Turnigy 9XR Pro: 4in1 Multi Protocol Module All in One Radio Transmitter
2,411
14
Posted in TechnologyRemote-control
Introduction: Turnigy 9XR Pro: 4in1 Multi Protocol Module All in One Radio Transmitter
https://www.youtube.com/watch?v=1ZjoXqyWwWU
The ultimate universal transmitter radio for RC models on a budget. The Turnigy 9XR Pro from HobbyKing can be had for about $60. Compared to the FrSky Taranis ($250), it's a much cheaper option. When installed with the multimodule, the transmitter can control many types of models from many RC brands. More protocols are added regularly so you can control everything with just one radio transmitter.
In this video:
4in1 multi-module PPM vs Serial Install the 4in1 module in the Turnigy 9XR Pro Flash ERSky9x firmware Setup model Bind model
Tutorial on how to install the 4 in 1 module for the Turnigy 9XR Pro from BangGood.com. When this module with updated firmware is installed, it can almost replace every transmitter for your RTF micro multi-rotors/quadcopters/helicopters and planes.
"The 4 in 1 wireless module integrate four RF chips (CC2500, NRF24L01, A7105, CYRF6936) into one single circuit board,with MCU baseplate, can support a variety of remote control protocols by identifying the PPM signal output of the remote control, such as Walkera DEVO, Spektrum DSM2, Flysky, Frsky, WLToys, Hubsan, Hisky,etc. It can control up to several hundreds airplanes (or receivers)."
This module makes the Turnigy 9XR Pro compatible with many protocols including:
DSM/DSM2/DSMX Bayang FlySky FrSky Hubsan Syma WLToys HiSky KN ... etc
4in1 Multi Protocol Module for FrSKY Taranis / JR / FlySky 2.4G CC2500 A7105 Flysky Frsky Devo DSM2 Multiprotocol TX Module With Antenna http://bit.ly/bg4in1module
Multi Protocol TX Transmitter Module Case for FrSky FlySky http://bit.ly/bg4in1case
Turnigy 9XR Pro Radio Transmitter http://bit.ly/hkturnigy9xrpro
Battery for Turnigy 9XR Pro http://bit.ly/hk9xrprobattery
FrSky Taranis X9D Plus http://bit.ly/bgtranisx9dplus
ERSky9x Firmware with Multi-Module support http://www.er9x.com/ http://openrcforums.com/forum/viewtopic.php?f=7&t...
RCGroups thread http://www.rcgroups.com/forums/showthread.php?t=2...
Protocol mapping https://github.com/pascallanger/DIY-Multiprotocol...
Models supported - not all are listed but even if they are not listed, they may work with an already supported protocol. Just some trial and error to find out http://www.deviationtx.com/wiki/supported_models
3D printed cases for 4in1 module http://www.thingiverse.com/thing:1691786 http://www.thingiverse.com/thing:1730039
Voice pack for Turnigy 9XR Pro Merge voice folder with the one on your MicroSD card http://openrcforums.com/forum/viewtopic.php?t=771...
Sample .EEPM model setup files (4in1-9xr-pro-ersky9x-models.zip) https://cdn.instructables.com/ORIG/FKJ/YGTZ/J08EF... Syma, JJRC, Hubsan, and the models I have setup
Copy the .eepm files to your MODELS folder on the microSD card and import them from the MENU on your 9XR Pro.
These are sample model config files for the 9XR Pro using the 4in1 module. They are all based on the generic model with some of the channels reversed. Most models are AETR mode:
CH1 = Aileron CH2 = Elevator CH3 = Throttle CH4 = Rudder CH5 = Flip (only active on flight mode 3) CH6 = Lights on/off
5min timer 3 flight modes
Switches TH is throttle on/off (off default) RUD D/R is lights on/off (on default) ID is Flight modes, with low/med/high rates (low default) ELE D/R is Acro/Flip mode (off default, only active in mode3 (high rate) Trainer = timer 1 reset
Step 1:
Turnigy 9XR Pro ERSKY9x model setup files (4in1-9xr-pro-ersky9x-models.zip)
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
