Ultrasonic Range Finder
6,589
79
5
Published
Introduction: Ultrasonic Range Finder
About: 55+ years in electronics, computers, and teaching ... now retired.
This instructable describes how to create a non-contact range-finder using an Arduino and an HC-SR04 ultrasonic module to measure distances in the range 2cm – 400cm.
The accuracy is typically +/- 3mm depending on distance, air temperature, and humidity.
Step 1: Parts List
Very few parts are required:
  • 1 only HC-SR04 ultrasonic module or similar
  • 1 only Arduino Uno R3
  • 4 only Arduino male-female jumper wires
All items were obtained from https://www.aliexpress.com/
Step 2: Wiring Diagram
Only four wires are required to complete this project.
The wiring diagram is shown in photo1.
Step 3: Theory
The HC-SR04 ultrasonic range-finder module (photo 1) provides non-contact measurements in the range 2cm – 400cm. The accuracy is typically +/- 3mm depending on distance, air temperature, and humidity.
For greatest accuracy the target area should be at least 0.5 square meters. Best results are obtained when the transducer is pointing directly at the target. Useable results, however, are possible within an imaginary “cone” of +/- 15 degrees.
Interfacing the HC-SR04 to an Arduino is extremely simple as, apart from the two supply pins, only two wires, “Trig” (trigger) and “Echo”, are required.
A 10uS (microsecond) trigger pulse must be applied to the “Trig” pin to start each measurement.
On receipt of a trigger pulse the module emits an eight cycle “burst” at a frequency of 40kHz (kilohertz) after which the “Echo” line goes HIGH. There is a short 430uS interval between the trigger pulse and the rising edge of the “Echo” pin during which time high energy +/-10 volt charges are built up in the transmitter circuit prior to the ultrasonic burst.
The “Echo” pin drops LOW on receipt of an echo signal or 210mS whichever comes first.
[ Note:
If you block the ultrasonic signals (I used a rolled up sock against the transducers), you will observe a distance reading of 3550cm which is outside the sensor range of approximately 400cm.
Beyond 400cm the distance readings will suddenly jump to 3550cm. The reason for this follows:
In normal operation the measure() function completes its measurement in less than 25mS (423cm) then waits a further 25mS until the task scheduler next sets TaskFlag1 "TRUE".
Should an echo not be received, the task scheduler will continue to set TaskFlag1 "TRUE" every 50mS until the HC-SR04 times out after 210mS and the Echo pin drops low. All 10uS start pulses generated by the measure() function during this time are ignored by the HC-SR04.
The timeout value of 210mS corresponds to a distance of 3550cm ... hence the sudden jump in the distance reading.
The important point is that all distance readings less than 400cm are correct. ]
Typical waveforms
Waveforms for 5cm, 10cm, 20cm, and 200cm distances are shown in photos 2,3,4, and 5.
The top trace in each photo is the “Trig” pin ... the lower trace in each photo is the “Echo” pin.
The duration of each “Echo” pulse can be calculated by multiplying the trace length by the “uS/div” value shown in the lower-right corner of each photo.
Calculating the distance
The exact distance can be calculated from the formula:
  • distance (cm) = pulse-length * speed-of-sound / 2 * 100 ......................................... (1)
This assumes that the “speed-of-sound” is 340m/S, and that the echo-distance is twice the actual distance.
The distance can also be calculated using the formula:
  • distance (cm) = pulse-length (uS) / 59 ............................................................................. (2)
The exact distance can be obtained by adjusting the constant value of 59.
[ Note:
The value of 59 for the constant is derived as follows:
The speed of sound is approximately 340m/S which is 0.034cm/uS (centimeters/microsceond).
The reciprocal of 0.034cm/uS is 29.412uS/cm which, when multiplied by 2 to allow for the return path, equals 58.824 or 59 when rounded. ]
Example 1:
Substituting a pulse-length of 2400uS into equation (1) we get:
  • distance = 2400/1000000 * 340/2 * 100 = 40.8cm
Example 2:
Substituting a pulse-length of 2400uS into equation (2) we get:
  • distance = 2400/59 = 40.7cm
Step 4: The Code
The code comprises a “measure()” function that is called once every 50mS using the task-scheduler described in instructable https://www.instructables.com/id/Multi-task-Your-...
The measure() function comprises the following code:
// ----- generate 10uS start pulse
digitalWrite(Trig,HIGH);
delayMicroseconds(10);
digitalWrite(Trig,LOW);
// ----- measure the distance
while (!digitalRead(Echo));   	//wait for Echo pin to go high
start_time =  micros();
while (digitalRead(Echo));  	//wait for Echo pin to go low
finish_time = micros();
time_taken = finish_time - start_time;
Distance = ((float)time_taken)/59;
The complete code, “Ultrasonic_range_finder.ino”, is attached.
Copy the contents of this text file to an Arduino sketch, save it as "Ultrasonic_range_finder" (without the quotes), then compile and upload it to your Arduino.
Step 5: Measuring Distances
To view the distance readings click “Tools|Serial Monitor” and set the speed to 115200 bauds.
The distance readings may be calibrated by placing an object along a ruler then adjusting the constant “59” value for “Distance” until an exact reading is displayed.
  Click here   to view my other instructables.
  • Casting Contest
    Casting Contest
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
2 Questions
A possible method for lighting a LED light at a specific height (distance) follows:
// ----- add this to the header
#define LED 13//onboard LED on arduino pin 13
// ----- add this to setup()
pinMode(LED, OUTPUT);//initialize the onboard LED
digitalWrite(LED,LOW);
// ----- add this to the main loop()
int distance = int(Distance);//change data type
(distance==15) ? digitalWrite(LED,HIGH): digitalWrite(LED,LOW);
Optionally, use a switch(distance){} function to set different distances.
You still need the ultrasonic sensor ...
Thanks for your answer. Since I am absolutely not an technical person I will have to find someone to built this equipment.
I was wondering, if you could build me one unit? Naturally I would pay you for the material and your time.
If possible just give me a ballpark figure about the cost.
You may reach me at: rlaporte10@gmail.com
Cordially
Instead to have a sound generated, would it be possible to have a led light that would light up when the content of a box raise at a pre fixe hight?
If yes how can I do it.
5 Comments
Photo 1 is the first photo shown in any given step.
Click on any photo and that photo will be displayed along with arrows to the left and right. Now click the left-hand arrow until it disappears. Photo 1 is the left-most image.
For example, in "Step 3", Photo 1 shows the HC-SR04 ultrasonic sensor module, and photos 2,3,4, and 5 show waveforms for distances of 5cm, 10cm, 20cm, and 200cm.
Restart your browser if you see no photos ...
How hard would it be to also have a display?
Sort of like the backup parking sensors with a progressive lighting of LEDs.
A possible solution is given in the above answers.
