, LOW);
  pinMode (13, OUTPUT); // Relay
  digitalWrite(13, LOW);
  pinMode (7, OUTPUT); // Relay
  digitalWrite(7, LOW);
  pinMode (9, OUTPUT); // Relay
  digitalWrite(9, LOW);
// External relays: 47,49,51,53
  pinMode(47, OUTPUT); // Relay for NOT USED
  digitalWrite(47, HIGH);
  pinMode(49, OUTPUT); // Relay for PUMP
  digitalWrite(49, HIGH);
  pinMode(51, OUTPUT); // Relay for RH valve
  digitalWrite(51, HIGH);
  pinMode(53, OUTPUT); // Relay for LH valve
  digitalWrite(53, HIGH);
 // pinMode (A1, OUTPUT);  //SFX T02 alcohol levels exceeded
 // pinMode (A2, OUTPUT);  //SFX T03 seventy degrees
//  pinMode (A3, OUTPUT);  //SFX T04 ninety five degrees
  pinMode (23, OUTPUT);  //SFX ..............
  pinMode (25, OUTPUT);  //SFX ..............Finished
  pinMode (27, OUTPUT);  //SFX ..............Alcohol too high
  pinMode (29, OUTPUT);  //SFX ..............70 degrees
  pinMode (31, OUTPUT);  //SFX ..............95 degrees
  pinMode (33, OUTPUT);  //SFX ..............Heater turned on
  pinMode (35, OUTPUT);  //SFX ..............Process initiated
  pinMode (37, OUTPUT);  //SFX ..............Dump valve opened
  pinMode (39, OUTPUT);  //SFX ..............Temperature is rising
  pinMode (41, OUTPUT);  //SFX ..............Now producing alcohol
  pinMode (43, OUTPUT);  //SFX ..............
                         //SFX T06
                         //SFX T07
//  digitalWrite(A1, HIGH);
//  digitalWrite(A2, HIGH);
//  digitalWrite(A3, HIGH);
  digitalWrite(23, HIGH);
  digitalWrite(25, HIGH);
  digitalWrite(27, HIGH);
  digitalWrite(29, HIGH);
  digitalWrite(31, HIGH);
  digitalWrite(33, HIGH);
  digitalWrite(35, HIGH);
  digitalWrite(37, HIGH);
  digitalWrite(39, HIGH);
  digitalWrite(41, HIGH);
  digitalWrite(43, HIGH);
  digitalWrite(35, LOW);
  delay(500);
//  digitalWrite(11, HIGH);
  Serial.begin(115200);
  lcd.createChar(1, delta);
  lcd.createChar(2, percent);
  lcd.begin(20, 4);
  lcd.setCursor(0,0);
  lcd.print("    DISTILLATION    ");
  lcd.setCursor(0,1);
  lcd.print("     INITIATED      ");
////////////////////////////////Wait for MQ3 to warm up //////////////////////////////////////////
  delay(3000);
  alcoholX = analogRead(A7);
  while (alcoholX>alcoholLimit)
    tone (A0,alcoholX*2,200);
    delay(500);
    lcd.setCursor(0,0);
    lcd.print("Wait for MQ3 Heater ");
    lcd.setCursor(0,1);
    lcd.print("                    ");
    lcd.setCursor(0,2);
    lcd.print("Alcohol:");
    lcd.setCursor(9,2);
    lcd.print(alcoholX);
//Temperature stuff
  sensors.begin();
  // locate devices on the bus
  Serial.print("Locating devices...");
  Serial.print("Found ");
  deviceCount = sensors.getDeviceCount(), DEC;
  Serial.print(deviceCount);
  Serial.println(" devices.");
  if (!sensors.getAddress(sensor0, 0)) Serial.println("Unable to find address for Device 0");
  if (!sensors.getAddress(sensor1, 1)) Serial.println("Unable to find address for Device 1");
  if (!sensors.getAddress(sensor2, 2)) Serial.println("Unable to find address for Device 2");
  if (!sensors.getAddress(sensor3, 3)) Serial.println("Unable to find address for Device 3");
  sensors.setResolution(sensor0, TEMPERATURE_PRECISION);
  sensors.setResolution(sensor1, TEMPERATURE_PRECISION);
  sensors.setResolution(sensor2, TEMPERATURE_PRECISION);
  sensors.setResolution(sensor3, TEMPERATURE_PRECISION);
  Serial.print("Device 0 Address: ");
  printAddress(sensor0);
  Serial.println();
  Serial.print("Device 1 Address: ");
  printAddress(sensor1);
  Serial.println();
  Serial.print("Device 2 Address: ");
  printAddress(sensor2);
  Serial.println();
  Serial.print("Device 3 Address: ");
  printAddress(sensor3);
  Serial.println();
  Serial.println("");
  printTemperature();
  lcdTemperatures();
  delay (4000);
    pinMode(28, INPUT_PULLUP);   // Momentary switch
    ads.begin();
  previousTempC = tempC;
  totalTempC = -1*tempC;
  delay (4000);
  lcd.clear();
void loop()
// Send data to the Feather Nestbox every 2 minutes:
currentTime = millis();
intervalTime = currentTime - previousTime;
Serial.print("Current time: "); Serial.print(currentTime/1000);Serial.print(" Secs ");Serial.print(currentTime/60000);Serial.println(" Minutes");
if (intervalTime > 120000)
// Send data to the feather HERE.
   Serial.println("Now we are doing a transmission ....... ");
   Serial.println("");
   lcd.setCursor(0,3);
   lcd.print("Transmitting data...");
   delay(3000);
   Wire.beginTransmission(9); // transmit to device #9     // Make sure the order is the same in master and slave.
   delay(20);
  // We're going to send two chunks of data, tempA and tempB. Each of them is less than 1,000 and has two digits after the
  //decimal place.
   tempZ=boilerTemp;
   numberId= 101;
   sendData();
   Serial.print(numberId);Serial.print(":  ");Serial.println(tempZ);
   delay(50);
   tempZ=refluxTemp;
   numberId= 102;
   sendData();
   delay(50);
   tempZ=condensorTemp;
   numberId= 103;
   sendData();
   delay(50);
   tempZ=hydroTemp;
   numberId= 104;
   sendData();
   delay(50);
   Wire.endTransmission();
   delay(20);
   tempZ=mins;
   numberId= 107;
   sendData();
   delay(20);
   tempZ=alcoholX/10;
   numberId= 105;
   sendData();
   tempZ=pressure/10;
   numberId= 106;
   sendData();
      while (k<20)
      tone (A0,700,50);
      delay(100);
      k++;
      k=0;
   delay(50);
   Serial.println("");
   Serial.println("Transmission ended ....... ");
   Serial.println("");
   previousTime=currentTime;
  int momentarySwitch = digitalRead(28);
  if ((momentarySwitch == LOW)&&(momentarySwitchStatus == 0))
    momentarySwitchStatus=1;
  else
    if ((momentarySwitch == LOW)&&(momentarySwitchStatus == 1))
     momentarySwitchStatus=0;
///////////////////////////// if command encompases all the next code /////////////////////
if (momentarySwitchStatus==0)
// Test external relays ////////////////////////////////////////////////////////////////////
//  digitalWrite(53, LOW);
//  delay(5000);
//  digitalWrite(53, HIGH);
//////// A place to allow settings to be adjusted ///////////////////////////////////////////////////////////////////////////
while (adjustmentTimer>0)
    tone(A0,(adjustmentTimer*2)+600,50);
    potReading01 = analogRead(A1);
    pumpTimer4 = potReading01;
    lcd.setCursor(0,0);
    lcd.print("Pump timer:");
    lcd.setCursor(12,0);
    lcd.print("        ");
    lcd.print(pumpTimer4);
    lcd.setCursor(15,0);
    lcd.print("secs");
    lcd.setCursor(0,1);
    lcd.print("Alcohol limit:");
    lcd.setCursor(15,1);
    lcd.print(alcoholLimit);
    potReading03 = analogRead(A3);
    powerFactor = map(potReading03, 14, 1023, 0,  100);
    lcd.setCursor(0,2);
    lcd.print("Power factor:");
    lcd.setCursor(14,2);
    lcd.print(powerFactor);
    lcd.setCursor(18,2);
    lcd.write(2);
    potReading02 = analogRead(A2);
    mappedPotReading02 = map(potReading02, 13, 1023, 0,  1000);
    endTemp = (mappedPotReading02 / 200.00) + 98.00;
    lcd.setCursor(0,3);
    lcd.print("End Temp:           ");
    lcd.setCursor(10,3);
    lcd.print(endTemp,2);
    lcd.setCursor(16,3);
    lcd.print("\337C");
    adjustmentTimer=adjustmentTimer-1;
    delay(100);
///////////////////////////////// Reading potentiometer on A1: Unused ///////////////////////////////////////////////////////
if (loopToStart ==0)
    lcd.clear();
    lcd.setCursor(0,2);
    lcd.print("Pump in timer:");
    lcd.setCursor(5,3);
    lcd.print(" seconds  ");
///// Empty the boiler. Fluid exits from LH valve port 3 /////////////////////////////////////////////////////////////////////
pumpTimer1 = 1000*potReading01;
pumpTimer2 = 1000*potReading01;
  //Pump and valves:
  //Valve default state is port 1 to 3 open.
  while (pumpTimer1>0)
  levelSwitch = digitalRead(A8);
  if (levelSwitch == HIGH)
    tone(A0,800,500);
    Serial.print("Level switch:  ");
    Serial.println(levelSwitch);
  pumpTimer1=pumpTimer1-1000;
  lcd.setCursor(0,0);
  lcd.print("    PUMPING OUT     ");
  lcd.setCursor(0,1);
  lcd.print("                    ");
  lcd.setCursor(5,1);
  pumpTimer3 = pumpTimer1/1000;
  lcd.print(pumpTimer3);
  digitalWrite(49, LOW); // Pump
  delay(1000); //Effectively mappedPotReading01 is in seconds.
  lcd.setCursor(0,1);
  lcd.print("     COMPLETED      ");
  delay(5000);
///// Fill the boiler. Fluid enters from RH valve port 2 /////////////////////////////////////////////////////////////////////
pumpTimer3 =1;
if ((loopToStart ==0)&&(pumpTimer3>0)) // &&(levelSwitch==LOW)
//  digitalWrite(49, LOW);  // Pump
//  digitalWrite(51, LOW);  // LH valve
    digitalWrite(53, LOW);  // RH valve must be opened before the pump starts.
//  delay(5000);
//  digitalWrite(49, HIGH);
//  digitalWrite(51, HIGH);
  delay(2000);
  while ((pumpTimer3>0) && (levelSwitch==LOW))
  tone(A0,800,500);
  pumpTimer2=pumpTimer2-1000;
  lcd.setCursor(0,2);
  lcd.print("    PUMPING IN      ");
  lcd.setCursor(0,3);
  lcd.print("                    ");
  lcd.setCursor(5,3);
  pumpTimer3 =pumpTimer2/1000;
  lcd.setCursor(9,3);
  lcd.print(" Seconds  ");
  digitalWrite(51, LOW);  //LH valve
  delay(1000);
  lcd.setCursor(0,3);
  delay(5000);
  lcd.clear();
loopToStart=1;  // This stops the pumping processes repeating in every loop.
///// Dump the contents of the hydrometer at the start ////////////////////////////////////////////
  startAndEndDump();
////////////////// Changes the Beep when alcohol starts to be produced /////////////////////
  if (pressure < 400)
    tone (A0,tempC*40,500);
  else
    k=10;
    while (k<20)
      tone (A0,tempC*k,50);
      delay(50);
      k++;
   if (a==0)                // One off Producing alcohol SFX.
     digitalWrite(41, LOW);
     delay(500);
     a=1;
///////////////////////////////// Reading potentiometer on A2: End point temperature ///////////////////////////////////////////////////////
    delay(100);
    lcd.setCursor(0,0);
    lcd.setCursor(11,0);
    lcd.setCursor(18,0);
    lcd.print("\337C");
 //   Serial.println(endTemp,2);
///////////////////////////////// Reading potentiometer on A3: Heater power factor % ///////////////////////////////////////////////////////
    lcd.setCursor(0,1);
    lcd.print("Power factor:           ");
    lcd.setCursor(14,1);
    lcd.setCursor(18,1);
    lcd.write(2);
///////////////////////////////////// Row 4 of LCD ////////////////////////////////////////////////////////////////
    lcd.setCursor(0,3);
    lcd.print("                    ");
    delay (1000);
    lcdStuff();
///////////////////////////////// Now producing alcohol SFX ///////////////////////////////////////////////////////
if ((tempCount==30)&&(pressure>100))
  delay(500);
  Serial.print("tempcount:   ");Serial.println(tempCount);
//////////////////////////////// The process needs to finish ////////////////////////////////
  if (tempC > endTemp)
//   startAndEndDumpValue=0;
//   startAndEndDump();
   while (1)
    lcd.setCursor(0,0);
    lcd.print("      FINISHED      ");
    digitalWrite(25,LOW);
    delay(1000);
    digitalWrite(25,HIGH);
    delay(10000);
  else
  digitalWrite(A0,HIGH);
  alcoholX = analogRead(A7)*1.01;
  Serial.print("Alcohol:  ");Serial.println(alcoholX);
  if (alcoholX>alcoholLimit)
    lcdStuff();
  digitalWrite(27, LOW);    // SFX
  delay(500);
    delay (10000);
  else
  if (alcoholX<alcoholLimit)
   alcoholCount++;
  else
   alcoholCount=0;
/////////// Heater control for full power:///////////////////////////////////////////////////
  if ((alcoholX<650)&&(alcoholCount>5)&&(tempC<85))
  digitalWrite(6, HIGH);
     if (T05==0)                  // Make a one off audio sound
      digitalWrite(33, LOW);
      delay(500);
      T05=1;
      lcd.clear();
//  else
//  digitalWrite(6, LOW);
//  T05=0;
/////////// Heater control for 1/5 power://////////////////////////////////////////////////////////////////
  if ((alcoholX<650)&&(alcoholCount>10)&&(tempC>85)&&(condensorTemp<50))
  delay (1000);
  delay (powerFactor*250);
  Serial.print("Power Factor:   ");
  Serial.println(powerFactor,2);
 // else
if (condensorTemp>50)
  lcd.setCursor(0,3);
  lcd.print("Condensor too hot");
////////////////////////////////// One off SFX ////////////////////////////////////////////////////
if ((tempC>70)&&(T03==0))
  digitalWrite(29, LOW);
  delay(500);
    T03=1;
else
if ((tempC>95)&&(T04==0))
  digitalWrite(31, LOW);
  delay(500);
    T04=1;
else
  foreshotsDump();
  if (f==5)
  pressureZeroing();
  sensors.requestTemperatures(); // Send the command to get temperatures
  printTemperature();
  totalTempC = totalTempC + tempC;
  int pushButton = digitalRead(10);
    if (pushButton == HIGH)
 //     Serial.print("Switch Off");
    } else
 //     Serial.print("Switch On");
 //   pressureZeroing();
     digitalWrite(8, HIGH);
//      Serial.println(" ");
///////// Reading the hydrometer pressure sensor ////////////////////////////////////////////////////////////////////////////
  int16_t adc0, adc1, adc2, adc3;
 // adc0 = ads.readADC_SingleEnded(0);
 // Serial.print("AIN0: "); Serial.println(adc0);
 i=0;
 c++;
 sensorValue =0;
 while (i<15)
  adc0 = analogRead(11);
  i++;
  sensorValue = sensorValue + adc0;
  delay (50);
  sensorValue = sensorValue/i;
 // sensorValue = adc0;
  // Map it to the range of the analog out:
  //outputValue = map(sensorValue, 0, 1024, -2500,  2500);
  adjustedOutputValue =   (sensorValue-512)*2.2; // Needs to be active in the range 0 to 1,000.
  pressure = adjustedOutputValue;
  Serial.print("Pressure sensor = "); // The sensor usually reads about 512 ie 1024/2.
  Serial.print(sensorValue);
  Serial.print("\t Actual output = ");
  Serial.println(pressure);
if (adjustedOutputValue > outputValueMax)
  outputValueMax = adjustedOutputValue;
if (adjustedOutputValue < outputValueMin)
  outputValueMin = adjustedOutputValue;
  totalAdjustedOutputValue = adjustedOutputValue + totalAdjustedOutputValue;
  av = 1.000*totalAdjustedOutputValue/c;
  avPressure = av/1.607/1.284;
  ethanol = 100 - (avPressure - densityEthanol) / (1000 - densityEthanol) *100;
  mins = c/60;
////////////// Calculating the temperature changes value (delta T) ////////////////////////////////////////////////////
if (tempCount ==10)
  deltaTempC = totalTempC/10 - previousTempC;
  previousTempC = totalTempC/10;
  doubleDeltaTempC = deltaTempC - previousDeltaTempC;
  previousDeltaTempC = deltaTempC;
  if (deltaTempC >0.2)
    digitalWrite(39, LOW); // SFX (Temperature is rising .... Checking all systems are operational.)
    delay(500);
//  Serial.print(k);
//  Serial.print(",");
//  Serial.print(totalTempC/60);
//  Serial.print(deltaTempC);
//  Serial.println(pressure,0);
//  Serial.print("Ethanol%: ");
//  Serial.println(ethanol,0);
  z=10;
  y=0;
  totalTempC=0;
////////////////////////// Zeroing the hydrometer sensor at 70 degrees C //////////////////////////////////////////////
  if ((tempC>70)&&(h<1))
    pressureZeroing();
    h=1;
  tempCount=0;
  k++;
////////////////////////// Print to LCD /////////////////////////////////////////////////////////////////
  lcdTemperatures();
  delay(5000);
  lcdStuff();
  delay(5000);
  tempCount++;
  f++;
////// The curly bracket above is effectively the main loop except for small bit of code below /////////////
////////////////// Momentary switch stuff below here ///////////////////////////////////////////////////////
else
   paused();
   delay(1000);
void paused()
   digitalWrite(6, LOW); // Turn off heater.
   digitalWrite(8, LOW); // Close dump valve.
   printTemperature();
   lcd.setCursor(0,0);
   lcd.print("       PAUSED       ");
   lcd.setCursor(0,1);
   lcd.print("                    ");
   lcd.setCursor(0,2);
   lcd.print("                    ");
   lcd.setCursor(0,3);
   lcd.print("                    ");
   lcd.setCursor(0,0);
   lcd.print("P:");
   delay(10);
   lcd.setCursor(2,0);
   lcd.print(pressure,0);
   lcd.setCursor(0,1);
   lcd.print("Max:");
   lcd.setCursor(4,1);
   lcd.print(outputValueMax);
   lcd.setCursor(0,2);
   lcd.print("Alc:");
   delay(10);
   lcd.setCursor(4,2);
   lcd.setCursor(0,3);
   lcd.print("Secs:");
   lcd.setCursor(5,3);
   lcd.print(c);
   lcd.setCursor(11,3);
   delay(10);
   lcd.print("Mins:");
   lcd.print(mins,1);
   lcd.setCursor(11,1);
   lcd.print("A:");
   delay(10);
   lcd.setCursor(11,2);
   lcd.print("T:");
   lcd.setCursor(13,2);
   lcd.print(tempC);
   lcd.print("\337C");
void printTemperature()
  Serial.print("Boiler Temp: ");
  boilerTemp =sensors.getTempCByIndex(1)-0.76; // Change the index value accordingly.
  Serial.println(boilerTemp);
  Serial.print("Reflux Temp: ");
  refluxTemp =sensors.getTempCByIndex(2)-0.76; // Change the index value accordingly.
  Serial.println(refluxTemp);
  Serial.print("Condensor Temp: ");
  condensorTemp =sensors.getTempCByIndex(0)-0.76; // Change the index value accordingly.
  Serial.println(condensorTemp);
  Serial.print("Hydrometer Temp: ");
  hydroTemp =sensors.getTempCByIndex(3)-0.76; // Change the index value accordingly.
  Serial.println(hydroTemp);
  tempC=boilerTemp;
void pressureZeroing()
      x = outputValue;
      outputValueMin = 10000;
      outputValueMax = -10000;
      c = 0;
      totalAdjustedOutputValue =0;
      av=0;
      hrs=0;
void lcdTemperatures()
  lcd.setCursor(0,0);
  lcd.print("Boiler Temp:");
  lcd.print("      ");
  lcd.print(boilerTemp,2);
  lcd.print("\337C");
  lcd.setCursor(0,1);
  lcd.print("Reflux Temp:");
  lcd.setCursor(12,1);
  lcd.print(refluxTemp,2);
  lcd.print("\337C");
  lcd.setCursor(0,2);
  lcd.print("Conden Temp:");
  lcd.setCursor(12,2);
  lcd.print(condensorTemp,2);
  lcd.print("\337C");
  lcd.setCursor(0,3);
  lcd.print("Hydrom Temp:");
  lcd.setCursor(12,3);
  lcd.print(hydroTemp,2);
  lcd.setCursor(18,3);
  lcd.print("\337C");
void lcdStuff()
  lcd.setCursor(0,0);
  lcd.print("                    ");
  lcd.setCursor(0,1);
  lcd.print("                    ");
  lcd.setCursor(0,2);
  lcd.print("                    ");
  lcd.setCursor(0,3);
  lcd.print("                    ");
  lcd.setCursor(0,0);
  lcd.print("P:");
  delay(10);
  lcd.setCursor(2,0);
  lcd.write(1);
  lcd.print("T:");
  lcd.setCursor(14,0);
  lcd.print(deltaTempC);
  lcd.setCursor(0,1);
  lcd.print("Max:");
  lcd.setCursor(4,1);
  lcd.setCursor(0,2);
  lcd.print("Alc:");
  delay(10);
  lcd.setCursor(4,2);
  lcd.setCursor(0,3);
  lcd.print("Secs:");
  lcd.setCursor(5,3);
  c=millis()/1000;
  lcd.print(c);
  delay(10);
  lcd.print("Mins:");
  mins=c/60;
  lcd.print(mins,1);
  lcd.print("A:");
  delay(10);
  lcd.print("T:");
  lcd.print(tempC);
  lcd.print("\337C");
  if (ethanol>100)
    lcd.setCursor(13,1);
    lcd.print("VOID");
    c=0;
  else
    lcd.print(ethanol,0);
    lcd.setCursor(16,1);
    lcd.write(2);
void foreshotsDump()
    z=15;
  if ((pressure > 500)&&(y<z)&&(foreshotsDumpValue==0))
    digitalWrite(37, LOW); // SFX
    delay(500);
    digitalWrite(8, HIGH);  // dump valve relay.
    while (y<(z+1))
    y++;
    delay(500);
    foreshotsDumpValue++;
    lcd.clear();
  else
void startAndEndDump()
  z=15;
  if ((y<z)&&(startAndEndDumpValue==0))
    delay(500);
    while (y<(z+1))
    lcd.setCursor(0,0);
    lcd.print("       DUMPING      ");
    lcd.setCursor(0,1);
    lcd.print("                    ");
    lcd.setCursor(0,2);
    lcd.print("                    ");
    lcd.setCursor(0,3);
    lcd.print("                    ");
    y++;
    delay(500);
    startAndEndDumpValue++;
    y=5;
    delay(1000);
    digitalWrite(7, HIGH); // Neutralise hydomter pressure sensor by 3 way solenoid in tube.
    tone(A0,600,600);
    delay(5000);
    tone(A0,600,600);
    delay(1000);
    lcd.clear();
  else
void testRelays()
  delay(2000);
  delay(2000);
  delay(2000);
  digitalWrite(13, HIGH);
  delay(2000);
  digitalWrite(9, HIGH);
  delay(2000);
void printAddress(DeviceAddress deviceAddress)
  for (uint8_t i = 0; i < 8; i++)
    // zero pad the address if necessary
    if (deviceAddress[i] < 16) Serial.print("0");
    Serial.print(deviceAddress[i], HEX);
void sendData()
  //  We're going to turn testAAAA and testBBBB into shorter numbers to transmit:
  //  assume the number is less than 1,000 and we want to preserve the first two decimal places
    testAAAA = nothing + tempZ*100;
    stringLengthAA = testAAAA.length();
    testAAAA.remove((stringLengthAA-3),3); // Remove decimal place etc.
 //   Serial.print("testAAAA: ");Serial.println(testAAAA);
    Wire.write(dataPrecursor);                          // Must send this junk data precursor first!
    Wire.write(numberId);
//    Serial.print("numberId is:   ");Serial.println(numberId);
    Wire.write(stringLengthAA-3);
    n=stringLengthAA-4;
      while (n>-1)                                       // Send the data back to front.
      digitCharAAAA[n-1] = testAAAA.charAt(n);
      n--;
      digitAAAA = (digitCharAAAA[n]+nothing).toInt();
 //     Serial.print("Digit to send:  "); Serial.println(digitAAAA);
      delay(20);
      Wire.write(int (digitAAAA));                       // Values must not be greater than 255 (1 byte)?
end.
Step 18: Adafruit GPRS Feather Code
Picture of Adafruit GPRS Feather Code
The crux of this code is the 'unravelData()' function which receives the stream of data and turns it into a character arrays called 'rabbits'. These arrays are then pretty much ready to be passed over to the FONA module for transmission down the GPRS network via a PHP 'Get' command. No real animals are sent down the I2C bus!!
Whilst on the subject of rabbits, an analogy would be where two foxes are working together on different sides of a hedge. The first fox chops the rabbits up into legs, arms, head, ears etc and sends everything down the rabbit hole tail first, ears last. The fox on the other side of the hedge is feeling benevolent and puts the rabbits back together again, but needs to know which rabbit is which and how many parts each rabbit was chopped up into as some rabbits were bigger than others.
#include <Wire.h>
#include "Adafruit_FONA.h"
#define FONA_RX 9
#define FONA_TX 8
#define FONA_RST 4
#define FONA_RI  7
// this is a large buffer for replies
char replybuffer[255];
String initiator;
String dataString;
const char webAddress[100] = "http://www.goatindustries.co.uk/test/send.php?";
char url[120];
String nothing;
int numberId =0;
String resultForNumberId;
String numberA;
int stringLength =0;
String testad;
float result101=0.00;
float result102=0.00;
float result103=10.00;
float result104=20.00;
float result105=30.00;
float result106=40.00;
float result107=50.00;
int n=0;
int i=0;
String compileA;
char rabbits[10];
int a;
int k;
int z=0;
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
//Connect Rx on Fona to Tx1 on mega or due:
//HardwareSerial *fonaSerial = &Serial1;
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
void setup() {
  pinMode(10,OUTPUT);
  digitalWrite(10, HIGH);
  delay(1000);
  digitalWrite(10, LOW);
  pinMode(13, OUTPUT);
  ledFastFlash();
  ledFastFlashB();
  Wire.begin(9);                // join i2c bus with address #9
  Wire.onReceive(receiveEvent); // register event
 // while (!Serial);                           // Use this for initiating program by opening of serial monitor. Delete in normal operation.
  Serial.println(F("FONA basic test"));
  Serial.println(F("Initialiking....(May take 3 seconds)"));
  fonaSerial->begin(4800);
  if (! fona.begin(*fonaSerial)) {
    Serial.println(F("Couldn't find FONA"));
//   while (1);
  type = fona.type();
  Serial.println(F("FONA is OK"));
  Serial.print(F("Found "));
  switch (type) {
    case FONA800H:
      Serial.println(F("FONA 800H")); break;
  networkStatus();   // Check the network is available. Home is good.
        Serial.println("");
        Serial.println("Checking that GPRS is turned off to start with .........");
  fona.setGPRSNetworkSettings(F("pp.vodafone.co.uk"), F("wap"), F("wap"));   // Change these settings! (Network APN, username ,password)
delay (1000);
        // Turn off GPRS:
        if (!fona.enableGPRS(false))
        Serial.println(F("No - Failed to turn off"));
        Serial.println("If the line above says OK, then GPRS has just been turned off");
delay (1000);
   Serial.println("Waiting for data from i2c  ...........");
void loop()
      if (z>0)              // This loop is initiated if z is greater than 1. The value of z is given by the reciept of I2C data
  delay(5000);
  Serial.print(F("FONA> "));
    ledFastFlash();
    turnOnGPRS();
    turnOnGPRS();
    ledSlowFlash();
   Serial.println("");
   Serial.print("Result 101:   ");Serial.println(result101,2);
   Serial.print("Result 102:   ");Serial.println(result102,2);
   Serial.print("Result 103:   ");Serial.println(result103,2);
   Serial.print("Result 104:   ");Serial.println(result104,2);
   Serial.print("Result 105:   ");Serial.println(result105,2);
   Serial.print("Result 106:   ");Serial.println(result106,2);
   Serial.print("Result 107:   ");Serial.println(result107,2);
        // read website URL
        uint16_t statuscode;
        int16_t length;
        char url[180];
// This is where the data is compiled into a character ....
  dataString =  initiator + webAddress + "tempA="+result101 + "&tempB="+result102 + "&tempC="+result103 + "&tempD="+result104 + "&alcohol="+result105 + "&pressure="+result106 + "&minutes="+result107;
  // To add another temperature reading we would need: +"&tempB="+tempB
  int n = dataString.length();
  Serial.print("Data string to send:     ");Serial.println(dataString);
  Serial.print("Size of string:  ");Serial.println(n);
  // Builds the url character:
      for (int aa=0;aa<=n;aa++)
          url[aa] = dataString[aa];
  Serial.print("Character data to send:  ");Serial.println(url);
  Serial.println("");
//..... and sent out via HTTP to a PHP file called send.php ready to recieve it.
        Serial.print("Sending url .... ");
        Serial.print("Compiled url is: ");Serial.println(url);
        Serial.println(F("****"));
        if (!fona.HTTP_GET_start(url, &statuscode, (uint16_t *)&length)) {
          Serial.println("Failed!");
        while (length > 0) {
          while (fona.available()) {
            char c = fona.read();
            // Serial.write is too slow, we'll write directly to Serial register!
#if defined(__AVR_ATmega328P__) || defined(__AVR_ATmega168__)
            loop_until_bit_is_set(UCSR0A, UDRE0); /* Wait until data register empty. */
            UDR0 = c;
#else
           // digitalWrite(5, HIGH);   // Call back to Master to say that tranmission was successful.
            Serial.write(c);
#endif
            length--;
            if (! length) break;
        Serial.println(F("\n****"));
        fona.HTTP_GET_end();
        Serial.println("Wait for 10 seconds ...........");
        delay (10000);
        // Turn off GPRS:
        Serial.println("GPRS turned off?");
  Serial.write(fona.read());
  z=0;
// End of main loop.
void turnOnGPRS()
        delay (10000);
        Serial.println("Now attempting to turn on GPRS .........");
     //   if (!fona.enableGPRS(true))
     //   Serial.println(F("No - Failed to turn on"));
     //   Serial.println("GPRS is on if the line above shows 'OK'");
     //   Serial.println("Wait for 10 seconds to make sure GPRS is on ...........");
     //   delay (10000);
        if (fona.enableGPRS(true))
        ledFastFlashB();                          // Indicates a connect to GPRS.
        //Serial.println(("No - Failed to turn on"));
void networkStatus()
        //delay(10000);
        // read the network/cellular status
        uint8_t n = fona.getNetworkStatus();
        Serial.print(F("Network status "));
        Serial.print(n);
        Serial.print(F(": "));
        if (n == 0) Serial.println(F("Not registered"));
        if (n == 1) Serial.println(F("Registered (home)"));
        if (n == 2) Serial.println(F("Not registered (searching)"));
        if (n == 3) Serial.println(F("Denied"));
        if (n == 4) Serial.println(F("Unknown"));
        if (n == 5) Serial.println(F("Registered roaming"));
void receiveEvent(int bytes)
  //delay(5000); // wait for data to be sent.
  a=20;
  while (a>0) // This looks for the correct numberId to iniate the next if command.
  numberId = Wire.read();
//  Serial.print("Possible number Id:   ");Serial.println(numberId);
  n=-1;
  compileA = nothing;
  testad = nothing;
 //   Serial.println("");
    if (numberId==101)
    unravelData();
    result101 = (rabbits+nothing).toInt()/100.00;
    if (numberId==102)
    unravelData();
    result102 = (rabbits+nothing).toInt()/100.00;
    if (numberId==103)
    unravelData();
    result103 = (rabbits+nothing).toInt()/100.00;
    if (numberId==104)
    unravelData();
    result104 = (rabbits+nothing).toInt()/100.00;
    if (numberId==105)
    unravelData();
    result105 = (rabbits+nothing).toInt()/100.00;
    if (numberId==106)
    unravelData();
    result106 = (rabbits+nothing).toInt()/100.00;
    if (numberId==107)
    unravelData();
    result107 = (rabbits+nothing).toInt()/100.00;
  a--;
  delay(100);
   delay(10);
   z=1;                 // recieveEvent is on an interrupt so when it's triggered it changes z to 1 and allows main loop.
void unravelData()
     a=10;
    stringLength = Wire.read();
      while (n<stringLength)
      compileA = testad + compileA;
      testad = nothing + Wire.read(); // This is a string.
      n++;
  //    Serial.print("Compile:  ");Serial.println(compileA);
  numberA = compileA;
//  Serial.print("NumberA:  ");Serial.println(numberA);
//  Serial.print("String length:   ");Serial.println(stringLength);
 //Builds the rabbits character:
      i=stringLength;
      for (int aa=0;aa<=i;aa++)
          rabbits[aa] = compileA[aa];
 //Now create a string in which the last 3 characters represent the ID. The string can have the last four characters removed before being processed at the next stage.
      resultForNumberId = nothing + rabbits +" & " + numberId;
 //   Serial.print("rabbits:  ");Serial.println(rabbits);
 //   Serial.print("Result for number Id: ");Serial.print(numberId); Serial.print(" is: "); Serial.println(resultForNumberId );
    Serial.println("");
void ledSlowFlash()
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
void ledFastFlash()
  k=0;
  while(k<20)
    delay(100);              // wait for a second
    delay(100);
    k++;
void ledFastFlashB()
  k=0;
  while(k<20)
    digitalWrite(10, HIGH);   // turn the LED on (HIGH is the voltage level)
    digitalWrite(10, LOW);    // turn the LED off by making the voltage LOW
    delay(100);
    k++;
Step 19: Video Tour
Every decent distillery should have a guided tour - no free samples on this one though! In the video you can see the machine automatically pumping in the homebrewed cider, dumping the foreshots, controlling the boiler heater, performing safety checks and sending out data to a real time webpage for graphical display.
Phew - this has taken me about 3 months to build and debug. Think it's time for a well deserved glass of delicious apple brandy?
Please in the competitions - top right - Thanks!
TomF105 (author)2017-05-02
Did I miss something, or isn't it possible to detect the methanol vaporazing though the absorbed energy in your PID heater? So wouldn't it be safer to first boil the methanol away in 64.7 °C? Is there some fundamental reason in the process this method is not used?
Galt (author)2017-04-09
Don't know how I missed this one. Love everything you did here with very minor exception, and ain't you the stud with the thin stainless welding? Well beyond my capabilities, which is why we use a pull thru dimpler and silver solder lugs for creating ports. We've converted a few American style Sanky "D" kegs into mini-stills. Pull the funky cir-clip out of the neck and it can be easily gutted leaving a perfectly functional half of a flanged coupling for a sanitary Tri-clamp. All that ya need is the silicone gasket (readily available cheap).
http://www.ebay.com/itm/331662160858
We are blessed with a local scrap yard that handles a lot of commercial food processing plant equipment tear outs, so stainless pipe and tube of various lengths and diameters with sanitary clamp compatible flanges is readily available and cheap.
My cons were pretty simple and small, but I'd hate for anyone to allow them to detract from the genius of your controls. You should definitely consider marketing them. Beyond distillation and all of its irrational gov't meddling, home brewing beer is much less onerously regulated, so a lot more people doing it, and there is huge interest/market in automated controls for nano-breweries, particularly including 240 volt heating. Seems you've already done the developmental heavy lifting and it would be a relatively simple lateral transition. Just sayin'...
As a general rule I avoid brass due to the potential heavy metals issue. Also, as has been mentioned, replacing the condenser with a Liebig or other type of water cooled condenser would seem more befitting the technology you've already employed. In keeping with your "transportable by donkey" parameter, you could design for a separate remote recirc sump to sling on the opposite side of the ass to keep him from leaning, and if ya wanna get real goofy, how about Peltier cooling the sump? :)
Not a tech nerd, so I know just enough to blow myself up or maybe poison a wedding party, but we have fun learning along the way.
Awesome -ible as always!
Tecwyn Twmffat (author)Galt2017-04-16
Thanks Galt - great to hear from you again!
That's a great tip about the silver solder fittings. I'll give it a try in the next project, whatever that may be.
Galt (author)Tecwyn Twmffat2017-04-17
Always love your projects. Here's a few pics of some other builds that I take inspiration from. S/S reducing fittings also work well with the draw bolt dimpling concept to give a nice well for soldering. Also the sanitary cloverleaf fitting attachment allows either a column or a pot still config using the same boiler components.
david.roseman (author)2016-11-29
Holy overkill 20,000 batman. First off, thank you for adding a disclaimer that it's ILLEGAL to distill in almost all parts of the world (curse you NZ!!!). Permits for home-distilling is rare and VERY expensive most places.
Second, you shouldn't distill beer. Hops oils will contaminate everything and make things taste like arse.
Third, the amount of methanol in beer/wine when distilling is very small. Even if you drink the entire batch of spirits, you'd get a hangover and one nasty headache. That INCLUDES drinking the fores and tails. Removing fores is a good way to get rid of things. Keep in mind, only fruit based mashes will have methanol in them. Grain, not so much. Either way, the common misconception about going blind is due to the US Govt actually poisoning spirits during the prohibition to give them an edge, and get people to stop drinking. That, and moonshiners would ADD adjuncts to their spirits that are cheaper and legal, so they can have more volume to sell. It's VERY VERY hard to get majorly sick or kill yourself by distilling in a safe manor. And if you drink that much, you are gonna be wicked sick anyway, and prob' should seek help from needing that much alcohol in you!!
Fourth, holy overkill batman!! HAHAHA.
Also, if you use copper ONLY, with lead free solder (I guarantee you, that finned condenser was used with lead based solder, unless it was used explicitly for beverage cooling), you won't have to remove any weird metal ions.... This is the first time I've ever heard anyone even mention doing something like this!!!
and finally, please, FOR THE LOVE OF GOD, please make sure that NO plastic ever comes in contact with alcohol vapor, or spirit. If you wnat something leaching into your product that will cause health issues, is plastic. Alcohol is a powerful solvent, and plastic WILL degrade into the vapor, wash, and final spirit. All seals should be teflon (high temp neutral material that is safe for high temp alcohol use), or flour paste.
+1 On what you wrote.
You seem to have a good basic knowledge about distilling, so do I. As you already mentioned synthetics like plastic is a bad idea, I won't write anything more about it. For all other readers...David Roseman really wrote a lot of good stuff. For those who want to find out a little more, I'd recommend this site: www.homedistiller.org
My favourite book is 'The Compleat Distiller'. Really good on both the engineering and the science, though rather scant on the heath and safety.
The Compleat distiller is one of my favorites ,too. It's an interesting book, but with a few minor inaccuracies. Mike Nixons "Reflux still and theory", is another book I can recommend if you ever want to produce high proof Ethanol. I must say, it's the first advance distilling machine I've seen out here...bravo..!
It is advisable to throw out the foreshot of any distillate, be it fruit- or grain-based. There are other fermentation product aside from methanol that you don't want to consume, including acetone and formaldehyde. Also, there are enough variables in fermentation (yeast nutrients, temperature, oxygen levels, adjuncts such as herbs) that the potential for methanol production an not be ruled out.
This is a brilliant build, congratulations! My only comment is that re-circulating water around the condenser will improve your output, and is a simple addition compared with what you have accomplished already.
Some really good additions - Thanks David!
I should mention that the condenser tube was painted with lead solder on the outside, with none on the inside or on the pipe ends.
Ah, good point on the condenser. As long as it's a straight tube, only the OUTSIDE would have been soldered.
Quite so.
acolomitchi (author)2016-12-17
"I might upgrade this to a capacitance probe if I can bench test one successfully." With that much metal around, I don't think an individual probe will work. That is, unless you use the very tube itself as one "plate" and have a central wire as another, with the liquid acting as a dielectric - sort of a Leyden jar. But again, since your dielectric have variable permittivity (anywhere between water 80, ethanol 24), I don't think a linear level indicator can work based on the capacitance in the context of your still. Capacitance probes... better stick to water level detection in the (plastic) tank of a solar heated shower.
ausernamenotused (author)2016-12-07
Great work! Many years ago I red in a book that you can have a tablespoon of potassium permanganate per 20 Liter of mash. The higher alcohols or the stuff that smells and taste bad will be converted in to another substance, and that substance then don't evaporate until a temperature of 170 C. So effektiv removing most of the bad stuff before distilling. I don't know if it works, but would be interesting to know if someone tried it.
Sounds interesting - thanks - I will have to look into it.
jcleverley (author)2016-12-04
I've been looking at purchasing something like this for years. (And yes, I'm a kiwi so I'm actually allowed)
Would you consider selling the complete unit in parts?
It's not really fully developed yet, certainly not fit for sale - maybe in a year or two if I keep on working on it.
Captain Jim (author)2016-11-29
You are my hero.
At last I am somebody's hero. It's been a lifelong ambition! Thanks!
diy_bloke (author)Tecwyn Twmffat2016-12-02
Mine too Tecwyn
Tecwyn Twmffat (author)diy_bloke2016-12-03
Oh no ........ This is getting out of control!
diy_bloke (author)Tecwyn Twmffat2016-12-03
When is the Action figure coming
Very soon hopefully!
diy_bloke (author)2016-12-02
As an other reader pointed out the amount of methanol will be very small, well that is true as long as you start with a grain or sugar based wort, in a
clean fermentor with a yeast culture from a well aereated source. That will
result in small/no methanol formed. The reaction formula just doesnt have it.
Until maybe you start using any ingredients that contain pectin. Fruits for instance. Pectin when fermented will yield methanol. Distilling it will not only increase the ethanol content but also the methanol content.
Will that pose a danger? I dont know. Sure, the first distillate run off will be the most concentrated in methanol as methanol has a lower evaporation point but I have no idea if this would come to toxic levels. Also realise that ethanol is a natural antidote for methanol, so maybe (but dont take my word for it) it will "neutralise" the danger of a bit of methanol in yr spirits.
But how about those Indian weddings I hear about in which 50 people die of selfdistilled alcohol??
Well, I suspect there is more to that, maybe they started off by using denatured alcohol that has a rather high content of methanol already
My personal theory about the wedding you mentioned is that somebody got hold of a 205 litre barrel of pure methanol and mixed it into the drinks fro a cheap (and very nasty) booze up. Probably they were not even aware that it was not proper ethanol or maybe they actually wanted to poison the guests, but it is extremely unlikely, eg 1:1,000,000, that even the worst home made spirits would contain enough methanol to kill anyone in one session.
indeed. i agree, I doubt they really would start brewing for say 700 guests.More like: "Hey they sell some cheap alcohol in this drugstore, it is even 40% m..me..meth..methyl, well i dont know what that is but here it says 'alcohol'. Fully agree, home made alcohol even if it would contain say 2% methyl alcohol would still contain enough ethanol (as antidote) to compete on receptors, though I wouldnt advise drinking that on a regular basis. Starting from water and sugar renders factually no methanol and lets not forget that your colon (well anybodies colon ofcourse) is pretty good at making metanol as well, there wld probably be more methanol in a 2 day old apple pie than in a sugar based worth destillate
shapespeare (author)2016-12-01
Excellent job! You are good to point out that welding thin stainless is a huge PITA. Next time try food-safe silver solder. It is much easier to work with because you can't melt the base metal. And unlike welding, silver solder wants to make airtight joints. Or you can get yourself a stainless pressure cooker at a thrift store.
Very good ideas - thanks!
inuyasha7322 (author)2016-11-30
Awesome design! Wish I had the technological know how to replicate your still-and laws that let me produce more than just fuel.
Thanks!
Max Maker (author)2016-11-30
How do you know about this stuff?
Tecwyn Twmffat (author)Max Maker2016-12-01
I worked in the biofuels industry for many years building industrial machinery and getting a good understanding of triglyceride + methanol chemistry. There are a lot of similarities.
MikeD50 (author)2016-11-30
Shouldn't it be enough to measure temerature at the top of the system, before vapour is entering the cooler ... if temp <= 65C then Methanol / solenoid valve to waste, if temp >78 (say well above) then Ethanol / solenoid to treasure sink, if temp > 95 (or so - depending on what you burn) then end of travel / drive down boiler, solenoid back to waste ... you may want to add a time delay to cater for the travel through the cooler.
Tecwyn Twmffat (author)MikeD502016-11-30
I am doing this, but your suggestions for temperature readings don't work on this type of still, which is designed for nice flavours. It might be relevant on a column still with loads of reflux though.
deluges (author)2016-11-30
Amazing man. Getting closer and closer to self-sufficiency I see !
Tecwyn Twmffat (author)deluges2016-11-30
Thanks! Unfortunately, the closer I get to self sufficiency, the more I realise how much I need other people. It's not an unhappy situation ..... I think I'm chasing a rainbow ...... and it's good fun!
smartrem (author)2016-11-29
Excellent work, you got my vote.
For my personnal information, I'd like to know how you're pulsing the power on your heater ?
If you could just reinject a bit of your production into your pot (10 to 20%), you'd increase your production rate and this would be just like an industrial distillery.
Tecwyn Twmffat (author)smartrem2016-11-29
The heater is pulsed on for about 10 seconds and then off for 20 seconds by means of a small 10 amp relay. Seems to work well, but makes the lights flicker slightly!
Yes, I've read that the heads and / or the tails can be reintroduced, but I'm finding it difficult to understand the logic of this!
smartrem (author)Tecwyn Twmffat2016-11-30
You need to reintroduce a bit of your production into the pot, it'll give you more ethanol in your mix which will induce a steadier temperature making it easier to extract alcohol. A simple 3 way valve with one way from your condenser, 1 way to your production and 1 way back to the pot is pretty easy to make. I've seen in a lab a system with a small glass funnel moved by a magnet. When electricity is on it attracts the magnet on one side, and released once off. You were able to adjust the frequency and duration of production/recycling. Like an industrial column, full recycling to heat up the thing, extracting the head, partial recycling to get the product and all off once everything is extracted.
SergeyT9 (author)2016-11-29
LMAO! Brilliant project and device! But i using more primitive system :)
Tecwyn Twmffat (author)SergeyT92016-11-29
Thanks! Primitive is good too.
SergeyT9 (author)Tecwyn Twmffat2016-11-29
There (i'm in Ukraine now) are many recipes for alcohol (typically homemade vodka from a variety of components) and for distillation devices. From complex (as i see here) to very simple (for example, a pelvis in the pelvis). You have got a very nice and hight technology device. I admire them.
JeffC156 (author)2016-11-29
never test a boiler of any type using air, it is very dangerous. always use water to pressurise with.
the reason is if your vessel fails when using air, it will fail in an explosive fashion.
but if the vessel fails using water then the pressure will instantly drop off to atmospheric pressure at no risc to life.
Tecwyn Twmffat (author)JeffC1562016-11-29
Good point ...... Thanks!
razamatraz (author)2016-11-29
This is super cool.
Thanks!
shantinath1000 (author)2016-11-29
Be careful with the radiator tube- if it has been soldered with lead solder it will leach into the alcohol.
Thanks for the heads up. I should mention that the condenser tube was painted with lead solder on the outside, with none on the inside or on the pipe ends.
harrydell (author)2016-11-28
what a incredible stuff! Great job!
Tecwyn Twmffat (author)harrydell2016-11-29
Thanks!
About This Instructable
63,360views
557favorites
License:
Bio: Ugly pirate roaming the seas in search of Treasure.
More by Tecwyn Twmffat:Arduino Cell Phone 4G Signal Booster / RepeaterSimple Manual Arduino 4 Axis Stepper Motor / 16 Channel LED Power ControllerFull English Breakfast
Add instructable to:
